  • Online today: 533
  • Guests: 346
  • Total: 346
Radiator Question!
Started by 74 PintoWagon, June 12, 2013, 11:38:34 AM
Chrysler tried that stupidity as well. Only problem was the system was garbage & 6 months after you bought your car it refused to start, belt or no belt.
Quote from: nnn0wqk on July 10, 2013, 01:02:22 AM
I believe that is the box for the seat belt interlock system that was only used on 1974 year model cars. In 74 only you could not start the car unless the seat belt for the driver was fastened and passenger if there was one. This was for the front seats only. There was a switch (push button) under the hoad on left fender side that you could push for a one time start. There was a pressure switch under the seat cushions to tell the box that the seat was occupied and if I recall correctly as you pulled the belt out it closed a switch to tell the box that the belt was fastened. Most were wired around many years ago as the motoring public did not like big brother telling them that they had to fasten the seat belt before they could start the car.
Wow never knew that, so I take it this is the push button switch you're talking about??, was wondering about that one too since nothing happens when you push it, makes sense now though guess it's been deactivated because you can just reach in and start it don't have to sit in the seat.. Thanks for the info much appreciated..
nnn0wqk
Quote from: Pinto5.0 on July 03, 2013, 07:46:00 AM
That's a complex POS for an early Pinto. I wonder if it worked longer than 5 minutes....
That's funny, LOL... ;D ;D
Quote from: Ricpinto on July 03, 2013, 07:37:09 AM
Going by the base number-14A554- Ford calls it - ACTUATOR (seat belt & ignition warning system)   Before 1/75
Interesting, wonder what kind of warning you get for a point ignition??..
Don't think so there's nothing to make sound it's just a little circuit board??, and there's two small ones there one for the door and seat belts according to the manual..
289Wagon
It is a dealer installed unit, what a pain getting it out I sure wouldn't want to be the installer,lol. It is a standard heater box with parts missing, they didn't use the left vent duct to register a hose from the AC went there, also the right vent is not there there's a plate covering the hole, the AC unit fits up to the register, also they added a register in the dash next to the heater controls so I now have hole there, but that's ok because it's a perfect place for oil and water gauges and I can eliminate the idiot lights. Now all I need to do is find the missing vent parts and glove box and I'll be all set, next step replace the heater core.
Now, does anybody know what this is for?, I looked at the wiring diagrams and it's not there, the box was attached to a metal bracket and was hanging with one screw in the middle and didn't look like it belonged there beside the AC unit??..
This is what the plug looks like and it's part of the factory harness.
chrisf1219
havent looked at mine but maybe you have a dealer installed ac?i have a dealer installed ac all contols are indepentant of reg  heater controls. good luck chris
Looking at the manual it looks like it from what can be seen?, got a couple of errands to do this morning hope to get it out  by this afternoon I'll take some pics. It is a totally independent system though, has it's own control panel separate from the factory heater controls, and there's nothing in the manual about it either so it ought to be fun trying to figure how it's mounted in there..
Looks completely different than mine.
I wonder if that's a standard heater box once the A/C unit is out of the way?
Well, had some old wires and a coil laying around and it worked fired right up. New water pump, T-stat housing and T-stat and no leaks, ran it for an hour and never went over 180*, I think I'm good to go on this deal.. Now onto the next project, since the heater hoses were whacked off I figured it had to be because the heater core is bad, sure as heck looked inside and you can see a trace of dry liquid at the bottom of the heater box and I can see why it never got fixed, before you can get to the heater box this dealer add on A/C unit has to come out, oh what fun this ought to be a riot,LOL, we'll see what happens tomorrow...
You're right, checked the manual and it shows a press in barb..
Got it all back together yesterday and went to fire it up and no spark, some testing shows a bad coil also the water pump started leaking, weird how it all happens while just sitting there,lol. Think I'll look into losing the points at the same time too, haven't mess with points in ages, LOL...
Judging by the screw in fuel filter in your pic that's a late carb. The earlier ones had a hose barb to connect the fuel line instead of a filter. I think the screw in filter started in '75
Well, here's mine looks identical, looks like the water manifold isn't part of the rebuild, gonna try it without water and see what happens..
