Date: 03/25/2019 09:02 pm
Date: 10/24/2018 07:35 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 09/12/2018 12:33 pm
Date: 02/18/2017 04:47 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
door sills
Date: 03/14/2020 03:20 pm
Date: 01/24/2017 12:36 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
  • Online today: 195
  • Guests: 192
  • Total: 192
Pan Problems: V8 edition!
Started by entropy, August 26, 2014, 01:10:39 AM
HOSS429
after you make the fix use a washer or two to raise the engine a bit ( between the mount and the block ) .. bought my first ever V8 pinto swap back for chump change cause the owner said it had a knock in the motor .. two hammers strokes to the side of the pan fixed that ...
Doubt you can pull the engine with headers on (and you wouldn't want/need to anyway).
I know I can pull an engine in 2-3 hours, by myself.
Hard to say one line how I do it.
No cost to pull it.
Cost after it's out is small. New header gaskets & welding the pan, if you do not have a welder....new pan gaskets.
In all, less than the cost of a tank of gas.
Pull it & do it right.
I think you have to stage a "Pull The Pan Party" and get as many So-Cal Pinto Freaks to spend a day doing whatever needs to be done!
You provide the vehicle!
That said; I have Tuesdays & Wednesdays off!
entropy
So, my '72 V8 car is running a regular 60's Mustang style front sump pan which had been clearanced by the original builder.  Some of it was done by hammer work and one small area on the driver's side was done by a cut and a patch that was welded in place.  All those years of basically feeler-gauge levels of clearance between that patched area and the rack has finally caused a crack to form and part of the weld to fail, and now it's leaking like that's its job.  The obvious fix is to pull the engine and repair or replace the pan....but unfortunately, I can't do that for quite a while.  So I'm stuck with solutions that can be done with the car up on jackstands.  So far my attempts to MacGuyver it with JB Weld putty (failed in the first 5 miles of driving) and Permatex's THe Right Stuff (it's already leaking hours after bolting the rack in back in place) have not gone well.  Anybody got any ideas?  How close to impossible would it be to pull the pan with the engine, rack and Hooker swap headers in place?
The goal is to affect enough of a repair to hold it together until I can afford to pull the engine in a year or two....
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
