Date: 09/01/2017 07:52 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 03/15/2023 02:16 pm
Date: 03/06/2017 01:24 am
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 02/08/2018 02:26 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
  • Online today: 452
  • Guests: 338
  • Total: 338
On To The Ignition!
Started by 74 PintoWagon, June 24, 2013, 10:37:46 PM
Thanks, I'll watch for one of those too.
pintoguy76
89 to 94 on the ranger I believe. Not totally sure tho. I know they had it from 91-93 also but believe they had it a year earlier and a year later also.
Quote from: pintoguy76 on October 15, 2013, 11:33:47 AM
I had to search beyond my city to find it... but it was only an hour away. I went and picked it up the day i found it. Was easy.
Look for a 91-93 mustang 2.3. That's the best engine to use. Its got the alternator on the correct side and everything. The ranger engine has the alternator on the opposite side but it is still usable.
Thanks much, I'll keep an eye out for one. How bout the Ranger same years?..
pintoguy76
Wish I was that lucky, lol..
pintoguy76
I found my engine on craigslist. I decided what I wanted and the first time I looked I found what I wanted.
Quote from: pintoguy76 on October 14, 2013, 11:51:15 PM
I probably have less than $300-ish in my swap. Engine was either $150 or $200 dont remember for sure. Plus $35 for the harness at pick n pull, same for the computer. Needed a few odds n ends but most of everything i needed came with the engine. I even wired in the mustang internally regulated alternator (took two wires to hook up). The engine only took about 3 wires plus some grounds.
As for the exhaust i used the stock mustang manifold. It clears everything just fine. Ranger should work too but I kept everything stock and retained the egr and everything.
Thanks, guess I'll keep an eye open for a wreck/junker, sounds like it would be an easy swap.
pintoguy76
Quote from: 74 PintoWagon on October 14, 2013, 09:41:47 PM
Yeah I know, that is really the way to go and I may change over down the road, gotta get the money tree to grow a bit first though,lol. So, you used a 91 Mustang setup huh, what do you have for an exhaust system?, I know mine is junk manifold is cracked small tubing and crap muffler, I was thinking of a ranger header and 2" back to a Flowmaster, how was the mileage after to converted to EFI?..
Quote from: pintoguy76 on October 14, 2013, 08:06:08 PM
I would just convert to EFI like it did. 91 mustang 2.3 DIS EFI. Youve replied to my thread about it before. I have the same car as you. Its easy to do and you no longer have to worry about setting the timing (no distributor!!) or messing with the adjustments and working out the flat spots in acceleration, etc.  I would gladly help all I could. It is by far the best thing I have ever done to my pinto.
rramjet
Quote from: Pinto5.0 on October 11, 2013, 11:52:33 PM
I have a dial back timing light so checking timing is easy. Set the dial where you want the timing & line the damper mark up to zero. Checking total advance is as easy as revving the engine & turning the dial until the damper reads zero then just read the number off the dial to know total advance.
My wife got me a fancy digital timing light for Xmas last year so it's a little different than just turning the knob. Got buttons to push. Of course I speced this light out for her so I have no one to blame but myself.
pintoguy76
Quote from: Pinto5.0 on October 12, 2013, 08:40:50 AM
I have a good plain light that sits in the drawer. Unless my dial back dies I doubt I'll ever use it again.
I can't get my mileage over 17 even with the NOS carb. I had one tank that gave 21 mpg then back to 16-17 max. It want's to bobble & almost stalls when coming to a stop & run-on is bad. Something isn't right but I don't have time to figure it out. Even though it's NOS & never had gas in it I'm betting a 36 year old gasket or diaphragm gave out someplace. I'm definitely NOT a carb guru. I can tune a good carb pretty well but when the carb acts up I start whizzing in the wind & hoping I stumble on the solution.
I have a standard one too and haven't looked at it in years,lol..
Yeah I know what you mean, most of the time it's just something simple, but being that it sat so long stuff could have dried up and now you develop an internal leak, I've had that happen before and had to rebuild a brand new carb.