Thanks for the link, it says 75-76 should fit 74 no problem, looks identical to mine without the water passage though, I'll have to take it off again and check I may be able to just eliminate it on mine, or maybe just replace the choke assembly??.. Thanks again..
Thanks I'll look into those... 8)
I think late '76 or early '77 the MII & Pintos started getting electric chokes.
Quote from: Pinto5.0 on June 19, 2013, 10:00:39 PM
Around town mileage is 14 with that car. Highway barely breaks 17 so yeah, that puppy isn't right. My timing belt was 3 teeth off when I got this car too. It ran ok but wouldn't go over 65 mph. Even with the bad carb this car starts easy cold & lights off instantly when warm. My only complaint is mileage but that's a biggie since I know it should do way better.
I don't think you would have any issue bypassing the water choke. See how it goes. You can always swap on a later 5200 with electric choke
I had mine up to 75 and seemed to run ok, of course retarding the cam gives more top end but 10* YIKES, it sure wasn't a ball of fire on the bottom end though, LOL, don't know if it's the quality of the belt but the closest I could get it is 4* advance, but that's ok it just gives more bottom end and if the belt stretches it'll just get closer to straight up..
Yeah, I can't see can't issues with bypassing it, but I just wonder if the intake needs heat to run good?, I know Chevy IL6's do but  I'm gonna try it and see what happens...  So the later 5200's don't have the water passage huh, think I will look into that, thanks for the heads up..
Quote from: Reeves1 on June 20, 2013, 06:03:38 AM
Took the AC unit out of my 72. If you want I'll have it cleaned & pressure tested ?
Problem with that, as already said, a NOS one can be had for cheap.
I picked up a NOS one with the seals for 60 bucks, for the standard heater I'm going to be using.
and yes.......the AC unit is a pain to take out !
Yeah, I'm not looking forward to that, been kinda been leaving it for last, LOL...
Quote from: Pinto5.0 on June 19, 2013, 04:05:06 PM
The simplest swap would be a 350 Holley with electric choke. I have 2 new ones but the tranny kickdown is the reason I wont run one. I'm not in the mood to cobble together something that may not work correctly & could cause the trans to burn up. Ford & Chrysler wont tolerate an out of adjustment kickdown for long.
The stock carb also delivers a few extra mpg over the Holley & I'm trying to get the wagon up to 25 mpg rather than the 17 it's getting on the 37 year old carb. I put a kit in it but it runs exactly the same as before so I give up. This is the smoothest running 2.3 I've ever had. The timing is dead on, new cap, rotor, wires & plugs so that just leaves the carb as the cause of the crappy mpg.
Yeah, the Holley is about as simple as simple can get to tune, but not good for mileage with the big primaries you'd be better off with a Q-Jet with the small primaries, kickdown is nothing to adjust and simple to hook up if the carb is sideways.
Must be something wrong with the carb if you're only getting 17mpg, mine was totally jacked up when I picked it up and got over 20mpg with it, first thing I did when I got it home was check the timing belt, somebody put a new one on and the cam was 10* retarted no wonder I got black smoke when I nailed the throttle. But I was thinking where I'm at I can get by without a choke not that big of a deal, if this carb(5200)can give good mileage(it is a new one) I may just eliminate the choke and just run a hose from the pump to the heater and back to the T-stat housing, it should circulate and give heat I would think..
The bad gas probably contributes to it but I have a dead spot in the carb under load just past 1/4 throttle & until 3/4 throttle I get no acceleration. The quickie rebuild didn't help it at all.
I've seen posts with similar symptoms & in the cases where an NOS or Autozone rebuild was installed the drivability & mileage went up drastically. Since this engine only has 60K original miles & the oil barely gets dirty between oil changes I think it's worth splurging on a carb at some point.
jeremysdad
Could be the alcohol-gas we're forced to run. I know mine runs better on straight gas...costs a pretty penny, and it's hard to find, but totally worth it. :)
