Front sump oil pan
Date: 01/02/2017 06:54 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 04/27/2018 10:28 pm
Oddsnends
Date: 12/20/2016 10:52 am
  • Online today: 583
  • Guests: 320
  • Total: 320
Metallic Rattling Sound
Started by From_Jonah, August 04, 2013, 10:17:35 PM
pintoguy76
Do you have an AIR pump (smog pump) on your car still? I think they came factory with one. They make noises like that. I chased a similar noise around my F150 with a 5.0 only it made that noise at idle only. I swore it was something in the bottom end of the engine like a loose timing chain slapping the timing cover, but it turned out to be the smog pump.
jeremysdad
Mine makes a 'metallic rattling sound' over bumps. One of the binder clip things on the rear springs (metal band) is loose. It annoys me, but rear springs aren't in the budget atm. lol
krazi
jack and handle in the spare tire area? maybe some wrenches hiding under the seats rattling against each other? I've had both of those problems before.
yeah, I'm Krazi!
krazi
muffler bearings and blinker fluid...
yeah, I'm Krazi!
If the U-joints are original it wouldn't hurt to check them regardless..
From_Jonah
Quote from: beaner on August 11, 2013, 06:44:53 PM
think it can be the alternator bearing going out ?
brad :)
Could be! I'll take a look.
Quote from: Pinturbo75 on August 14, 2013, 06:43:52 PM
how old are the u-joints.....
As far as I know, they're original.
Quote from: 71HANTO on August 06, 2013, 07:12:42 PM... STAND ON EITHER side of the car and NOT IN FRONT! ...
i will second that bit of advice seeing that i have spent time in intensive care after NOT standing to the side !!!
beaner
brad :)
I've had this happen a couple time, similar rattle, depending on speed and torque the rattle would come and go. both times it was the heat shield around the exhaust manifold. The shield rusted around where the bolts hold to the manifold and it rattled. I also recall there is a nut/bolt combo that holds the front/rear shield together at one/two points. Unsure if this could be it but... worth a look.
From_Jonah
Okay awesome. Hopefully and can try that out in the next couple days. In my first post I said that it was doing it when I got it but now that I think about it, I think it started later. I just can't remember when for sure.
Quote from: From_Jonah on August 06, 2013, 06:42:44 PM
Ahhh, okay. I'd not even though of the motor mounts. How would I go about checking the motor mounts? I'd think i could see where they were physically broken.
You can check them with another person. Here is the drill...have someone (you trust) start the car, put it in Drive, WITH THE BRAKES ON including the Emergency brake. Have them slowly rev the engine. STAND ON EITHER side of the car and NOT IN FRONT! The engine will want to twist to one side (can't remember which side). If the mount pulls apart, you have a bad mount.
From_Jonah
Quote from: dga57 on August 04, 2013, 10:19:59 PM
Have you checked your exhaust system to make sure you haven't lost a hanger?
I had a Mustang that had the same sounding issue. Under load the engine would torque over enough that the exhaust pipe would contact a frame rail. A little crowbar messaging fixed the problem. You might also want to check your motor mounts. I have seen where an engine with bad motor mounts torqued over enough that the fan blade contacted the fan shoud.
Yeah, and start looking in an area you'd least think it would come from, probably save a bunch of time, LOL..
From_Jonah
It's always what you never think it would be haha. And yeah. It does sounds like something loos sort. I guess I'll just have to try and go through it and find anything that might be rattling  :P
It's amazing how sound can travel through a vehicle.
HOSS429
the rear seat latch rattles on both my pintos ..  when i first got the 80 pinto one of the first things i did was to fix the drivers sun visor .. the shaft had broken so i JB welded a piece of stud to hold it in place ..  after fixing a few other things so i could drive it some it developed a rattle under the dash i thought .i pulled the glove box .. the radio .. the speaker .. all the heating duct work i could reach .. tightened up the exhaust and fixed every loose thing i could shake .. still had that annoying buzz of a rattle at speed ...  i was about to the point of hiring some kid to find the noise .. i took off down the street one day with the sun glaring in my eyes ... i reach up and swing down the sun visor  ... to my surprise no more rattle ..i cant hear your video here at work .. i`ll play it at home tonite ...
This is going to sound ridiculous, but I experienced a similar sound in my '72 Squire wagon after folding the rear seat down to haul a rear bumper and then putting it back into the upright position.  Even though the latch appeared to be secure, it was allowing enough vibration to create a rattle under certain conditions.  I drove myself crazy looking around on the outside of the car (that's where it sounded like it was coming from) until I stumbled onto it!
Hmmm, didn't sound like pinging at all more like something's loose?, but then again my speakers are getting bad so I could be wrong?..
From_Jonah
Here's the video I made of it. It's kinda faint but I think y'all should be able to hear it well enough to know what I'm talking about.
http://youtu.be/xUitsrlUX2A
From_Jonah
Quote from: krazi on August 05, 2013, 07:47:31 PM
check the fuel tank straps. mine came loose once.
Okay, cool. I'll give it a shot.
krazi
yeah, I'm Krazi!
Quote from: Pinto5.0 on August 05, 2013, 09:04:06 AMI changed the EGR plate gasket to rid myself of the vacuum leak I had but still haven't got the carb dialed in yet.  This thing is driving me up the wall.
If it's identical to the old one and adjusted the same it should just bolt on and go I would think?, maybe something is different inside from the old one??..
Quote from: From_Jonah on August 05, 2013, 09:01:02 AM
OOOOH haha. Mines a manual actually so I guess that's not it. I need to get it up on a lift and see of I can find anything else that could be loose or something.
Well, guess that eliminates that theory then, LOL...
Quote from: 74 PintoWagon on August 05, 2013, 08:38:23 AM
Is the jetting the same as the old carb?, sounds like it could be lean??..
From_Jonah
Quote from: 74 PintoWagon on August 05, 2013, 08:32:19 AM
Ok guess we were, I was talking about the torque converter, LOL..
Quote from: Pinto5.0 on August 05, 2013, 12:52:50 AMI was thinking this as well. Mine started doing it with my new carb & backing the timing down hasn't solved it.
Quote from: tbucketjack on August 05, 2013, 12:44:45 AM
Could this be ignition pinging when under load? Check your timing and put in a little higher octane gas.
Possible, but pinging don't really sound metallic though???.
Quote from: From_Jonah on August 04, 2013, 11:55:36 PM
Maybe we're talking about two different converters  ??? I drilled out the cor of my catalytic converter. It was clogged up.
