Brake rotors
Date: 03/24/2017 09:02 pm
Date: 06/28/2019 09:14 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 03/14/2020 01:52 pm
Date: 03/07/2017 07:03 pm
Date: 02/27/2017 10:10 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 12/09/2018 11:35 pm
  • Online today: 489
  • Guests: 210
  • Total: 210
Radiator Question!
Started by 74 PintoWagon, June 12, 2013, 11:38:34 AM
Kinda what I was thinking..
Quote from: 74 PintoWagon on July 25, 2013, 08:40:11 AM
That makes sense definitely don't want any air pockets, I take it the top hose goes to the pump then.
That's a good question. I would assume so since the lower hose on the radiator is the return to the pump & the water then goes into the block passages 1st.
You want the flow going in the lower inlet & out the top to avoid air pockets in the core
Ok, got the heater box all cleaned up and back together and ready to go back in just need the hoses, measured the top hole in the firewall and 3/4 hose will fit so I'll go that route with an adapter, now the question is which goes where?, I've looked at pics and I see some with the top hose going to the pump and bottom to the intake and vice versa, but now that it all ends up being 5/8 anyhow I was wondering if it makes any difference which way they're routed, just want to route them to get the most heat??, what you guys think??..
Thanks guys, I have seen universal hose with 5/8 to 3/4 before I'll see if I can find some local, if not I'll just go the adapter route I could make one if I had to. Just don't make sense why there isn't 3/4 on both ends??, but heater hose on the inside of the firewall don't make much sense either, lol..
sedandelivery
When I put my heater back in, I used regular hose and bought an adapter  that allowed me to put the 2 hose sizes together, using hose clamps.
nnn0wqk
If memory serves me Ford actually used a 3/4 to 5/8 hose on that heater fitting. Never made much since to me either. Kind of like putting the hose connections on the passenger side of the fire wall!! Not one of Fords better ideas. Try Napa or some of the other chain stores and see what they might have. Or get an adapter and a small lenght of 3/4 hose and go to 5/8. I looked on Ebay and they have a molded hose with those sizes up that is not quite what you want.
Ok now that the radiator issue has been fixed it's back to the heater box, cleaned it all up and made my heater core gaskets today and it's ready to put back together... But something puzzles me, the old core and the new one both have 3/4" top and 5/8" bottom hose fittings, but the pump fitting, the choke manifold and the intake fitting are all 5/8",  and the old core had 5/8" hoses someone forced 5/8" hose on the 3/4" fitting?, what's up with this?, do I have the wrong heater core?, searched all over and all have the same core with 3/4 top and 5/8 bottom. It's just not making any sense to me I am totally cornfused, what am I missing here???... And looking at Joe's setup he has the same size hoses on both too???
Thanks for the heads up, I'm saving that number.
I made a couple calls & apparently the warehouse is temporarily out of stock which is why the order wont go through. How long before they have stock or if they will re-stock nobody knows but the new part number will be B426 if it ever hits the warehouse.
waldo786
I did see those, but they are $201.XX.  Quite a big difference from the $115 shipped somebody else mentioned, so I'll wait and see if autozone gets more in.  RockAuto has a Pro Rad/APDI one on there for $176, but that's still a big difference.  I do at least have a 5% off coupon for there, but it doesn't take off that much.
Well that's good, almost tempted to get another one for a spare just in case..
They are still on Ebay under part# CU426 so it could be that AutoZone's warehouse is out. Hopefully they will stock them again.
Wow glad I got mine when I did, somebody has to have them somewhere though I would think..
waldo786
I'm going to go to the store tomorrow and ask them about it.  Maybe they have one somewhere.  It sucks because my hatchback has what seems to be a very new radiator, it's just not the heavy duty one for A/C, which I plan on installing in my car.  I have the old A/C one from my grandfather's car, maybe I should just use it?  Do radiators go bad?  There seems to be a bit of gunk inside, but I do know they make cleaners.
Quote from: waldo786 on July 21, 2013, 07:58:17 PM
My grandfather's '76 wagon had a 5 blade fan on it that came with with factory A/C.  I do have a bit of bad news though - this was such a great thread and I was going to order a new radiator, but autozone doesn't seem to have these anymore.  When I go to checkout it says the requested quantity is not available.  :(  They have have a 20% off deal going too and they are far cheaper than anywhere else I've come across.  Grrrr...
Holy cow, I tried it too. We bought the last of them
waldo786
Done, rad out soldered back in and no leaks, in less than an hour, try that with one of these new cars, LOL... Heater box is next..
Yeah it does, but story of my life if there's a bad one in the pile guess who gets it, I always tell them at the counter want to weed out the junk just sell me something, lol... :D
Well, while I waited for the heater core to get here I got tied up in other stuff but yesterday decided to service the tranny and change the oil in the motor, while under the car I noticed coolant on the ground, come to find out the lower radiator hose outlet has a pin hole where it was brazed on, so I guess today's project is pulling the "new" radiator and fix the leak, was hoping to get the heater box all back together and back in the car, oh well....
Well, unfortunately I was quite older at the time,LOL, but it still escapes me on it. But you're probably right about failure and mass complaints seen that before on different things.
nnn0wqk
I was only 17-18 at the time so memory may be a little dim. I would guess there was so much out cry over the whole thing that they backed off. They to this day still have the warning system it is just now you can start the car even if you not buckled in. I suppose the failure rate could have been high enough that it became a saftey issue not being able to get the thing to start too? Who knows. Its like the unleaded fuel sticker you still find at the gas cap. When was the last time you found gas with lead in it? Most of these laws once they are on the book they never get changed. In this case something must have happened to get them to back off. Maybe someone with a better memory of those times will jump in here with an idea or two.
Federal huh don't remember that one??, interesting why it was only one year though wonder what happened?..
nnn0wqk
Well keep in mind this was a federal mandate system. All the car companies had it. I remember JC Whitney selling just a tongue to bypass the system I believe on GM cars it was suppose to be for people to use that parked lots of cars? I never did disconnect mine and it still functions. Guess that got me into the habit of wearing the belt.
One year only kinda tells ya something, wonder how many got stranded because of that that system..
My orange '74 Runabout was all of three months old the first (and only) time there was a malfunction of the seatbelt/starter interlock.  I consulted the owners manual, pushed the little red button under the hood, and all was well.  My dad took it back to the dealership while I was at school a few days later for its first oil change and had them disconnect that nonsense while he was there.  He did not tell me at the time, so thinking the system was still active, I continued to buckle up... a habit that has stuck with me from that time on!  I discovered the "modification" about a year later when my girlfriend got in and started it without buckling the seatbelt!  As nnn0wqk pointed out, it was a one-year-only thing; 1974.
Well, got the heater box out and all apart today, just have to clean it out and take out about 5lbs of crud,LOL, got to get a core and make a couple of gaskets and put er back together..
That had to zoop, glad mine's not hooked up or it would have to come off real quick..
