Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 08/17/2022 06:27 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 03/21/2017 07:47 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 08/01/2018 01:27 pm
  • Online today: 628
  • Guests: 332
  • Total: 332
The Restoration Of my 1977 V-6 Pinto Crusing Wagon
Started by DBSS1234, May 07, 2013, 02:48:33 PM
dianne
Just beautiful! I can't say enough about how good that looks!
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
DBSS1234
Rear axle housing is installed along with a pair of NOS Motorcraft shocks. Tomorrow I will install the axles and the rear brake components. I painted the brake backing plates today and they need over night to dry. The red you see on the carrier is Ditzler DP-74 epoxy primer used to duplicate the red oxide the factory used. On removable carrier axles Ford dipped the castings in red oxide primer before machining them. That is why you see the bright "silver" spots on the casting, this is where the casting was machined so there would be bare metal in this area. I painted these areas with a natural metal paint to duplicate this look but the paint won't rust. The ID tag I plated with zinc to avoid rust. The pinion nut and the carrier retaining nut are replated with a zinc dichromate finish.
DBSS1234
The only way to get the surface pitting perfect is to fill the pits with filler, sand, fill, sand, prime, sand, prime, sand and paint. I was going to wait and show the rear axle from start to finish but since you asked here it is in process. As for the ride, new ball joints, bushings, and rubber isolators should make it ride as new. Remember this isn't a Lincoln, so the ride will never be like new cars.
dianne
Sanding with 80 grit and spending some time with it might do it. Or an orbital sander with 40 grit and smooth with 80 with a vibrating sander and then 200. That would provide that new look I think. Yours look good. Mine are minor surface rust only, so a light sanding and paint would do most of it. I don't know if that would only be cosmetic or show or if it makes for a new ride drive. I'd be happy with a perfect ride. I'd like to know how the new springs did. I compensated with air shocks and it didn't make a difference.
His is too perfect LOL, actually looks fake it's so good!
Vehicles:
Alpine615
I hope this isn't a stupid question, but how did you deal with the pitting on some of those parts?  When I restored my suspension, I did not have a compressor, so I had to pay to have them blasted.  They looked great, except all the parts looked like they had a texture to them.  Yours look, as dianne said, brand new...here's a pic of my pitted parts:
1980 Runabout
dianne
Your work looks so perfect it's almost like someone photoshopped it for a magazine.
Vehicles:
dianne
Quote from: DBSS1234 on November 07, 2013, 09:19:31 PM
Front springs are original, sandblasted and refinished. The rear springs are new, one of the old ones had the top leaf completely broken in two. I hung the rear springs up to paint tonight, I should have them painted and installed by the end of the weekend.
When you're finished, how close to new do you think the ride will feel? I have some squeaks in the wagon, is taking it apart like you are the only way to fix it, or can you clean, scrape, replace any bad gaskets, bolts that are rusted, and so on. Paint also I guess if you want it to look decent. Is what you're doing the only way to get a new ride feel again?
Vehicles:
DBSS1234
dianne
Dang, that looks better than new!
That's pretty awesome actually! I don't know if I can do that, but I would like to try with the Mustang. Are you getting new springs?
Vehicles:
DBSS1234
Finally bolting more restored parts on the Pinto. This time it is the rack and pinion steering gear assembly.
dianne
Vehicles:
Alpine615
1980 Runabout
DBSS1234
Front suspension and brakes are done! Here are a few before and after pictures. I look them and can't quite believe it, and I did it! ???
dianne
Just wants to get me there on my wagon! Thanks for posting that, it was awesome!
Vehicles:
DBSS1234
Thanks Dianne. As soon as I get the rear axle and front brake parts restored and mounted I will post picutres of them also.
dianne
Vehicles:
DBSS1234
I am finally getting to bolt some parts back onto the car! This is the restored front suspension. All replaced parts are NOS except for the LH upper "A" frame which has an after market ball joint (you can tell by the bolts holding it on instead of the stock rivets). I just couldn't find a nice NOS one. :(
DBSS1234
Continuing with the restore the parts and reassemble the car approach here are some of the restored parts (front sway bar and front lower "A" frame struts). The three yellow stripes were faint but visable on the sway bar so I repainted them after refinishing the bar. Looking at the build sheet I found in the car it shows "Y" for the sway bar (Yellow). It would have sucked to be color blind and work on the assembly line at Ford! :)
DBSS1234
Thanks to everybody for all the kind compliments! I am taking a few days off to go to Rainy Lake on the Minnesota/Canada border and do a little fall fishing. Weather looks bleak to say the least, but as they say a poor day fishing is still better than a good day at work!
Walleye and Northern Pike beware, I am on my way! ;D
dianne
Vehicles:
DBSS1234
Been working every night on the restoration and I am making pretty fair progress. Engine bay is painted. On disassambly I noticed that the motor mount brackets, battery tray, hood hinges, and hood bumpers were installed before paint................so that is what I did also. I also included a picture of the replated hood latch along with the replated zinc dichromate (zinc and yellow) bolts.
DBSS1234
My wife said that also. She also mentioned I am most likely on some FBI watch list due to my buying a small scale, small measuring beaker, various chemicals, and the power supply all off Ebay. :o
jeremysdad
My wife said 'Don't burn the house down, and don't make it look like a meth lab.'
DON'T CROSS THE WRONG WIRES! Also, capacitors gonna burn you. Don't touch those, either. :) lol
Beyond that, it's a bunch of wires hooked to metallic objects simmering in a salt-solution on the kitchen table. How could it not look like a meth lab??? lol
