  • Online today: 499
  • Guests: 493
  • Total: 493
On To The Ignition!
Started by 74 PintoWagon, June 24, 2013, 10:37:46 PM
Ok, just reset everything, speed screw just under 1 turn and mixture crew 1 turn, idles nice but bring it up gently about 50rpm and it's real rough, about 500rpm more and it smoothens right out, accelerator pump is good can whack the throttle from idle and no stumble.
Hmmm, guess it don't need a module then, that's cool. I can relate to the British jokes too,lol...
I'm pretty sure the speed screw isn't too far in but I'll take another look, in fact I'll just start over and reset the thing it's no big deal..
jeremysdad
It's a conversion, just needs + and - hookups. And Ford Europe took the 2.0 we all know and love, and shrank/expanded it for diff applications. Yes, I spend waaaayyy too much time perusing British car forums (which results in lots of English slang jokes that nobody but me finds funny around the house, but whatever). lol
Try backing your speed screw all the way out (next step easier with a mirror), then turn it in until it just touches the contact pad, then 1 full turn in from there. Set your mixture screw 2 turns out, and play from there, MIXTURE FIRST. I bet your speed screw is too far in, which exposes the off idle enrichment circuit, but at idle. If that makes no change, your idle jet is too big.
Right now the mixture screw is almost one turn out, 1/4 turn each way and rpm drops.
I notice that distributor only has 2 wires coming out of it instead of 3 like the Dura-Spark?, something else strange looking at the application chart, it shows it fits 1.3 to 3.0 engines?.
jeremysdad
How many turns in/out is your mixture screw? Lean off idle could be caused by having the speed screw adjusted in too far to compensate for a too small idle jet.
I've been doing some research this morning, and I believe the electronic distributors I've been looking at from the UK are actually just converted via a Pertronix style kit, not actual stock Dura-Spark style electronic. Converted to USD, they are appx $120, which gives you a brand new distributor with the conversion kit, (appears new rotor and cap included). At this point, I would just buy the Pertronix kit for $75, since my distributor is a fresh reman. (D'oh!)
Link to eBay part: http://www.ebay.co.uk/itm/Powerspark-Electronic-Distributor-Ford-Escort-Capri-Cortina-Transit-Pinto-Blocks-/121032996459
Get one now if you want one, the conversion for Great British Pound to USD is .2 lower than when I bought my cam last year, and looks like it's going back up again. D'oh! again. lol :)
Well, took the car out yesterday and put about 50mi on it, new ignition is awesome thing starts with just a touch of the key no cranking at all, starter should last forever, lol. New cooling system is working good and no leaks, gotta put a gauge on it though don't seem like it's getting too warm going by how much heat coming out of the heater. Carb has some issues though, it's way too fat and mileage ain't too good and it has a lean condition just off idle, but I know the idle jets are wrong just by the adjustment of the air mixture screw, I just wish I knew what this carb came off of and what it supposed to have for jets can't tell if anyone messed with it before?, worst part is there is no markings on the main or idle jets never seen that before?, only ones that have numbers on are the air bleeds, so this ought to be fun figuring this out, lol. But before I get into that I need to put valve seals on I don't think there's any left and the way it is you can't really read the plugs. I'm also looking at another wagon supposedly converted to a "Cruiser" for myself.
I was kinda wondering if there was a magnetic pickup out there that could be made to fit, gotta be other small type distributors out there with magnetic pickups I would think???..
Been using Accel for over 30yrs never had one failure yet, pretty good stuff I would say.
It would not be hard to put a magnetic pickup in the 2.0 if the distributor wasn't so dang small in OD, no room inside. I bet a stepper could do it though. I took Mopar early electronic innards and put them in an AMC distributor back in the mid '70s as electronic for AMC was unobtanium. Used an Accel competition dual point distributor with points removed and had to cut the point cam down to press the reluctor on, and used an Accel Supercoil. That was one hot ignition brother.
Got a Ford Duraspark distributor for AMC V-8 if I ever build another engine.
