Pinto Watch
Date: 06/22/2019 07:12 pm
KYB shocks
Date: 02/08/2017 07:09 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 09/02/2021 08:21 am
Date: 10/11/2019 11:13 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
  • Online today: 587
  • Guests: 216
  • Total: 216
Another '74 Bites The Dust?
Started by blupinto, January 09, 2013, 08:19:37 PM
I'm with  johnbigman2011. it sounds like more junk got sucked into the line. Out of curiosity have you changed the fuel filter?  Didn't know if you mentioned it or not.
johnbigman2011
I'm leaning toward fuel issues Becky. Try the jug of gas again.
lol well the coil  (the old one) had oil coming out of it. That HAD to be replaced.  ;)
I had taken the old line off the fuel pump and got a gallon of gas and she ran on that til she ran the can dry! I hooked the new line to the gas supply line and started her up. She started without a hitch and idled for several minutes. I'm having a vehicle crisis here as I have now 5 cars and none I can take to work tomorrow.  >:(   I rolled the blue Squire out of the driveway, put her in 1st gear and somehow let her stall. Now I can't start her again and even with starting fluid she won't start. I spent two days working on the ignition and now I'm very frustrated.  >:( >:( >:(
I covered fuel, spark & timing so I can't claim clairvoyance lol  ;)
Hmmmm....... well....
The new points didn't work, and I ended up reinstalling her old distributor innards to get spark. The new coil stays. Those of you all who said it was likely a fuel starvation issue were pretty right on the mark. Wait til you see what came out of the fuel line when I removed it from the fuel pump... (picture to come)  :o
This sounds oh, so similar to the issue I had in 2006 with my 77 Pinto. Turns out the carb was full of junk from the tank & needed cleaned out. That could possibly explain the starvation you seem to be experiencing
Yesterday was a banner day for me, mechanic-wise. With the help of a dear friend who's on this site I learned how to adjust points and look for spark. To normal gearheads this is child's play, but no one ever taught me how to do that. Reading a manual doesn't always work.  I am kind of proud of myself.
Ok enough about me. So far these are the things replaced since Moxie crapped out on me a couple weeks ago:
Spark plugs
Spark plug wires
Coil
Fuel Filter
Points
Condenser
Distributor cap
Rotor
With my friend's help via telephone, I learned how to hook up a remote starter button so I can check spark and see if rotor works as well as other stuff.  At one point I wasable to get Moxie started and running at idle for a few minutes. I played with the throttle linkage a couple times too. Only when I got in the car and pressed the accelerator did she falter and stall, reluctant to stat again. We got her running twice, but pressing the accelerator pedal killed her twice. Today, with Rich's help, I am going to try an idea of his... a gallon of fresh gas to the carburetor via the fuel pump.  I still have 3/4 of a tank of gas in  that car. Now I'm wondering if it's a throttle issue because she quit after I pressed the accelerator down a little (to the point of the engine slowly racing).  This is also basically what I did when she faltered and died.  Maybe fuel pump failure.  :-\
78txpony
It should have little deflection when  depressed with a light finger.  With some effort on that finger you might have about 1/4" movement.  You should try to see if the timing marks all line up.  But first, you should confirm IF you are getting a spark from the coil.
Do not attempt to tighten that belt until you confirm if you can get a spark or not.  Otherwise you will be wasting time, as you will need to remove the belt enough to get it back into time.
Quote from: blupinto on January 13, 2013, 08:23:10 PM
the belt on this car looks and feels fairly new. With my fingers I can pull on it and to me it feels a tad stretched. Here's the question: How do I determine the right tension or tightness on the belt? I know where the belt tensioner is, but what point can I tighten it and call it good? I don't know if it's a cheapy belt, but I wouldn't be too surprised if it was.
-Rob Young
1997 H-D Sportster
ToniJ1960
 this site shows a picture of a brake booster and its location. Its really close to the one in a pinto even the elbow piece the hose connects to it looks so close youll know it right away.
ToniJ1960
Quote from: blupinto on January 13, 2013, 09:37:08 PM
Thank you, Toni yes it's a points car. I will enlist my mechanic neighbor to help me on this. First I'll pull the distributor cap and see what I can see (if there's anything I can see). I can understand water getting to the carb from the gas tank- I think that's why she's surged in the past- more so when the gas tank is less than half- full.
I'm not sure what the brake booster hose looks like. :-[
If your car has power brakes that hose is easy to find look for the brake booster and youll see a good  sized hose plugged into it. You can get a fitting for a vacuum gauge thats cone  shaped ( I think my vacuum gauge came with a bunch of fittings and it was only $12)and plugs right into the hose once you pull it off the elbow that goes into the booster. Or else you can sometimes find a hose coming from the intake you can hijack to test the vacuum. Cranking vacuum will be a lot lower than normal engine vacuum but I think 6 or 7 inches of vacuum should should be about r ight.
I didn't realize you had points. This could be as simple as the condenser failing. It's on the outside of the distributor. Quick fix & only a few bucks.
ToniJ1960
 Im wondering if some water gut into the carb passages if theres water in the tank. But I think the first thing is to check for spark, get someone o help you I guess Im always afraid of doing that too. I read on electronic ignition cars you shouldnt but I think yours is apoints car isnt it?
Checking at the coil would tell you if the spark is there but I think it would be better to check at a couple of spark plug wires. Then y ou know the distributor is turning and everything there is good if more than one sparks. The next thing I would do then is hook up a vacuum gauge to the intake manifold vacuum (pull of the brake booster hose if it has power brakes and connect to it) check the cranking vacuum.
