1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 02/18/2017 04:44 pm
Date: 02/08/2018 02:26 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 02/28/2018 09:33 am
Date: 08/17/2022 06:27 pm
Date: 08/01/2018 01:17 pm
  • Online today: 506
  • Guests: 230
  • Total: 230
v-8 pinto
Started by bob hess, August 20, 2014, 09:26:20 AM
Old bigblock Mustangs don't handle worth a darn either.
Ironically, the 2.3T engine weighs only slightly less than a 302. If you want a compact and lightweight V8 that can make a lot of power, you are probably limited to an all-aluminum 302 ($$$) or a GM 4.8-5.3L V8. A 351W weighs at least 50lbs more than a 302.
A small Japanese aluminum V6 might be an option. I like the Toyota 5VZ-FE, but it's an iron block and not that small as V6s go. (DOHC makes the heads very big)
The 72 I built in the early 70s - 302w - would handle a corner as fast as I wanted to take it.
I had up-graded the front springs & had air shocks in the back & 9".
Handled the corners nearly as good as bro's 69 Mach 1 428 SCJ.
He drove my car & says the same.
This 72 I'm working on now has M ll with A/C front springs. Cut down to 3 & 3/4" less coils than 6 full coils though. Stiff. I want to keep the headers off the ground....so not lowered. BOSS 302.
I do not expect this one to corner well.
Diff is a narrowed 9". I can fit 29 x 18.50 x 15s completely under the fender wells: it's a straight line car.
Having said all that....if you want something that will corner, do a real hot V6. Keeps the weight back enough that with suspension mods it will out corner a V8 by a long shot.
No one will build a V8 & expect it to corner well.
Why a blower or a 351w for such low HP ?
A 302w can far exceed that with simple mods ?
My B2 will have about 550 HP (if he ever gets it done).
bob hess
Hey Guys , is a V-8 swap really  THAT bad an idea ( I'd like it to handle as well as a 64-68 / sorry friends 69-72 Must. DO NOT HANDLE,  TOO HEAVY . I had a 69 Mach 1 .)
ANY input on a   V-6  swap  ( would it handle ? ) Trans -Am tricks ( wider tiers , Fat  F & R Sway Bars , lowering ) . Or do I have to go back to my old Mustang Club ?
Any handling tricks you guys have done that made a Big difference , that would help a V-6 , or V-8 swap ????
Sorry , I'm just NOT a fan of 4 bangers !!
No way a V-8 Pinto will handle as well as a 64 to 70 Mustang. Those cars were killer Trans-Am race cars. Repeat after me (V-8 Pintos will not handle). Sorry but that's the truth.
bob hess
So you are saying , a V-8 pinto can't handle at  least as well as a 64-68 V-8 mustang ????
Tons of V-8 swaps in history . Cobra, Tigers , MBG-gt's . Or should I be better off  looking in to a HOT V-6. Or is that still TOO heavy ?
V-8 Pinto's corner like a drunk sailor. Most of that heavy V-8 is in front of the cross member. Just keep it going in a straight line and you'll be ok.
bob hess
Quote from: Reeves1 on August 20, 2014, 07:06:47 PM
What are your plans for the car ?
Street / strip ?
Or ?
For the most part a HOT street car. But one that can be driven , too & from the track. I'll compromise low e t's for good cornering.
Wish list : 351 W   300 - 375 HP . ?? Street Blower on Pumped (Prem.) gas .
Something my Mustangs friends will take seriously .
Street / strip ?
Or ?
bob hess
Hey Guys ,
Any & all help would be greatly appreciated.
I've been a Ford Guy all my life . ( Shelby , mustangs mostly ) . And recently  fell in love with what I've seen other guys do with V-8 pintos .
So my question is , I read to beware of " junk " V-8 swaps . How can one tell what is a good swap ?
I'm very busy , so I'm considering having a exp. shop ( Phily, NJ area ) do most of the drive train install for me .  I'm shopping for a 79 / 80 runabout now . Any idea of the cost for Labor .   ( I know the sky's  the limit when it comes to HiPo parts.
Many Thanks ,
Bob
