Date: 11/05/2020 06:32 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 10/05/2017 02:26 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 09/01/2017 07:52 am
Date: 08/01/2018 01:27 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 03/13/2021 12:57 pm
Date: 12/20/2016 10:47 pm
  • Online today: 403
  • Guests: 158
  • Total: 158
Radiator Question!
Started by 74 PintoWagon, June 12, 2013, 11:38:34 AM
The pinto radiator came in two sizes.  17" and 20".  '74 and up could use both.  To install the 20" in my '73 I had to cut, move and weld in the drivers side radiator edge support. I overlapped the metal to increase strength. It took time to think out, but overall it was pretty straight forward.
Jerry merrill
I just put in a new radiator in my 71 with a 2.3. I got it from Oriellys. The application was a 76 2.3 with air. The lower passenger side outlet is curved over to the passenger side somewhat so I had to shorten the hose for this same application. Not enough room for a fan blade so I mounted a small electric fan on the front side of radiator. I dont even have to turn on the fan most of the time. Works great.
Art come on over to Pinto World and I could show you the difference in radiators your only 1 mile from me. Also we have another newbe name John who has a yellow 73 wagon and 2 V-8 Mustang 2 he lives next to water tanks on river about 2 blocks from you. And yea the 115 temp does zoop !    Fred   ;D 8)
Quote from: jeremysdad on June 12, 2013, 12:29:01 PM
Hoses are in the same locations. :)
That's good to know. I just ordered one for my '73 since I'm gonna put the 2.0 back in temporarily so I can drive it. $115 shipped with the discount is too cheap to pass up.
BTW  74 PintoWagon, the new rad, thermostat & water pump dropped my temps from 205 in summer down to 175 degrees & in winter I can barely get it above 155 degrees. That's with a tiny 12" flex fan. I had a 15" fan on it & couldn't get over 130 in winter so I swapped fans to stop cooling it down. The bigger fan in summer would keep it below 170 but I may go electric this year so I can get heat next winter instead of just warm air.
chrisf1219
when i first got my pinto it use to spit out antifreeze when ever i stopped,what a mess,plus it ran a little on the hot side.installed the radiator list above plus went to 5 bladed fan from mustang 2, coolest theroslat at autozone and istalled a radiator overfill tank.car runs great in all kinds of weather even 105 we had up here in turlock last weekend while in car cruise/show. cooler it runs the better.  chris
jeremysdad
http://www.autozone.com/autozone/parts/Radiator/_/N-8ii30?filterByKeyWord=cu426&fromString=search&isSearchByPartNumber=true
This is the one I put in my wagon last fall. It's for A/C cars so it's wider than stock but bolts to factory bolt holes.  Mine has a 2.3L but I'm not sure if the hoses are on the same sides if you have a 2.0L.
If you order online there is a 20% discount at checkout for promo code DAD20 which probably expires after fathers day. Hope this helps.
Hey guys, pulled the radiator out and noticed the extension on the left and the support is open all the way, looks like a bigger radiator was available for this car, is this true or am I dreaming??, I searched all over but can't find anything than what I have, only engine options I could find were only a 2.0 and 2.3, was there anything else?, now if there is no option for a bigger radiator is there one that would bolt in without modifications??(don't want to be drilling holes all over the place)figure it wouldn't hurt to have a little more capacity with our 115* summer temps.. Thanks for any info guys..
