Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 09/21/2018 11:35 am
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 03/30/2021 12:29 pm
Date: 04/12/2017 06:57 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
  • Online today: 344
  • Guests: 167
  • Total: 167
v-8 pinto
Started by bob hess, August 20, 2014, 09:26:20 AM
Well I got the part of the world right. Opel instead of Volvo. Thanks for the post Hairball.
Hairball
The water pump is a Snow White, made from an Opel.
It moves the water outlet to the other side
Link
http://www.snowwhiteltd.com/products.html
http://www.speedwaymotors.com/Snow-White-Small-Block-Ford-Shorty-Water-Pump-2-Groove-Pulley,58832.html
The two cars I built, I ground the tit down on the water pump to about 1/8 inch.
I used thin head bolts on the pulley with NO lock washers. I use red locktite.
I used V6 pinto radiators in the stock location ans did not cut the core support.
I used an electric pusher fan in front after trimming the rubber bumper piece.
This gave me 3/8 inch clearance between the pulley bolt and the rad.
Nice green 1977 cruising wagon wanted
ADDCO, jic somebody does a search.........................
The Mustang II (V-8) front sway bar is already bent to clear the oil pan with no mods necessary. The bar really hangs down right in front of the oil pan. 2.3 Mustang II don't have this mod and will not clear a V-8 oil pan. There was an export 1" V-8 sway bar sold over the counter. So now all you need is a V-8 Mustang II sway bar. I'm pretty sure ADCO makes one for the V-8 cars.
I think the MII front sway bar needs heating & bending to fit.
My 79 V8 car just had the bar spaced with a stack of washers on longer bolts. I didn't do it but it worked fine
no you do not have to remove the sway bar, you have to make a one inch thick spacer out of aluminum for the sway bar clamps to bolt on, it will drop just a tad below the oil pan , which is good to protect the pan from parking lot bumper stops and other low things , use the mustang two bar , it is thicker and from memory almost a inch think , and if you find one see if it has the rear sway bar also, I know some with the 5.0 had them , I do not know if racer walch still has them in stock anymore , if you have a 74 to 76 pinto use the 77 to 78 front and rear bumpers , they will save you some weight , hope this helps
Quote from: pinto_one on October 15, 2014, 09:16:03 AM
next one was a 74 wagon, mustang II V8 front springs and 8 inch rear, large sway bars front and back, machined front and rear hubs for five lug pattern so I could use 14 inch mag wheels
Could you give some more details on the front sway bar? I have gotten the impression that most think the V8 swap means you have to remove the sway bar in front.
I have a 74 wagon that I am doing the swap in.
Quote from: dick1172762 on October 15, 2014, 08:09:21 AM
Thanks Reeves1. Do you have a link to the Volvo water pump conversion for a small block Ford engine? Someone posted it on this site several years ago. It gave you even more clearance. Thanks again.
News to me. Never heard about that.
I also looked into electric water pumps. All the ones I found were taller/longer than the short one I posted.
This post caught my eye on the V-8 swaps, and my reply I have done a few over the years , I have seen some too, a few that were well done and too many that were just a shame for the car they just wasted trying to do so , poor pick of parts used and extreme cutting up the car to make things fit, not the right way , most people complane that the car does not handle well with a V-8 , well not on the wimpy stock front tires you wont , and the front springs too have to be changed , back in 71 when I done my first one the only wheels you could find were wider 13 inch rims and wider tires , it was fair but not great , next one was a 74 wagon, mustang II V8 front springs and 8 inch rear, large sway bars front and back, machined front and rear hubs for five lug pattern so I could use 14 inch mag wheels , looked much better in those large fenders the pinto has , now could hang with corvettes in the corners , now years later I have a V6 pinto , TBI injection and a A4LD installed (looking for gas mileage now) and does very well , they are two light weight bolt in engines that would be light and fill the bill , first would be the cosworth ford 2.9 , to replace the stock 2.8 , 200hp stock, next would be the 4.0 , yes it will all bolt up, have to mod the 2.8 oil pan on one side to make it work, just my two cents , my only remake is don't cut up the car and waste it, do it very neatly , make it look like it can from the factory with a V8 , later guys
Quote from: dick1172762 on October 14, 2014, 09:36:25 PM
      Can you get us a little closer on that white car water pump post.
I think this is the one:
http://www.fordracingpartsdirect.com/STREET_ROD_SHORT_V_BELT_WATER_PUMP_p/m-8501-e351s.htm
Very minimum you have to change the crank pulley as well. I changed all & got them from here:
http://www.cvfracing.com/ford-small-block-pulleys-s/165.htm
Quote from: Reeves1 on September 26, 2014, 06:31:58 PM
Have to remember the weight of a V8 moves it forward. Everything is. Even the rad goes in front of the rad support.
As far as an aluminum water pump, lots made. If you look in my topic on the white car, you will find the numbers for a short one, that gives an extra 1.5" of clearance.
randyg
I have a V-8 in my 71 and it is brutally fast. I agree with the handling part. It can be downright scary. Now if I had it to do over again, here is what I would do. Find a 305 hp 3.7 v6 from a 2011 or new Mustang and put it in the Pinto. Im not sure of the dimensions but I dont have fenderwells, just tubing to deal with. My 13stang with the v6 and a tune with 4.10 gears rips most 2010 and older stangs.
Randy
Just a 289......
