Date: 07/03/2025 04:35 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
postal pinto
Date: 06/03/2020 09:31 am
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 08/01/2018 01:27 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 02/25/2017 08:45 pm
  • Online today: 500
  • Guests: 313
  • Total: 313
Another '74 Bites The Dust?
Started by blupinto, January 09, 2013, 08:19:37 PM
Good point. Had that happen on my 85 Omni. Engine wouldn't turn & the belt looked good. turned out the belt had no teeth at the cam gear
HOSS429
pull the emergency brake .. put the car in neutral gear .. open the hood .. put on a glove .. grab the fan blade and try to turn the engine with it .. watch and see if the timing belt/cam gear  moves with it .. belts strip teeth as often as they break ... if the engine wont turn with the fan blade then the alternator  belt is too loose ...
I just remembered, check the timing belt 1st because the fuel pump runs off that belt. I can't believe I forgot that......
If its the fuel line you can also remove the line from the tank at the mechanical pump and compress it with air to Blow the plug back into the tank. More then likely sounds like your Timing belt.. Check it and make sure there are no missing teeth. Im hoping that its a Fuel Issue as thats much easier to deal with. Good luck
Yeah, the engine cut out between gears so it just didn't mesh since RPM's dropped.
The vacuum lines would cause stalling or rough idle but you said it wont fire. If it comes to life with starting fluid then it's a fuel problem. If that's the case then pull the fuel line at the carb & crank the engine to see of it pumps fuel through the line. If it does & there is a fuel filter screwed into the carb just change it, hook up the fuel line & see if it starts.
If no fuel comes out of the line & there is an inline filter try removing that & cranking it to check for fuel flow. If you get flow just replace that filter & then try starting it. If you get nothing then it could be a bad fuel pump, clogged fuel line or the sock in the tank could be plugged with crud.
If it doesn't fire on starting fluid then you need to check for spark.
lol AM skeered!
I wouldn't be surprised if something got stuck between the gas tank and the filter. When I bought this car, the gas cap was gone and there had been rain. Who knows how long the car sat with old/crappy gas too. I've filled the tank at least three times and as I get towards the last quarter tank before fill-up the car will have moments of surging and sometimes even backfiring.  Still, why wouldn't the car go into 2nd gear before it stalled? Does it have to do with synchronization of engine RPMs to tranny position? I'm hoping whatever it is one of your suggestions will be right on. I looked at the vacuum lines for a minute before I was compelled to get back in the car (she stalled in a bad area where there was no shoulder and only one lane. We were straddling the sidewalk) but I didn't see any lines missing connectors. Now that she's safe in the driveway I'll try to have an extended look-see. It probably won't be til Saturday (hopefully it won't be raining) but my fingers are crossed! Thank you all for the responses.  :)
RSM
Quote from: Pinturbo75 on January 09, 2013, 09:27:53 PM
or a stripped dizzy gear.....
I wasn't ready to frighten her with stuff like that just yet lol. Or wiring issues......
Best to check the simple things first  ;)
ToniJ1960
Quote from: Pinto5.0 on January 09, 2013, 08:41:25 PM
Since the engine died & wont start that rules out the trans & clutch. That narrows it to fuel, spark or timing.
Spray a little starting fluid in the carb & crank it to see if it's fuel. If it doesn't fire pull a plug wire, insert a screwdriver at the plug end & crank it while holding the screwdriver 1/2" from any metal & check for spark. It has to be narrowed down to go further.
Or maybe a vacuum hose came loose somewhere?
ToniJ1960
 I remember a few years ago I came up to a stop put the clutch in and my motor just stopped dead as if someone turned the key off and it wouyldnt start again. It was the timing belt broken. So I would think its not the tinming belt if you looked and its not broken especially.Min e was easy to see it was obviously broken.
Maybe the first thing to do is pull off the gas hose at the carb stick it in a jar turn the engine over for a second or two maybe three and see if theres any gas in the jar. After that maybe try to get a look at the cap and points? I never had to bother with then on my two 74s and one 75 I had, but I didnt have them for real long. I would imagine if anything changed about the points you might be able to see it. The capacitor you wont but it shouldnt take much to replace it for a try.
Just dying like that could be a plugged fuel filter, bad fuel pump, ignition box, distributor module, timing belt or bad cap/rotor if it's apart failure.
RSM
My money is on the timing belt. Sounds like it's due for replacement. How many miles are on the car Becky?
cutelitlputtputt
Becky, I died like this on the freeway during rush hour back in March.  Wore my battery out trying to start it.  A cop had to push me off the freeway!!
There was something with the carburetor.  Also my catalytic converter was clogged up real bad because of my old engine.  It is like the car could not breathe or something!!!!
Anything to keep her runnin'!
I already have a '74 whose problems confounded me so that I buried her in my garage. Now my wagon Moxie is doing something similar. Alas, I have no more garage space, so I have to deal with her!
          She's been running great ever since I bought her in October. I changed her oil and filter last weekend and replaced her broken sway bar link. Today, on my way home, I stopped at one of the many red lights I encounter on this route. When the light turned green I proceeded in 1st gear. When I depressed the clutch, shifted into 2nd, and released the clutch the car didn't respond. The engine didn't revv like I was still in neutral. In fact it kinda made an unhappy rumbling noise and was fixing to stall. I was able to limp the car to the side in a rather dangerous area (no choice) and as soon as we came to a stop she died. I was unable to start the engine after that, and had to call AAA to get us out of our hairy situation and to home.
         I got a glimpse of the timing belt- it's not broken from what I could see. The spark plug wires are old, but none were loose or off. Does this sound like a timing issue, a transmission issue, or an engine issue? There was no leaks, smoke, or funny smells when this happened or after. The car is a Squire wagon with a 2.3 and 4-speed. I appreciate any help or advice I can get.