Quote from: 74 PintoWagon on October 12, 2013, 07:52:47 AM
All I use is a dial back, wouldn't be without one.
Quote from: Pinto5.0 on October 11, 2013, 09:11:13 PM
My 76 calls for 20 initial & I've revved it with the timing light hooked & got 30 total not under load. I have it at 16 initial now because I can't seem to cure my valve pinging or run on.
Wow 20* initial, guess I been around the big V8's too long, LOL, guess I'll play with timing a bit then, it seems to run decent but it's not that peppy and mileage ain't that good.
Quote from: rramjet on October 11, 2013, 11:02:11 PM
I just reworked the head on mine and it likes I'm guessing about 16 BTD as well. Same place it was before head rework. I need to learn to use the advance function n my timing light so I can see exactly where it is.
rramjet
From AMC49 "When you put ANY carb on, the first thing you ensure is that it gets the idle speed screw preset so that the butterfly or throttle blade is exactly right at the edge of uncovering the transfer holes or slot, so that even five or ten thousandths of movement instantly begins to uncover the slot or holes"
Finally got around to adjusting the carb and this step really does the trick. I set the speed at about 1.5 turns then played with the mixture screw with a vacuum gauge attached. After getting vacuum at it's highest with mixture I actually backed the speed down and vacuum increased which seems counter intuitive but I think it has to do with covering up the Transfer hole and drawing just through the Idle mixture adjustment. After that I did a little more fine tunning with the idle screw.
Sure did smooth out idle and low speed throttle transition as well as overall drivability.
rramjet
Quote from: Pinto5.0 on October 10, 2013, 07:49:28 PM
30 degrees total sounds about right.
Really??? that's all they run for total?, and all I see for initial is 6-8* but this thing needs 16* to get 30*, not that it's bad it still starts with the touch of the key just seems strange. I was thinking 12* initial with 36-38* total all in by 2500 on the centrifical and another 10* on vacuum on the cruise, of course you have to have full manifold vacuum for that. But if 30* is where they run best and get the best mileage guess I won't mess with it then. Thanks for the info..
Hey guys, what do you guys run for an ignition curve on a stock 2.3?, all I can find is initial timing nothing on the total on mechanical and/or vacuum. With this new reman distributor I got all I get is 30* total with the vacuum at 2500rpm with 16* initial, that don't sound right at all to me???..
Yeah, ProStock is a world of it's own, more R&D goes on there than anywhere else. And those carbs are not quite out of the box items either, lol..
Then you know how between MSD and careful carb setup you can get one idling at like 600 rpm just like a stock car, even with .800 lift roller cam and twin 1400 cfm Dominators.....................on the 720CI prostock fatblock Camaro my brother used to drive it sounded ticking over that slow like individual sticks of dynamite going off in the 4 inch collectors, man that thing hurt your ears at IDLE. Even racking engine off dead idle the tach pulled up so quick you couldn't follow it with your eye. 0-9000 rpm instantly, my brother said it was virtually impossible to not overrev engine in every gear and yanking Lenco sticks as fast as he possibly could. Car held world's fastest top speed prostock record in IHRA there for a bit in late '80s, he ran it in Texas Prostock Association heads up match racing. Jerry Haas car. With 3 stage nitrous it ran high sevens at 205+, car still trying to spin tires off track going into fourth gear. I always thought that boy was a bit stupid. He loved it. That car was the last of a string of like five pro cars driven by him, the cars' owner was a guy who started by bringing us 454 dragboats to hop up, he had tons of cash and owned a big string of convenience stores.
Until MSD came along I never dreamed you could get those big muthas to idle that low. So low I used to joke about knocking the cam lobes off simply by how hard the car rocked when every cylinder went off.
No insult taken I know exactly what you mean, just a figure of speech. Done many a tunnelrams over the years and know all about initial setups.
Just cracked can often mean many things. There is actually only one correct place for it. Attention to detail off idle corrects many things, just saying. I never accepted 'just cracked' at all when setting up tunnel ram idles and off idle, you just can't do it because everyone's idea of cracked is different. Meaning I ALWAYS yanked the carbs to see where they were before ever starting to tune.
