1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Date: 01/28/2019 05:15 pm
Date: 02/18/2017 05:55 pm
Date: 04/21/2017 02:03 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 02/21/2022 11:11 pm
Date: 11/11/2019 04:49 pm
  • Online today: 238
  • Guests: 204
  • Total: 204
help please ignition cylinder
Started by tonij1960, November 26, 2012, 10:33:17 PM
earthquake
You could try a pair of channel locks to force it back to acc position.It worked for me,once.If not I have a 78 column black refurbished bare $40.00
ToniJ1960
 I kind of know that feeling I had this one for nearly 27 years and bought my first one (a 1974 wagon) in 1980. I forgot how I did some tings and not in a real big hurry to try again after all those years especially.
On my 74 wagonm a friend I had let drive it pulled out the key with pliers, I guess he didnt rdive a lot of cars and didnt realize there was a button you had to push. The key had marks from the pliers and the whole cylinder just turned and turned. They got it out with a slide hammer, but looking at the pictures in the thread and in my chiltons, I believe the older ones had a different cylinder without the pin that we were talking about. And for whatever reason after drilling and grinding down that pin it still wont come out.
maphoone
I saw this and had to say something,this happened to me some / many years ago and I called a locksmith I don't remember how but he explained how to pull the ignition switch out  and also had another one or re built it .
I think it was under 30$  all I remember is the keys were not the same as the door any more
I have had 4 Pintos and worked on them all my self , its surprising what I don't remember ... ??? or maybe I don't want to.
I think it should bolt in but the wiring is probably going to be different.
ToniJ1960
 ok the lights  are on it was a bad contact on the fuse from a dirty fuse clip. On the input side where the wire from the light switch comes from. Only had 12v on one side of the fuse I first thought ok a bad fuse, but as I was starting to pull it out the lights came on.No contact from the metal clip to the metal on  the fuse to carry 12v through the fuse to the lights. Contact cleaner and putting the fuse in and out a few times, now I have my IP lights back.
ToniJ1960
 Well so far no one has said wil the 73 one work or not. Anyone know?
Also now that I drove it the steering wheel makes a clack sound when I turn it to the right and back to the left. Small wiggling back and forth I dont hear feel the clunk type noise or feeling you get from bad tie rods. Its a louder clack type sound and vibration on the wheel itself. I onder if we messed up the bearings in it, or if its because we didnt get the wheel back on straight at all (going to take it off and put it back on tomorrow. Check the  wheels yourself, to someone else they might look straight I guess, have to remember that next time).
And no lights on the instrument panel. Going to check the fuse and maybe I should check the connector on the ignition switch after getting my hand in there to see if it was loose. Can someone tell me if the if the dome light is the same as a courtesy light? I know Im going to feel stupid about asking this later. But the fuse for the ip lighting gets fed from the same power source off the ignition switch as the `courtesy lights` and the dome light works. So if  the dome light=courtesy light the feed from the ignition switch for the ip lights should be ok too.
no sure. im sure the pinto goo roos on here will know!!! any help will be great!!! thanks guys!!
ToniJ1960
if you need a colum i have one i just pulled out of a 73 wagon, let me know if you would like to purchase!
good luck
eric
ToniJ1960
Quote from: Ricpinto on December 06, 2012, 12:27:34 PM
Like I said I prefer to disconnect the upper u-joint. Because of it's simple double 'D' design (to me) it makes it much easier to re-index things and
the column is much shorter & you don't have the shaft flopping all over the place. However it's your car, so do it how you wish.
Be on the lookout for a PM.
Thanks for helping its been so long since I changed the rag joint. I cant even remember if it was ths one or the 79 I had.
I did tonight finally take desperate measures and saw the rod so I can get it o start.Im going to do some shopping tomorrow finally cant get much food home on the bus.
289Wagon
ToniJ1960
 Im seriously thinking thats what Im going to wind up doing. Do you disconnect it at the rag joint or at the input shaft of the rack? I remember changing a rag joint one time I dont remember having anyone helping me but I may have it had to be over 12 years ago.