An assumption is being made that a stock Pinto with a 2.3L actually handles well. They don't. My 95 Neon 4 door work car can turn circles around any of my Pintos
bob hess
If we plug in the above weights . ( non turbo ) 2.3 L engine as a factory weight of very near 400 - 420 lbs. Vs. a 289-302 of 460 lbs.  Some are saying the 40 - 60 lbs . is making a big difference in the handling of a 2400 lb. Pinto.
So ,one moves the battery , replaces with alum. : intake , heads , oil pan , all pulleys , light weight flywheel (and if one can find it ) an alum water pump . Now the pricey part :Finding a pro drag racing fiberglass tilt front end .
Any flaw in this ??
Other then the fiberglass front end & the aluminum heads , it should be within a fair budget .
SOOOOOOOOOOOO , unless I missed a big item . Why are so many saying the 302 swap is such a bad idea for a part time drag car that can "  handle "  the rest of the time . From the # of readers I see , there is a lot of interest in a small V-8 Pinto  that can handle .So why hasn't anyone out lined  this in print ? As a do able swap ?
On April 4 2014, Chopchop weighed his 2.3 complete less power steering pump, clutch disk and pressure plate but with flywheel. It weighed 386 lbs. Look up Chopchop posting to see more.
I can lift & move a 2.3 shortblock myself & carry the head easily. Even dressed I'd be amazed if it's 315 pounds. I'd believe 260-ish
Quote from: Clydesdale80 on September 24, 2014, 10:15:53 AM
He said that a 2.3 TURBO weighs close to a 302, not a n/a 2.3, Pintos never came with a turbo 2.3
My point was that a 2.3T makes the car a lot more nose-heavy and a 302 weighs more than a 2.3T, therefore _____.
I've seen mention that a 2.3NA is in the 315lb range, but I find that hard to believe. All the iron and steel hung on the exhaust side of a 2.3T does not amount to 135lbs+. Ergo, either a 2.3T is a lot lighter than everyone thinks or a 2.3NA is a lot heavier than 315.
It would take some meticulous weighing on every part of a V8 swap to prove it but my guess is that a 302 with aluminum heads & intake, headers instead of manifolds & a lightweight flywheel could probably come within 50 pounds of a stock 2.3 turbo with steel flywheel, T3/stock manifold & stock intercooler but a stock 2.3 is a lot lighter than the 2.3T.
A little weight would be farther forward but eliminating the battery & a heavy bumper could counteract that. That said, I doubt it could handle as well as an N/A 2.0 or 2.3 would because those are still easily 100 pounds lighter. 100 pounds doesn't sound like much on a 4000 pound car but a Pinto weighs 2400 so that weight combined with it's placement can definitely affect handling.
Clydesdale80
Pintocrazed
GOOD HANDLING OR BAD HANDLING WHAT DOES IT MATTER YOU WANT A V8 PINTO BUILD IT.
bob hess
Is that the truth ? that a 2.3 L is only 20 pounds less then a 302 ?
And didn't the 2.3 L come in the 79-80 Pintos ?
SOOOOOOOOOOOOOO , why would a (302) V-8 swap  NOT WORK in a 79 - 80 Pinto ?
You can move the battery to the trunk , and there is most of your extra 20 pounds .
Sorry guys . But I'm still not seeing why the v-8 swap would kill the handling so .
That's assuming the 2.3L / 302 , 20 pound thing is true .
PLEASE HELP BEFORE I NEED TO GO BACK THE MY OLD MUSTANG CLUB .
I really do love the little Pinto ( Had one about 10 yrs. ago ). But just can't do the 4 banger thing.
Part of the problem is that a V8 puts a larger portion of the car's weigh on the front tires. A V8 wagon would probably handle a little better than a V8 hatch/sedan.
I hate to say this, but GM's modern all-aluminum pushrod V8s are the lightest and smallest you're going to find short of an old Buick 215 or Rover.
I can tell you this, my '72 is noticeably more nose-heavy with just a 2.3T swap (over the 2.0) and I haven't even driven it yet. Word around the campfire is that a 2.3T is only 10-20lbs lighter than a 5.0 of the same vintage.
Quote from: Pinto5.0 on September 21, 2014, 07:09:43 PM
MII road racers were heavily modded. Stock ones handled like dog poo.
That's for sure!
Mustang II is a much heavier car by several hundred pounds. Never seen one at an autocross or road race in the past 40 years.
bob hess
Thanks guys , for your feedback . So from what I count , 75-25% say the best I can expect from a ( affordable ) V8 swap , is a car that will handle as poorly as a big block mustang . Being new to the Pinto club ( but life long Ford man ) it is still hard to understand way the  ( small V8 swap ) pinto handles sooooo poorly when the Must. II ( factory V8 ) seems to handle fine. They just don't look that much different when you look at them side by side .  Or dose the Must. II have handling problems too ?
Or is it all a matter of how far forward the V8 sits in the Pinto Vs. the Must. II ?
pintoman1972
Bob,
It's all a matter of what you want the car to do, how much time and money you are willing to spend and then following through on it.
Does my Blown V-8 Pinto handle corners well?  No because it was not built to corner.  It was built to go fast and streight.
This Pavement Pounding Pinto is now retired from drag racing and is street legal for cruise nights and car shows.
Build time, 2 1/2 years
Did it cost a lot of money, yep.
Is it fast, plenty.
Does it stop well, sure.
Is it reliable, yep
Does it get instant attention, yes.
Good gas milage, no.
Lots of maintenance, yes
Long road trips, on the trailer.
So make a list of what you want the car to do, and then you can make decisions was to how to build and so on.
Dick
