Date: 05/21/2019 11:50 am
Date: 04/13/2018 11:30 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 02/16/2019 10:46 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
pintos for sale
Date: 12/11/2018 04:29 pm
door sills
Date: 03/14/2020 03:20 pm
Date: 08/30/2018 12:59 am
  • Online today: 452
  • Guests: 394
  • Total: 394
Pan Problems: V8 edition!
Started by entropy, August 26, 2014, 01:10:39 AM
the interaction between you two and what the car needed is a breathe of fresh air.  if only all of lifes interactions would be so seamless & drama free.
Happy to see the parts made it there OK & were put to good use. I would never have used them.
Merry Christmas !
entropy
Quote from: Reeves1 on November 10, 2014, 08:42:43 AM
Free pan & pick up should be there soon, if not already....
It arrived and last week I put the engine back in the car.  Today the last bolt was turned, the last hose was checked and the car hit the street for the first time in at least 4 months.  No leaks, tons of clearance at the rack...the car is better than ever and I really owe it all to you.  Thank you!  Because of your selflessness, my little monster lives again...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Quote from: entropy on October 12, 2014, 10:17:14 PM
Update.  Picked up a really nice 2-ton cherry picker for next to nothing today....so looks like fixing it right may be able to happen after all.
sounds like you are on your way to a no leak engine. :-)
entropy
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: russosborne on September 20, 2014, 10:26:27 PM
Well, you have to have the cherry picker, you can get by without a stand if you have to.
Sucks, but you can pull the pan while it is on the hoist. Remember, I did say it sucks. But without the hoist you won't need a stand, unless you are thinking about borrowing or renting one. Renting is ok, I used to do it a lot back in the 80's, but you need a friend with a truck to get it home and back if you don't own one yourself.
Yeah...I meant possibly buy one instead of renting one.  I've found some used ones cheaper than a rental....the only thing holding me back is transporting it from the seller to where the car in my SRT 4...
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: Reeves1 on September 18, 2014, 05:20:44 AM
Wish I was closer. I'd help you out with pulling the engine & getting this done for you.
Not really a big job , nor does it take long.
Nothing for me to take out/install an engine a half dozen times a day , when fitting one. By myself.
In regards to the pan/pick up.....PM being sent.
I appreciate it, my friend.  I'll find a way.  I'm starting to dig through craigslist to see if I can't dig up a cheap engine stand and possibly a cherry picker.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: bad bean on September 09, 2014, 11:03:54 PM
Not sure why you didn't put a mustang ll pan on it anyway. But you could try draining oil then clean well put jb weld high heat knead it well push in Crack
Because I didn't do the swap.  That's the pan they used when they built the car in the 80's
As for draining oil/cleaning well/JB Weld suggestion.....that's exactly what failed repair #1 consisted of.  The epoxy popped right off after a 10 minute drive.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: Reeves1 on September 07, 2014, 05:58:12 PM
Yes there is. Maybe. I have one that has no numbers left. Blasted & checked for pin holes : none.
It came on Ugly Yellow. Someone in the past painted over rust & looked like the rust continued under paint.
No rust left after blasting.
Painted Ford blue.
I'll never use it.
If someone has good pictures of one, PM me for my e-mail, so I can compare.
I already gave the Mll frame mounts away for the same reason: I'd never use them.
Better pans "out there" than the Mll pans.
If you've got the oil pump pickup that goes with it, I'd love to talk price with you...
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: russosborne on September 06, 2014, 09:25:54 PM
Any update?
Yup....still boned.  Between being broke, demoralized and ambient temps in the 3 digit range, I haven't yet attempted halfassed repair #3 yet....but I will fairly soon.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: tjm73 on September 01, 2014, 09:41:28 PM
Can you weld or do you have friends that can? Reproduction early oil pans are cheap. Buy a cheapy, clearance it and swap the pans. Ask a local trade school if they could do the modification if you supply the parts and instructions.
I'd bet you can get a used pan off eBay real cheap or a fellow member may even give you one.
If you "fix it till you can really fix it" and it holds, you will most likely never really fix it.
Swapping pans isn't really an option without pulling the engine...and I don't have the ability to pull the engine right now.  As for never really fixing it, that would happen a few years down the road when my financial and living situation allow me to pull the engine and go bigger.....but that time is not now.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: russosborne on August 29, 2014, 02:38:17 PM
Hey, that is my line.  ;D
I feel your pain. That is exactly the same situation that I am in. :(
I'm surprised that the JB Weld didn't work. This is just a wild ash thought. Do you have a propane torch? Maybe you could solder the crack. It would have to be spotless with no oil at all for it to even have a chance. I don't know if this is even possible, but maybe someone else can chime in.
On second thought, I really like Pinto 5.0's idea. JB Weld really does work, the surface has to be totally free of any oil though.
Yeah...after I drained it, I let it sit for half a week to completely drain out, then hit it with everything from lacquer thinner to brake cleaner....and apparently it wasn't enough to get all the Mobil 1 off...
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
bad bean
I'd have to take pictures of it to confirm it is an Mll pan (post them here).
I also saved the pick up.
Keeping in mind it is NOT smooth steel, due to past rusting......maybe $50.00 + shipping ?
Not worth much to me, and I know 100% that I'd never use it.
However...... I would rather it go to a person that really needs it, rather than someone who merely wants to get it for re-sale to make money.
That is why I posted it here, in case it could help entropy, due to limited funds........or someone in need.
All my cars get the Milodon pan. More oil is a good thing.
So how cheap is cheap for the Mustang II pan????
True....but if the other pan I have is a true Mll pan, I'd let it go cheap.
That's a loooong way from being cheap.
Quote from: dick1172762 on September 07, 2014, 02:13:11 PM
There is no cheap Mustang II V-8 oil pan.
Painted Ford blue.
I'll never use it.
Quote from: entropy on August 29, 2014, 01:49:47 AM
Yeah....that's what I thought the first time I tried to repair it.  And the second.  I'll let you know after the third...
Any update?
tjm73
Quote from: entropy on August 27, 2014, 03:59:22 AM
The problem is that, at the moment, I don't own a cherry picker or an engine stand, nor do I have anyplace I can store said engine once it's out while I do the work and clean it up.  This is, at the moment, a car on jackstands, making due with hand-tools, at a house I don't own, doing repairs with no money kind of deal.  Hence the looking to hack it together well enough to last until I'm working and can do it right.
entropy
Quote from: dga57 on August 29, 2014, 12:11:47 AM
Sounds like a simple enough repair!
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
I repaired a cracked fuel tank in my semi years ago that lasted 300,000 plus miles with aluminum foil & JB Weld.
I roughed up an area way larger than the crack with 80 grit, got it spotless with lacquer thinner then spread a layer of epoxy over an area an inch larger than the crack & put a piece of thick Reynolds wrap over the epoxy & squeegeed it to remove air bubbles but not hard enough to remove the epoxy.
I repeated this 2 more times expanding the patch by an inch each time letting it thoroughly dry each time. This repair held back 150 gallons of diesel fuel for years without a leak & it was on the bottom of the tank.
entropy
Quote from: Reeves1 on August 26, 2014, 05:04:31 PM
Doubt you can pull the engine with headers on (and you wouldn't want/need to anyway).
I know I can pull an engine in 2-3 hours, by myself.
Hard to say one line how I do it.
No cost to pull it.
Cost after it's out is small. New header gaskets & welding the pan, if you do not have a welder....new pan gaskets.
In all, less than the cost of a tank of gas.
Pull it & do it right.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