For now Im thinking of cutting the rod that goes from the cylinder to the switch and see if I can work it by hand. Its drastic and maybe the final straw on the back of using this column,but maybe I can at least drive it for a while to get my groceries :)
I just spent about an hour with the wiring diagram I dont know why they make them so hard to read but finally started coming together, just have a major headache now.
289Wagon
 With all the trouble you're having it would be easier to just replace the entire steering column. If I recall there are two wiring connectors, four nuts
or maybe two nuts & two bolts and disconnect the upper u-joint. You will need someone to help guide the joint on when putting in the replacement column.
Just a thought.
Can't believe the slide hammer won't pull it out, the steel pin is what gives the most resistance. the end of the cylinder does go through a slotted washer, most of the time the end of the cylinder will break off, sometimes the washer breaks as well. I've pulled literally 100's out with a slide hammer. ( I work at a Ford dealer) I never drill them. In fact today I pulled one out of an '02 crown vic. 3 wacks with the slide hammer. Gone in 60 seconds!
ToniJ1960
 Theres something going on in there. The pin is gone its clear and the cylinder wont come out still. It looks like there may not be a washer but a metal wall or something in the end of the housing that could have that same T sort of shape in it that means the cylinder does have to be turned. So now I have to try to drill out the tumblers and get it to turn to the run position.I can get the cylinder to move forward nearly a quarter inch and see in there a little. If I had a small saw blade that could get in there and cut that end of the lock cylinder off I could try that.
ToniJ1960
Quote from: Bipper on December 02, 2012, 12:15:23 AM
Yes that way will work also. But it is very difficult but not impossible to know when the tumbler is in the right position after it's chewed up. But if you think you're close and the pin won't push in you could try and pound the pin in with a punch. The reason it won't slide out with just the pin pushed in is the end of the tumbler is sort of shaped like a "T". That T goes through the drive gear washer that has a matching T shaped hole in the center. Therefore to remove or install the tumbler these T shapes have to line up. If my memory serves me I think that is in the run position. Hope that makes sense.
You might also want to see if someone has posted a video on youtube about removing a Ford ignition tumbler.
Bob in Socal
I really hope this is wrong and its not the drive end of the cylinder still keeping it from coming out now that the pin is drilled ( but maybe not still completely)
The main reasons I think it is wrong are as follows
1. a regular washer with a round hole would sem to work as well. Why spend extra to make a special part that isnt needed?
2. it would probably be a little harder to put together if the washer had to be turned a certain way for them (washer and gear) to align. Again uneccesary so why.
3. even if the cylinder turned if the washer turned you still wouldnt be able to pull the t shaped end out of washer if it had that shape opening, if the washer was able to turn also once the t end went through and into the gear. And if the washer wasnt able to turn against the gear and forced to stay in alignment with the gear, then it wouldnt matter as far as removing the cylinder because the t shape openings would be lined up no matter if the cylinder is in the off run start position.
Does this actually make sense? If this was something to with electronic engineering I feel on steadier ground.
ToniJ1960
 I have got the pin drilled away but it must be some little bumps still that wont let it come out. We used a slide hammer (window down door open) and no luck. I guess I need a small grinder to get it flush. The holes a little bigger that it was  so the cylinder might wind up being a little loose in there but I dont care right now. It could probably be shimmed or something. Im just so close I can feel it bit still cant drive my car its my only vehicle too. I just dont need two cars to try to keep going though.
So I have a small sharp flat blade I may try to plow some of the bits off or down with. And try to find out where to get some small small grinding bits for a dremel locally. Harbor freight home depot anyone know?
ToniJ1960
 That pin isnt budging what I wonder is wil it break off. Maybe if I drill along the half side of it and make i thinner it wil break off.
Hammer & punch. Drive it in as far as it will go then slide hammer.
ToniJ1960
 The pin wont go in because the cylinder wont turn looking at the new one you can see theres no way the pin can go in. Will it break off?
