  • Online today: 628
  • Guests: 354
  • Total: 354
The Restoration Of my 1977 V-6 Pinto Crusing Wagon
Started by DBSS1234, May 07, 2013, 02:48:33 PM
DBSS1234
Thanks Cookie. I still plan on having it at Apple Valley for the all ford show in June. Might bring the 77 Cobra also, that way I would have a pair of 77's to show. ;D
I can't wait to see this when done, unbelievable the details and quality... I've seen the stangs, and i know the quality you are capable of...
DBSS1234
Back from a business trip/trade show so I can work on the Pinto again! First picture is of the Steering column and wheel installed. The rest are of the air cleaner. I had a rubber stamp made to redo the part number stamp on the air cleaner snorkle. If any one restoring a 1977 V-6 Pinto out there would like to have the correct stamped number on the snorkle let me know. 1978 Pintos may be the same but I don't know for sure.
DBSS1234
Pinto_one:
I will check diameter of the pulley tonight.
P.S. Ye,p I have to original window sticker. Plan is to get a good color copy of it made and display the car with the copy in the side window. /this will save the original from all the wear and tear plus the sun fading.
Every time you post new photos I got to say wow, this is beyond Restoration . hope you got the dealer sticker to put on the window because its going to look better than new,  but also notice that you car does not have A/C , and been trying to find out the water pump pulley diameter , have two almost tore apart pintos and got the pulleys mixed up, one is smaller than the other , one pinto did not come with a/c and the one I am almost finished with does, also been thinking of making a two grove pulley because the belt broke and ran hot and cracked both heads , this set up always ate belts , also yours does not have the big alt , both of mine do, along with the big 5 blade flex fan from the factory , so if you have time can you let me know what diameter you have , thanks Blaine   (in hot butt Missisippi
bbobcat75
BAG VS BOTTLE MAY HAVE BEEN A PLANT THING TOO BOTH MY BOBCATS WHERE MADE IN THE SAME PLANT SO MAYBE THAT IS THE REASON TOO OR LIKE YOU SAID RAN OUT OF BOTTLES AND INSTALLED BAGS TO KEEP THE FLOW GOING!!
TAKE CARE
1975 mercury bobcat 2.8 auto
DBSS1234
Quote from: bbobcat75 on January 14, 2014, 06:37:44 AM
dale looks great!!! as far as the washer bottle/reservoir my 75 bobcat hatch back with factory 2.8 has a plastic one just like my 78 wagon with a 2.3 have a super nice one from a 80 if needed!!
take care and great work will be doing that to my 75 in about 20 years when it needs it and I need a project!!
Thanks for the kind complements. As for the bag vs bottle thing, I have owned this car since new and it came with the bag. I actually ordered it late in 1976 and it was built in March of 1977. Maybe it was an early build thing that got changed over later, or maybe they just ran out of bottles and used this to keep the line going? All I know is replacement bags are nonexistent but luckily mine is in good shape! If anybody out there has a good bag I would be interested in buying a spare!
bbobcat75
Dale! Received the wire loom Friday. Looks great. Its got me all fired up to work on my Pinto (as soon as it warms up). Your car looks great. Its almost will be a shame to drive it (ALMOST). Keep up the good work. Sent you a letter today. Thanks again.~~~Dick
Alpine615
Loving the progress!  She looks beautiful - keep up the good work! :)
1980 Runabout
DBSS1234
Moving from front to back, the dash is in! For those of you with a black interior a perfect match for the factory semi flat black is SEM 39144 trim paint, it also comes in spray cans for those without a gun and an air compressor. The first picture is before the dash was installed and the second is after.........duh! ;)
Ignore the toy tractor sitting on the cowl, it is actually sitting on a saw horse in front of the car. I am restoring it for a friends new grandson.
Quote from: DBSS1234 on December 27, 2013, 01:13:51 PM
Engine bay is ready for the completed engine/transmission assembly. Hope to get the transmission back from the shop next week (had a little problem with the reassembly and called in the reinforcements). If anyone needs some of the wire loom covering I have plenty and will sell you enough to redo your car cheap. I had to buy the stuff in 100' rolls so I have alot left over. I have 3/4" ID, 1/2" ID and 1/4" ID but no extra clips or connectors as I reused my old ones. Let me know if interested.
How much a foot for 1/2 & 3/4 loom covering? Thanks
DBSS1234
I did it! I successfully stuffed 10 pounds of stuff into a 5 pound pail!! I got the transmission back Saturday and Sunday I installed the engine transmission assembly into the car.
Transmission bolted to engine.
Blankets padding the engine bay to avoid paint damage.
At this point I almost thought it was going to be impossible!
S-L-O-W-L-Y
It's in! ;D
DBSS1234
Was the washer reservoir bag an option on some models? My 77 sedan had the standard plastic washer reservoir.
[/quote]
I believe it was just the medthod they used with a V-6 in 1977. There isn't mush room with a V-6 and power steering in that area.
Wow you've done some really nice work!
Beautiful work there.
DBSS1234
thanks but already got the engine done , done a few mods , took the 2.9 crank out of my wifes dead bronco II , machined the nose to take the gear (never liked chains) and installed it with a comp two cam, headers and TBI fuel injection ( see ranger site for the 2.8 conversion ) and a remote oil filter ( got tired of oil running down my arm every time I pulled the filter ) and last a A4LD automatic overdrive , get rid of the buzz at hwy speeds, but yours will look like a factory new car, nice
I must say you do very nice work.  This car is going to be amazing when it is done.
DBSS1234
Quote from: pinto_one on December 05, 2013, 09:17:55 AM
very nice job there , doing my 76 V-6 right now ,  have a 79 V-6 Crusing wagon also that is on the waiting list, guess your going for the all orginal look with the smog pump and egr valve , and the valve cover stickers, I know that someone makes the 2.8 decal for the air cleaner top,  keep up the good work
If you need any engine parts let me know. To restore mine I scavenged 3 parts engines and have parts left over.
DBSS1234
Engine is finished, now if it runs half as good as it looks I should be in fine shape. ;)
Transmission is next!
:D
Scott Hamilton
DBSS1234
Quote from: mrskydog on November 12, 2013, 10:27:44 AM
HATS OFF!! what a nice job on this car ,it will look better than new after you finish it. Wow  8)
That's the plan!  ;)
mrskydog
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
DBSS1234
Axles installed and brakes done, almost a shame to cover it up with the drum. Next the motor! :)
