2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
73 Runabout
Date: 11/20/2017 03:19 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 04/13/2018 11:30 am
71-73 Hood
Date: 12/07/2018 06:22 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 10/25/2019 04:05 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
  • Online today: 553
  • Guests: 240
  • Total: 240
up-grade to turbo
Started by haj81, July 10, 2005, 09:27:31 AM
Quote from: bigh4th on July 13, 2005, 11:36:58 AM
He said 3 tower head, so that leads me to think it was a 2.0.  2.3's have the 4 tower heads.
As far as I know, you'll have to change your motor mounts or fab up some engine brackets to use the exsisting mounts.  You'll also have to do some minor bellhousing bolt-pattern work as the dowel pins on 2.0's and 2.3's are different sizes, and the 2 top bolts are higher up on the 2.3.
-Harry
Ok, well I cant help here untill I get more info................. ::)
bigh4th
-Harry
Quote from: haj81 on July 11, 2005, 05:16:43 AM
I'm looking for a quick conversion, and have some concern about all sensor hookups that I have no place to go with.  Would the old carb and intake manifold work?
II'mstill not sure "exactly what you are trying to do?? When you say you want a quick conversion are you wanting to go from EFI to carb or the other way???
haj81
i'm looking for a quick conversion, and have some concern about all sensor hookups that I have no place to go with.  Would the old carb and intake manifold work?
Quote from: haj81 on July 10, 2005, 09:27:31 AM
I trashed the motor in my sand rail, it (was) the older pinto motor with the three tower head.  I don't think it would be cost effective to rebuild it, so I'm considering going to a later model turbo.  I need to hook up to a volks trans-axle, and would like to run a header.  what problems can I expect to incur?
I will take a bunch of liberties with your post. I assume you are running a 2.3 and a 74-83? vintage. And you want to run a 84-88 vintage Tbird or SVO engine??? I dont think there will be any probblems with your trans adapter. You can port an E6 turbo manifold and do almost as well as a header. are you wanting to run an EFI system or is this the old style carb type set up???
haj81
