Wheel cap
Date: 04/25/2022 11:21 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 04/30/2023 04:31 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 10/04/2019 08:43 pm
Date: 11/05/2020 06:32 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
  • Online today: 1,292
  • Guests: 497
  • Total: 497
CARB
Started by Pintocrazed, February 20, 2015, 12:02:27 PM
Dead stock ATX and a big cam is a driveability killer. A bigger carb will only make that worse.
Ok , But is this a street car or a mini stock racer? How much is the Compression ratio , what kind of fuel octane?. Before I go much further, what kind of power band do you want to deal with? And will you spin the engine beyond 6500 rpm (is the crank and rods upgraded for revs)?
If you can find one, get the Dave Vizard book on hopping up 2.0L ford. Most of your questions can be answered there. We'll be here, it's just a question of the usage and detail of the whole Induction and Exhaust parameters.
Pintosopher, the difference between 150 and 180 Hp is the size of my wallet
Pintocrazed
I GOT A HEADER,FACTORY INTAKE,AND A FOUR BARREL INTAKE ON ITS WAY.OH AND ITS HAS HARDENED VALVE SEATS AND LARGER VALVES
Pintocrazed,
There just isn't enough info on the engine to recommend a specific carb that will work well enough. Head work, Cam, manifold type? headers? More specifics are needed.
Pintocrazed
ALRIGHT THIS IS TO ALL YOU PINTO GURU'S.GETTING A 2.0 BORED .30 OVER WITH A BIG CAM SPECS IM NOT SURE OF MSD DISTRIBUTOR.ANY TIPS ON A GOOD CARB TO USE SUCH AS ONE I CAN GET OF A VEHICLE IN A JUNKYARD TO REBUILD?CAR IS A AUTOMATIC CAR WITH 3.40 GEARS BUT ALSO HAVE A T-5 SITTING AT THE HOUSE OUT OF A 93 MUSTANG.
