Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Date: 05/13/2021 05:29 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 02/27/2017 10:10 pm
cam pulley
Date: 05/30/2018 04:56 pm
Date: 09/05/2018 06:30 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
  • Online today: 1,292
  • Guests: 594
  • Total: 594
up-grade to turbo
Started by haj81, July 10, 2005, 09:27:31 AM
Quote from: bigh4th on July 13, 2005, 11:36:58 AM
He said 3 tower head, so that leads me to think it was a 2.0.  2.3's have the 4 tower heads.
As far as I know, you'll have to change your motor mounts or fab up some engine brackets to use the exsisting mounts.  You'll also have to do some minor bellhousing bolt-pattern work as the dowel pins on 2.0's and 2.3's are different sizes, and the 2 top bolts are higher up on the 2.3.
-Harry
Ok, well I cant help here untill I get more info................. ::)
bigh4th
-Harry
Quote from: haj81 on July 11, 2005, 05:16:43 AM
I'm looking for a quick conversion, and have some concern about all sensor hookups that I have no place to go with.  Would the old carb and intake manifold work?
II'mstill not sure "exactly what you are trying to do?? When you say you want a quick conversion are you wanting to go from EFI to carb or the other way???
haj81
i'm looking for a quick conversion, and have some concern about all sensor hookups that I have no place to go with.  Would the old carb and intake manifold work?
Quote from: haj81 on July 10, 2005, 09:27:31 AM
I trashed the motor in my sand rail, it (was) the older pinto motor with the three tower head.  I don't think it would be cost effective to rebuild it, so I'm considering going to a later model turbo.  I need to hook up to a volks trans-axle, and would like to run a header.  what problems can I expect to incur?
I will take a bunch of liberties with your post. I assume you are running a 2.3 and a 74-83? vintage. And you want to run a 84-88 vintage Tbird or SVO engine??? I dont think there will be any probblems with your trans adapter. You can port an E6 turbo manifold and do almost as well as a header. are you wanting to run an EFI system or is this the old style carb type set up???
haj81