No insult intended or implied of course.
No choking here, lol, primary and secondary is progressive and no mixture screw on the secondary, secondary plate just has a stop screw and set just cracked, issue is strictly on the primary side, already planned on the wire trick in the jet, been doing that for ages,lol, still need to find a chart though..
You really cannot tell rich/lean by the sound of the miss.
When you put ANY carb on, the first thing you ensure is that it gets the idle speed screw preset so that the butterfly or throttle blade is exactly right at the edge of uncovering the transfer holes or slot, so that even five or ten thousandths of movement instantly begins to uncover the slot or holes. That is the correct dead on idle setting and better than one turn on the screw which if not checked means nothing. With the idle at that point then you have the full range of off idle fuel flow and instantly. If the car does not idle at proper speed then, you have to add airhole to fake motor into thinking blades open further than they are. Having carb preset like that before you bolt it down then helps much to determine what is happening when you roll throttle open, since you already have a known point to start with. If you don't know, then you do not know whether the resultant miss is before you hit transfer or during or even past all of it. In other words doing it definitely the hard way with much more confusion.
Just looked at a cutaway of the idle circuit on a regular 5200, it clearly shows that the mixture set screw sets idle fuel at the curb idle hole only and NOT the transfer slot. The transfer gets the full idle jet fuel, the curb hole lower gets the mixture set fuel, two things to keep sorted out there. If the mixture screw is only one turn out that may well  mean too RICH off idle, the screw is in very far to cut way back meaning a LOT of fuel coming though idle jet. Get somebody to go back at tailpipe and look to see if any black smoke comes out when you slowly roll the throttle on to get into your rough running area. And of course that thinking only valid if you have the starting butterfly position as I just said. If you are into the transfer, then you may be too rich because of that, or lost. You're now adjusting mixture based on incorrect throttle blade position, or wrong.
Proper dead idle is with all idle fuel coming through the curb hole only and none through the transfers. But the transfers should then work instantly as soon as blade gets moved.
Why I use a fitting welded on exhaust somewhere to insert a narrow band O2 sensor, you can tell by the output which way to go. Screw all that guessing.
More. Just where is the idle speed setting for the OTHER barrel? If it even has one. There is usually another idle circuit in the other barrel. If 1/1 ratio and both open together, you may have complicating issues from that side too. The mixture may not be settable there, but the position of the butterfly there could be adding to the problem. Most people never even think about that one. Generally the other barrel sets just like the front, or right at any slight movement the transfer exposes, but just barely covered up at dead idle. The aircrack around the throttle plate then usually will work fine with the 'front' barrel, or the one with the mixture screw. Lots of time the other will be almost shut, which makes you have to open the one causing you trouble more, or the source of your trouble to begin with. Like on a 4 barrel, you want balance, throttle blades almost closed have to open a bit before fuel flows and troubles there. All 4 need to be cracked open a bit already, it establishes initial slight flow so that it does not have to be started up, making off idle smoother. Fuel circuits already in motion can react quicker to changes.
Try getting the idle speed screw deeper to see if you can get the idle speed fast enough to get into your bad running spot. If so, then while it is there then screw your mixture screw SHUT and see if the bad running gets better or worse. That may give you an indicator of which way the idle jet needs to go. I've been known to take extremely small OD pieces of wire and stick them into the idle jet to cut the size of the hole back, I lock the piece of wire in a side airbleed hole to keep it in place. If you know the size of the wire and the size of the idle jet hole, then a little calculating of the two areas and subtract one from the other can tell you what new size jet you need.
Sorry to choke you there..................
Yeah I know, sounds on the lean side though?, thing is I need to find a chart somewhere that lists jet numbers and hole sizes, jets in this carb has no numbers on them so all I can go by is hole sizes, right now I wouldn't know what number jets to get.
Flat spot just off idle can be either rich OR lean......................you get to figure out which.