Yep thats how I pull cylinders out of everything. Since you have started drilling the pin go ahead and drive it up into the cyl then wack it with the slide hammer. Should pop right out.
ToniJ1960
 can you break the cylinder out with a slide hammer even if you cant get the pin in?
Wow you guys go about this the hard way!! I slide hammer them all the time. Get someone to hold the steering wheel from the driver side and 3-4 wacks out it comes. Make sure you have the pass door open and the window down lol! Also, you can use a pin punch and drive the steel pin up into the cylinder. DON'T drill down into the cylinder!! When that bit hits that steel pin the drill will twist and try to break your arm!
ToniJ1960
 I started drilling the pin. I just didnt realize I drilled half the pin and half the hole. So now Im taking a break before I destroy it. Its probably going to be more difficult to drill it outnow so I may have to try to drill it along the side of the half of pin thats there. If I damage that hole too much I wonder if I can put a sleeve in it.
The lock block came out so I put a good washer behind it pretty thick it shouldnt bend or wear out so now my steering wheel wont look. Tempted to zip tie the push rod to the column and s aw it to get the car started more than ever. I think ill sleep on it and maybe my brain will be fresh or less stirred up tomorrow.
Bipper
This might be of some help. http://www.youtube.com/watch?v=DFZeb5KFpUw Same basic design as a pinto. The reason his tumbler came right out was he was able to turn the key to the run position just not the start position.
Bob in Socal
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
Like Bipper I can't recall either since I replaced the ignition on my 77 in 2006 before Carlisle after I lost the keys. From what I recall once I got the pin out I was able to remove the cylinder with no problem. I can't say for certain since it was so long ago but that's what I'm thinking.
Bipper
Quote from: tonij1960 on December 01, 2012, 11:17:01 PM
  From what I read you drill through with the 3/8 to get the tumblers to all fall out then it can turn and you can press the pin in.
Bob in Socal
71 Sedan, stock
72 Pangra
ToniJ1960
Quote from: Bipper on December 01, 2012, 09:52:46 PM
I have run into this problem many times at FEDEX when we used Ford vans. From my experience the key tumbler just wore out from age. Has never been the ignition switch, rod or lock gear mechanism. To remove a tumbler that won't turn disconnect battery, remove steering wheel, disconnect turn signal switch at connecter under dash, remove turn switch screws and lift switch out of the way. You don't have to take it all the way out just out of the way for access to the pin. Do yourself a favor and center punch the pin, then drill it out. Then drill into the keyway of the tumbler with a 3/8 bit. You want to drill until the tumbler pins fall out. Don't drill deeper than the length of a key or you will be drilling into the washer and drive gear. If it won't come out step drill above the 3/8 size. It's been many years since I have done one of these so I don't remember what size I ended up with but with some prying and wiggling the tumbler will slide out. Good luck.
Bob in Socal
I got the steering wheel off and trying to figure out how to get my dril at that angle maybe I need a different tool.Im using a dremel, I guess I just need to round up some extension cords so I can run a good drill out there.
My main question to you is, if I drill that retaining pin out why would I still need to drill through the cylinder with the 3.8 bit? It seems like it would come out without turning it once the pin is out. From what I read you drill through with the 3/8 to get the tumblers to all fall out then it can turn and you can press the pin in.
So why both?
Also I was able to get my hand back on top of the columb and feel the switch part and the wires.It doesnt feel like anything is loose there.'
The lock button to lock the steering wheel pushes in easily, but after I took the screw out for the block it wont come out of the housing.
Bipper
Bob in Socal
71 Sedan, stock
72 Pangra
Ok, I've been trying to think of other things to try, before you saw thru that rod, try this, with the steering wheel off, put the key in and give this thing a few raps with the hammer, don't unleash all your fury, just tap it good while you try to turn the key. Also one more question, did the button on the bottom side of the column pop back out after you took the key out last time? Or did it stick in? Anyway, by tapping it here, you're basically 'helping' that potmetal doohickey toward the electrical part, same motion as when you turn the key onward, on the electrical part in is on and out is off.
Once again wishing you luck and fortune :)