Oh I'm sure they are, I'm still thinking about it, lol..
jeremysdad
They're awesome motors, don't get me wrong. Just have a few more challenges that the 2.3 doesn't have. :)
Wow it does look different, never got into these motors before(I'm an FE guy,lol)I thought the only difference was bore and stroke, learn something new every day. That's good to know, I'm looking at another one now and it has a 2.0, I may just pass on it now..
jeremysdad
A 2.3 distributor won't fit a 2.0???.. ??? ???
jeremysdad
This thread makes me jealous of the 2.3 guys. :) lol I think when I get to that modification, I'll go Pertronix. Seems like it's cheaper than the Dura-Spark upgrade for us 2.0 fellas, since we have to source our distributors from the UK.
Most definitely, and since the box isn't flat I put some on the back side of the plate on the ribs also. Guess I'll take it for a ride today and see how everything works.
It's kinda hard to beat an HEI..
Surely you put heat transfer compound on the back of the module right? You better have.
I actually put two of those on an inline four motorcycle many years ago and they worked great.
Well, got a chance to work on the car a bit, got my ignition built and mounted and a reman Dura-Spark distributor and coil, fired instantly and it was night and day to the points, idles nice and I could actually adjust the carb some, lol. So now that it's all together it's time to drive it and see what the next step will be.
Well, doing some thinking I decided I want to keep things looking factory but yet I've always liked the reliability of an HEI, so I'm just gonna pick up a later distributor and try and find a junk box to put the module in. Thanks for all the ideas guys.. 8)
Quote from: TIGGER on June 25, 2013, 05:50:12 PM
I have run a Pertronix unit in my 67 mustang for about 19 years now and have had no issues with it.  It has never let me down.
That's what I'm looking for, since my distributor is in good shape I may go this route.. Thanks...
Quote from: 72pair on June 25, 2013, 02:29:56 PM
Seen a lot of dirt racers run a stock Ford distributor with a GM HEI module tacked on the side. Seems to work good. i've used a MSD 6AL with both a stock and a billet dist. Couldn't tell any difference really. My 2.0 has an old Mallory YL with a Mallory E-spark conversion. I really like this one. Cranks great, runs clean. Actually had engine start once just by turning ignition on!
Thanks, HEI module sounds like a good deal, I did see an article somewhere about that a while back, someone used an old Duraspark box and gutted it and used it for the HEI module good way to hide the module I guess, would have to get a later electronic distributor for that to work though but it would be cool to keep it looking factory..
72pair
Thanks, not really a fan of MSD though, sure wish there was enough room I'd just put an HEI in and forget about it..
I have an MSD-6A & billet distributor for my sons '80 but it's not cheap. I spent close to $200 for used ones but wiring is simple.
Duhh, never thought about Duraspark, thanks Jerry I'll look into that..
Jerry merrill
The Ford Duraspark works great and is pretty cheap all you need is a75 and up distributor, ignition box, also cheap and a wiring diagram which I got off of Racer Walsh website or several other sources. Not too hard to install.
Well, since I had to order the water pump I thought I'd look at the ignition and a few tests shows it's all junk and it's a wonder it even ran at all, so I'm thinking of ditching the points did a search here and all I can find is old threads on electronic ignition(maybe I searched wrong)and what I read on Pertronix not sure I want to go that route or not?, since it's the wife's car and she'll be driving it to work(graveyard)all the time last thing I want is a call saying the car died and she's sitting on the side of the road in the middle of the night, so I was wondering what you guys all run that's been the most reliable?, I was looking at this deal from Pertronix and wondered if they improved over the years and was worth using??.. Any comments, recommendations appreciated.. Thanks guys...
http://www.ebay.com/itm/Ignitor-Electronic-Ignition-Module-Coil-for-Ford-2300cc-Motorcraft-Distributor-/330616645310?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1974|Make%3AFord|Model%3APinto&hash=item4cfa49a6be&vxp=mtr