Then the next thing may be to pull out a plug and see if theres any fuel smell in the cylinder after you crank it a bit. I never tried this but if its impractical I guess someone will let me know.
Thank you Matty (and your Dad) and Rob! I'm not brave enough to do the spark thing yet, but here's a question: the belt on this car looks and feels fairly new. With my fingers I can pull on it and to me it feels a tad stretched. Here's the question: How do I determine the right tension or tightness on the belt? I know where the belt tensioner is, but what point can I tighten it and call it good? I don't know if it's a cheapy belt, but I wouldn't be too surprised if it was.
78txpony
Was the timing belt tight?  I once had a cheapie on mine which stretched and it jumped a tooth or so, just enough for it to die, but still show spark, fuel, and compression.  Ironically that happened on 2-29-2000...
Also on my car I can pull the coil wire off, crank it and a spark will leap from the tower to the fender - easily seen from the drivers seat.  Of course mine has the higher output ignition system, but it could work on yours. Or pop the coil wire from the disty and place it near a metal bolt or such where you can see it.
You are pretty certain you have fuel, now you need to confirm you have spark.
Hope you get it running soon!
-Rob Young
1997 H-D Sportster
Thank my Dad..  :D  He thought of it from his days of fixing the Pintos my Mom owned & then the family wagon lol. Prolly also good to look at the cam timing since it could have skipped a few teeth & is now out of time.
I haven't yet. That's my next idea. I can't remember what I'm looking for timing-wise, though... and I'm not feeling well physically this whole weekend. I have a four-day weekend coming up next weekend so I'll hopefully be feeling better and can actually think.  Thank you for bringing it up.  :)
Dunno if you said u did or not but have u pulled the distributor & checked it?
Replaced spark plugs and wires (plugs have proper gap) but she's still not starting.  :(
I'm glad it's warmed up a bit in the buckeye state. Nice & warm at 60 today.
No... I need another person to assist me in that.  Maybe tomorrow I can wrangle my mechanic neighbor to help.  ;)
My fingers did thaw... but the sun's down again, and they're getting stiff again.  :o
johnbigman2011
Becky, did you check for spark like pinto 5.0 said. Check your distributor cap as well.
Sounds like your not getting any spark??
Glad to hear your fingers thawed out too :D
Ok so far this is what I've found:
I took that belt cover thingy (yes that's the technical term! lol) off so I can get a decent look at the belt and teeth. The belt looks and feels fairly new. No cracks, no dry rubber look... and all the teeth are present and accounted for. I tightened the alternator belt so I can move the belt (thank you HOSS429 for that suggestion). I don't know if I should breathe a sigh of relief or not yet... taking off that cover reminded me of taking all that stuff off my Runabout Wildfire (nightmares to come) to replace her timing belt (good times).  I went ahead and replaced the fuel filter and verified that fuel is coming to the carburetor and  made sure the spark plug wires were connected to whatever they're supposed to be connected to... she still won't start.  :-\
I have spark plug wires, spark plugs, and fuel line (as well as a new timing belt I may or may not need) on order from O'Reilly's.  I did notice, while the cover was off, that the pointers and such to synchronize the timing are different on this car as opposed to the other 2.3 car I have.  I couldn't do the air compressor thing because I don't have a compressor. I do know I'm getting fuel to the carb, though, so there's something else here...
OK you got me there.. 20s & 30s is cold. I won't even work on my car in that temp..  ;)
In the 20s and 30s. It's supposed to get that cold tonight. Right now I think, with wind-chill factor it's in the 40s and YES THAT'S COLD! No bellyaching about us Californians who don't REALLY know what cold is!  If my fingers are numb it's COLD... or my carpal tunnel acting up. In this case it's cold.  ;D
Yes we have snow in our mountains as low as 2000 ft (unusual).  We had a cold snap in 2007 that devastated a lot of crops out here... in the millions of dollars.  A lot of avocado and citrus farmers were devastated too.  It doesn't usually get this cold but in parts of San Diego it even snowed briefly! Now THAT'S RARE! lol Where was the snow when I was a kid!?
Don't want it now. The way people drive out here, if there was a little ice on the roads the freeway system would shut down due to all the knuckleheads who can barely drive on sunny dry days now driving on snow or ice. YIKES!!! :o
Ok for now I'm off my soap box. I already miss driving the wagon... she has so much torque even in 4th gear! I have to be patent... but I will keep y'all posted with updates as they happen! ;D
Quote from: blupinto on January 10, 2013, 07:31:15 PM
lol John I've been digging out drains and chopping out fountain grass and other crap all day. I'm plumb tuckered out tonight, not to mention ice cold. My fingers are numb.  :)
What is your definition of cold?
johnbigman2011
I didn't think that it ever got cold in Cali.. Maybe the mountains??
johnbigman2011
Becky, get you a sweat shirt and a light and get after it... I want to hear what is wrong with her.
Well, so far I've tried the fan blade test. THe fan turns, sure enough... but nothing else does. The alternator belt seems fairly tight, but that wasn't moving, either.  :-\ Now it's too dark and cold (we're in for a cold snap as bad as in '07 here) so I'll tighten alt. belt and then see what happens.  Saturday, if fair weather holds out, I'll do the other stuff. Good news is I do have a fuel filter waiting in the wings for her. I just haven't had a chance to replace her old one. It's the one that screws into the carburetor itself.
