1975 mercury bobcat
Date: 08/14/2018 03:40 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 02/22/2017 01:58 pm
Date: 11/04/2018 02:34 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 04/06/2017 12:13 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 07/08/2017 08:53 pm
  • Online today: 489
  • Guests: 122
  • Total: 122
header.
Started by whoever, June 20, 2014, 08:08:23 AM
jburt
Ahh... I learn something new everyday. Thanks
I color outside the lines...
74 Squire Wagon - needs a lot of work.
The header is stainless steel and doesn't rust.
jburt
Quote from: chrisf1219 on August 23, 2014, 06:37:54 PM
hi I just used the cleaner and just painted it silver with the paint I mentioned above.so far so good give it a lot of coats of paint.i can feel a lot more zip with the header on my wagon.that wrap around metal tube that goes around the back of the engine, I just got a plug and plugged at the egr valve and capped the bung on the header.  chris
Thanks Chris. This header looks like it was a recent replacement on the Ranger. No dirt, no rust (not even flash rust), no carbon build-up. The flange bolts and lower pipe are brown and rusty. The header, clean.
chrisf1219
jburt
Quote from: chrisf1219 on June 22, 2014, 03:34:09 PM
I used eastwood pre painting prep to clean the pipe.I then used vht flameproof silica ceramic coating silver spray paint.i have have the header on a month now and the paint has held up well.this first picture the gasket with no holes is mine and is made of all metal.the second is arts and more of a stock manifold gasket because the hole are needed with a stock manifold.i tapped the holes on the head with a 3/8 pipe thread.i also used 3/8x1/4 Allen screws to seal up the head.a brass cap from the hardware store for the exhaust bung to cap it.also theres a metal tube from stock exhaust manifold and goes to the base of the egr valve. a bass plug also from the hardware store sealed it also.i  used m10x60mm 1.50 pitch hex head flange bolts metric 10.9 grade. I also have a lot of extra Allen screws cause fastnel only sells them in bags of 50.hope any of this info helps out.  chris
I just picked up a 95 Ranger header from a pull your part today. Took the O2 sensor and EGR tube loose and it fell out of the truck. Sweet...
VHT recommends cleaner, primer, ceramic coat, and clear coat. Did you use all of that or just the cleaner and ceramic coat? Is it still holding up well?
whoever
Sorry.  Haven't been on in a while. Came with new bolts, and gasket for 67 bucks. Took it to my buddies exhaust shop, and had everything new to the back put on.
Whoever
chrisf1219
looks like your set got your new bolts for the manifold yet? any questions send me a pm. chris
whoever
Should have it in tomorrow.
Whoever
Post a pic when you get it installed..
whoever
Found one on ebay for $68. All emissions stuff is off. Ready to put it on.
Whoever
Any pipe running to exhaust is either passive or active air injection or EGR supply and plug it at exhaust manifold...........
Mine has a hose from the breather to the air cleaner and a PCV valve, gotta let the crank case breathe, if no emissions you can plug all that stuff up.
whoever
Quote from: 74 PintoWagon on July 01, 2014, 09:36:52 PM
I threw all that junk in the trash but I'm also pre 76 and in a non smog area, good question if you have to have it though.... BTW, if you haven't found one yet here's a nice one..
http://www.fordpinto.com/classifieds/parts-for-sale/ranger-header-for-sale/3033
Thanks for link. I'm gonna try and get that one. I am in Ohio, and emissions doesn't matter where I am at. I haven't taken the breather off yet to see where that hooks in on the intake side. Do I just plug that up?
Whoever
whoever
What do I do with the tube that runs from the exhaust manifold, around the back of the engine, to the other side?
Whoever
Chris, haven't had time to mess with it yet been too dam busy, thanks for the offer but I got a bunch of plugs so that won't be a problem there.
chrisf1219
art were you able to find the different gasket?what did you plan to plug the 3 holes on the head with? I have got some extra Allen screws to plug the holes if you need them.  chris
They do pop up quite often, check every day took a couple of weeks to find mine, finding the carb is giving me fits now, LOL..
whoever
I've been looking on craigslist and eBay every day. Haven't seen anything till todat. A few popped up on ebay. $126. I might as well wait and save a few bucks, and get the one I want.
Whoever
Thanks Chris I'll look into that.
chrisf1219
hi update on header gasket. victor # m516104  95 ford ranger.try that number art and anyone else doing header upgrade.  chris
waldo786
I understand the 93/94 ones are the ones that look like in the pic above. I believe mine was a 94.  Either that or 93.  I don't know what all years are encompassed, but they are referred to as mid-90s headers, so somewhere in that range.  Not sure when they switched.
chrisf1219
Hi my header was a 95.a96 might be ok but anything older or newer is cast iron.just make sure it looks like arts pic and you should do good.if you need more help post or pm me. Chris
whoever
Is there a certain year ranger that I want to look for?
Whoever
Quote from: chrisf1219 on June 22, 2014, 03:34:09 PMthanks art for posting the pictures for me.first I used eastwood pre painting prep to clean the pipe.I then used vht flameproof silica ceramic coating silver spray paint.i have have the header on a month now and the paint has held up well.
You're quite welcome Chris, and thanks for the tip  on the coating I'll probaly do that on mine it looks great..
chrisf1219
thanks art for posting the pictures for me.first I used eastwood pre painting prep to clean the pipe.I then used vht flameproof silica ceramic coating silver spray paint.i have have the header on a month now and the paint has held up well.this first picture the gasket with no holes is mine and is made of all metal.the second is arts and more of a stock manifold gasket because the hole are needed with a stock manifold.i tapped the holes on the head with a 3/8 pipe thread.i also used 3/8x1/4 Allen screws to seal up the head.a brass cap from the hardware store for the exhaust bung to cap it.also theres a metal tube from stock exhaust manifold and goes to the base of the egr valve. a bass plug also from the hardware store sealed it also.i  used m10x60mm 1.50 pitch hex head flange bolts metric 10.9 grade. I also have a lot of extra Allen screws cause fastnel only sells them in bags of 50.hope any of this info helps out.  chris
I got mine for about the same price, if you look by the bolts you'll see the tubes squashed in, if they weren't you wouldn't get the long bolts in, if you remove the stand offs and use short bolts the tubes wouldn't have to be squashed. A brass cap from the hardware store will plug the fitting up.
waldo786
May I ask what the "squash" is that is in the tubes?  I just got one of these headers off ebay.  Take a look around, I got mine for like $60 shipped I want to say.  It was an auto salvage place that didn't have a pic so I asked them the condition and if they could send a pic.  They did and and it is really nice, so you can get one for cheap.  BTW, did you all just leave the oxygen sensor in the header, or did you plug it with a bolt of some kind?  I'd also be curious what coating was used in the pic above, it looks excellent!
And without the stand offs you can take the squash out of the tubes.
Remove those stand off's that the header bolts go through for even better looking header. They were put there so Ford could use the same bolts as used with the cast iron manifold.
