Date: 07/10/2016 10:17 am
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 09/21/2018 11:35 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 10/28/2018 08:45 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 12/24/2016 04:13 pm
  • Online today: 292
  • Guests: 316
  • Total: 316
header.
Started by whoever, June 20, 2014, 08:08:23 AM
Ok, here's the header installed, looks good Chris what kind of coating you put on the header?..
And here is the difference in gaskets, top one is way better.
Got your e-mail thanks Chris, I'll post the pics up later when I get home.
chrisf1219
hi art I sent you a email on the different gaskets. and also on the other things to install the header.if you can post it here for all that might have questions. anyone else need help send me a pm with your reg email address and I will send my email to you.  chris
When I got my gasket it just said 2.3 didn't specify what vehicle but it matches perfect, what's the difference between the Pinto and the Ranger??..
chrisf1219
hi I just installed the ranger header a couple weeks ago. looks just like the picture in the post.it well give your 2.3 some extra zip on low end and threw the gears.use a gasket from a ranger truck and not a pinto cause it well leak if you don't. if you need more info pm me I will tell what worked.  chris
Well, I got this off of E-Gay for about the same as any manifold I seen at the time, just need to shorten the pipe some and it'll match up.
whoever
I found out yesterday that my exhaust manifold has a pretty bad cracked in it. I've been wanting to switch to a header of some kind for a while, but just don't have the money right now. I have heard about people using Ranger maniloflds. Would this be a bolt in swap, or would I have to do any modifying?
Whoever
