Date: 04/06/2017 12:13 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 02/10/2017 09:30 am
Date: 05/21/2019 11:50 am
Date: 01/28/2019 05:15 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 632
  • Guests: 616
  • Total: 616
0 Members and 6 Guests are viewing this topic.
Quote from: 74 PintoWagon on November 17, 2013, 07:08:08 AM
Grenades are cool, it's different.
I had shell casings on my other cars - just cut down some and epoxied them in. Those kept disappearing, these probably will also...
I'm real close. We had a warm Saturday last week and I took down a lot of the hood that I didn't before. Rust again under those little nicks. I think I'm almost there now, one small thing and the rain gutters (boy am I dreading that! Mask of course cause all the plastic. Hopefully I won't be doing this again LOL
The wheels all painted black. I like the contrast of the rings and hubs on it. Oh, also had to add some anodized aluminum gold granades to the valve stems on the wheels LOL
Quote from: popbumper on November 13, 2013, 07:31:59 PM
I've heard that about makeshift booths - and I'm considering it - but I used to work in a woodshop that had a full size auto updraft paint booth where we painted cabinets. I have asked the owner if I could use it when the time comes....and he has agreed.....so hopefully that will still work out.....
Well, that would also work if you don't have that alternative :)
Quote from: popbumper on November 13, 2013, 07:21:41 PM
I will, thanks for the tip. The Deltron has been real decent for me, but I need to spray in a dust free booth (or find someone to do it cheap). I can paint all day, love doing it, but I don't have the proper facilities.
Deltron is very expensive though and Limco is pretty good from the cars I've seen painted with it, and years later - not like Macco paint.
You can setup a booth like this:
1) Get old sheets at a Goodwill or other thrift store.
2) Clean the heck out of the area you're painting
3) Pin them up in your garage or work space to create the booth
4) Spray water on the floor, ceiling and the walls you made with the sheets
It works pretty darn good. If you do get dust, just sand it down later (enamel in about 6 months) and polish :)
Quote from: popbumper on November 13, 2013, 07:12:52 PM
Well, I want to use the red oxide because it's closer in color to the final coat (easier to cover/hide). When I did the first bodywork I used standard grey. As far as final coat, I chose to use original enamel - I realize that urethanes are superior but I am trying to save some $$ - and it won't be a daily driver - and I am using a urethane hardener in it anyway, so it should be reasonably durable.
Guess that makes sense! Check out Limco paint, I think you might be surprised at the results and the cost. Single stage may only cost you around $160.00 with everything including the harder. The Maverick, got a deal, will have Deltron paint - but only because I got a deal from someone who decided to go with a different color - that stuff is expensive!
So, guess I'll get some red oxide and then resand LOL
Hey pop! Mine is also brown, although you can't tell now with all the primer LOL Would the red oxide in Lacquer be better than doing it with the gray lacquer primer I'm using? I guess the red would match the top coat. I plan on doing a single stage enamel urethane on it, and not the two stage.
The Maverick will be two stage because I bought the paint already and the King in pearl white, and thinking lacquer there also.
So back to the Pinto, are you saying that using the red oxide would be better than the grey?
Thanks!
This is really good stuff Dianne. As you have seen on my restoration (and you know from experience), bodywork is an absolute OCD fest, and it a tedious, tedious time killer. You will think you have something super flat until you throw some nice shiny paint on it. Then, the light catches it a certain way, and OOPS - there are tiny dents you missed in places you'd never guess. I am putting the first coat on the car after all the bodywork JUST to act as the guide for bodywork. I have found a number of missed spots, this paint will be sanded back down with 600 grit, any defects will be repaired with spot putty and a rust oxide primer (the car is brown), and then will be final painted.
Keep up the GREAT work, it's all worth the effort. I can't wait to get mine done too!!
Quote from: dave1987 on November 12, 2013, 09:00:56 PM
Lookin good Dianne! You keep finding things like that you might have to wait until spring to paint the car! ;)
Any progress with the console yet?
You know how I am with the car ;) LOL  I ordered the paint, it doesn't ship for 5 more days. I'm not certain how I can fit it yet. The console in the car now actually comes real close to the shifter. I'm not certain if I can keep the original tray though and may have to cut that out to fit the console. Right now it's above my pay grade so might have someone do it. Found someone to do the seats and he said he can think of something on the console. If I could fit a 78 one in there, it would work. Thinking it through! Then I'm done until Spring after paint to work underneath. Gotta do the Maverick and get it in primer at least.
I just had the back window redone with outthe defroster, it looks good without the lines :-D
Hey no one bought those Pintos yet, just called the guy.
You'll like the detail work. Someone today said it's like 95% of the paintjob, they aren't kidding!
As you think you're closer to paint? You're not. I keep finding more wrong before paint. Maybe I am getting OCD on this, but I do want it perfect as possible. So the trouble with just doing a small dent takes awhile. The car is now at least 70% primer. This was a car that I originally thought would be some minor bodywork and a paint job. Oh well, the devil is in the details as they say.
Quote from: dianne on November 03, 2013, 11:01:33 PM
Mine are pretty dark back there ;)  Are yours done on the rear?
Yes they are.
Quote from: 74 PintoWagon on November 03, 2013, 10:58:30 PM
The driver and passenger door and windshield are the only ones that have a ruling on, the rest can be limo black it don't matter.
Quote from: dianne on November 03, 2013, 08:56:20 PM
I may leave the sides and front alone I guess. I love the back done, changes the look of the car :D
Quote from: 74 PintoWagon on November 03, 2013, 08:35:05 PM
Lot of states are different but AZ goes by a percentage of transparency on the doors and windshield, behind that don't matter, and cops carry a meter with them they'll pull you over if they think you're too dark and check it and they'll give you a ticket if it's too dark... Mine is tinted all the way around the back.
Quote from: dianne on November 03, 2013, 07:22:20 PM
Yeah, we can here, but was thinking about ceramic which lowers heat and isn't that bad :)
Are your backs tinted also?
Oh, the sticker? Just showing my support for POTUS!  ::)
Quote from: 74 PintoWagon on November 03, 2013, 06:49:45 PM
That is looking great, and I love the sticker on the back window,lol..
Oh, and best check with state laws for tint shade on the doors.
Three more pictures of the tint job. Thinking of doing the side windows in a lighter shade or ceramic. Have to get the channels fixed first...
OK, I tinted the windows in my Pinto, wow they look great! This is where the bodywork is right now also, having to finish it and then to paint. Closer, still a tad more to go. I am OCD with it like Dave says LOL
This is Milo with no windows on it, even the rare window is off. The windows are drying overnight and going back in tomorrow. I didn't do the work though - but I think Milo will look HOT!
Dave, no more tarp over the speakers in back :D
Quote from: dave1987 on October 27, 2013, 03:26:06 PM
Pintos are the healthy kind of addiction! :D
I agree. I put the Rambler on Craigslist. I'm keeping the Pinto and Maverick!
Quote from: 74 PintoWagon on October 27, 2013, 08:24:52 AM
LOL, like Dave said I am getting pretty OCD on this wagon. So honestly the other side needs some also so going to work on that side now. I'll post pictures in more detail. Honestly, I didn't know if this was going to work. I'll put them where I placed the others. I just want it as perfect as possible. Now I'm thinking Lacquer cause it shines more, but will probably do a single stage acrylic enamel.
