Date: 03/06/2019 06:40 pm
Date: 09/17/2024 12:35 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 08/09/2018 07:49 am
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
  • Online today: 628
  • Guests: 550
  • Total: 550
The Restoration Of my 1977 V-6 Pinto Crusing Wagon
Started by DBSS1234, May 07, 2013, 02:48:33 PM
Quote from: DBSS1234 on April 16, 2014, 07:39:54 AM
IT'S ALIVE!!!!!! Fired up the motor last night for the first time since the rebuild. Last time I had heard it run was in 1992. Runs very nice but still needs a little fine tuning to be perfect. After watching all these auto restoration shows where there is always some major leak or other problem at first fire up it is nice to say "no leaks and the transmission is shifting fine". It is nice to have things go right once in awhile. :)
Always good to hear of a successful resurrection, The Holy Horses of our Olympic corral are pleased, Always ready with the feeler gauges...
Pintosopher, confidant to the Trek we all must engage! ;)
bbobcat75
GREAT TO HEAR AND CONGRATS!!!   MOST OF THOSE TV SHOWS ARE A JOKE! A LOT OF WACK AND PACK - MAKE IT LOOK GOOD FOR TV!!
YOURS IS A TRUE RESTORATION WITH QUALITY WORK AND PARTS!! THE WAY IT SHOULD BE!!!
HOPE TO DO THAT TO MY 75 BOBCAT IN 35 YEARS WHEN IM RETIRED AND NEED A PROJECT!! TILL THEN JUST GOING TO CRUISE!!
1975 mercury bobcat 2.8 auto
DBSS1234
I like the milk jug washer idea. I always used good masking tape to protect fresh paint but that seems faster.
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
bbobcat75
DBSS1234
Finished painting the inside edges of the fenders and under the hood. Then I spent a little over 4 hours last night getting the doors, fenders and hood installed and the gaps as close to perfect as "Pintoly" possible. Ended up looking pretty darn good if I say so myself.
A little tip for anybody doing this, you will notice the thin plastic washers under the fender to body bolts. I made these from an old milk jug and use them to avoid damaging the paint when adjusting the fender into position. After everything looks good remove one bolt at a time, remove the washer, then reinstall the bolt.
DBSS1234
Unpainted parts are either blasted and clear coated or painted with a natural metal type of paint. I use a lot of Eastwood spray grey and detail grey. I buy it in the quart cans if available and use a touchup gun to spray it.
Super fine details on your restoration !
Better than new !
Q: the un-painted parts under the dash etc. Are you blasting/painting them ? I've been doing so with mine. Not worried about what was factory though. Just wanted no rust.
If I was doing one like you , I'd clear coat to preserve the bare metal look.
DBSS1234
Fuel tank is cleaned, detailed, and installed with new filller neck seal and a NOS fuel pick-up/level sender. Tank was very nice on the inside so all I did was tape off the openings, lightly sand blast, epoxy prime, and paint it with Eastwood tank-tone silver. I could see the remains of the USS stamp on the tank so I replicated it for that finishing touch. :D
DBSS1234
Finished installing a new interior for a customer in a Ford Model A 5 window so I am back onto my Pinto. Finished cleaning and polishing the wheel tire assemblies. I also installed a NOS set of center caps for that final touch! Before everybody asks where I found raised white letter 13" tires let me say they are old (second set ever on bought for this car) I figure I bought them about 1982 or so, still have about 80% tread! These are going to be my "show" tires for limited trips locally only. I also have another set of slotted wheels (though not as nice as these) that I plan on mounting new black wall tires on for longer trips.
Also got the front and rear bumpers polished and reassembled.
bbobcat75
DBSS1234
Color could be changed on the pink one but the part number on the bottom starts with D7 with decodes to 1977. The door jamb decal should be the same unless I am mistaken.
bbobcat75
man wish I could use both of those on my 75 v6 bobcat!! the one looks the same but the pink one is neon green on my 75
can the color be changed??
thanks
eric
DBSS1234
Got another decal remade. This time it is the vehicle emission control information decal found under the hood on our cars. This will be correct for all 1977 V-6 equipped cars. If anybody out there needs one I made extra and will sell them again for $7.00 including the postage to send one out.
DBSS1234
Latest update on the progress of the restoration. Inside of the doors and the jamb area of the doors have been painted along with the inner workings (door latches and window regulators) getting cleaned, lubed and reinstalled (I even decided to use the correct rivets to reinstall the window regulator). I know I must be excessive compulsive!  :P
The seats and interior door panels cleaned up VERY nicely and look almost new!
Lastly I got the door frame tire size and air pressure decal reproduced. These should be correct for all Pintos 1975 thru 1978. If anyone needs one I had extra made and will let them go for $7.00 each including the postage.
mrskydog
Awsome Restoration on your Cruzing Wagon! I really would like to have one someday as nice as yours. I think they are so 70's ..Cool!!
Keep up the good work, I would love to see it someday.
Kirk  ;)
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
dianne
Vehicles:
DBSS1234
Another example of how quality was NOT job 1 at Ford in 1977. I was cleaning the inside of the doors after sandblasting and found these slugs in the doors. They evidently were left in the door after the hole for the stereo speaker wires were drilled. Not wonder my car had rattles I couldn't find! :P
dennisofaz
DBSS1234
Anyone following this restoration thread knows I am kind of a stickler for originality in my restorations. Along this line, I have never liked the look of modern sealed battries in old cars. It just doesn't look right.
To fix this problem I made a cover for the modern battery. First I got lucky and found an old Motorcraft vented type battery and cut the top off of it, enlarged the post holes, and repainted it with plastic paint. Then I went shopping for a battery that had the right dimensions and post spacing. That was the hard part but my local O'Reilly had one that worked. Here are pictures of my new battery with an old battery cover.
The modern battery installed, it just doesn't look at home in there does it?
Much better. The only give away is the height of the posts in the cable clamps! ;D
bbobcat75
when can I send my 75 bobcat over for the same treatment!!
looks great!
makes me want to do it today!! but don't have the time right now!! but retirement might be my time to do it!!!
later
DBSS1234
FINALLY got my brake booster back from the rebuilders so the engine compartment is done! I thought new cars have crowded engine compartments, this thing is busy under the hood and it doesn't even have A/C! Also my wife and I installed the windshield with a new gasket. The project is really starting to look like a car again.
bbobcat75
man this wagon is going to be built nicer and better then day 1!!!  great build keep up the great work!!  love all the detail work!!
DBSS1234
Making more progress, headliner is now installed! First picture is of the roof insulation and the second is of the headliner thru the windshield opening. Next is the windshield installation.
Quote from: DBSS1234 on January 30, 2014, 01:30:53 PM
Thanks Cookie. I still plan on having it at Apple Valley for the all ford show in June. Might bring the 77 Cobra also, that way I would have a pair of 77's to show. ;D
Hot Dig-A-Dee!! I know where I'm gonna be in June = APPLE VALLEY!
