71 72 front bumper brackets
Date: 06/10/2020 10:55 am
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 12/09/2018 11:35 pm
Date: 09/26/2019 05:31 pm
Date: 02/16/2019 10:46 am
74 pinto
Date: 09/11/2016 06:32 pm
Date: 07/01/2019 12:23 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 02/28/2024 02:07 pm
  • Online today: 498
help please ignition cylinder
Started by tonij1960, November 26, 2012, 10:33:17 PM
Isn't the steering wheel locked as well?
ToniJ1960
 Well I got the plastic collar out of the way and still couldnt get the rod loose. Theres some kind of metal flap or something that covers that e nd, and the roll pin or drift pin is underneath on the bottom too.It looks like the whole end of the column would have to come apart.
Tommorrow someone is going to help me try to drill out the pin. I think we`ll start with a 1/16 split point bit, try to center punch it if we can. If that goes well then maybe a 1/8 to finish it. The pin measures just under 1/8 on my micrometer. I might need a 7/64 bit even.
Im nearly tempted to saw that rod in two just to try and get my car started and put it back together with a piece of metal sleeve and jb weld. If it doesnt go smoothly tomorrow, I think I will. I need my car back.
If it is anything like my 77 it doesn't have spring clips but the pin that everyone else is referring to. Tonji, as long as you are careful you should be able to drill it out. If you have a way to center punch it that will help the drill bit from slipping. I know it will be hard with the pin being so small but as long as you take your time you should be ok. Once it's drilled out you can then remove the cylinder with no problem.
around the area of the column that the lock cyl slides into; are there any small holes at opposite sides around the circumference?  if you loook at the diagram you see two spring clips. i'm wondering if perhaps those were depressed somehow, that the ylinder will slide out.
ToniJ1960
 Ok I can see it now thats the button on the right side that locks the steering wheel,I wasnt thinking it rode on top pf the gear.But it did look more like the left side would be the end the rod went onto. The shroud is off the column so all I have to do is figure out how to get that plastic collar off I guess. Then if it is the cylinder how to get it out if I cant even turn it. I might ry drilling the pin but it seems like a lot of metal to drill off. Maybe drill a hole through it to just weaken it then try a  slide hammer.
I really want to thank you for taking so much time to show me all these pieces in detail. And for your patience.
The picture of the part above's orientation is 'right side of photo' toward steering wheel and 'left side of photo' toward dash, and that is the bottom side, it rides above the tumber with the teeth facing down. I would start by removing the plastic shields around the column, once they are out of the way you should be able to loosen the collar directly behind (toward the dash) the metal housing for the tumbler, at that end, I'm pretty sure you'll find a 'roll pin' attaching it. if you can get that roll pin out with a punch and hammer, then you won't have to drop the column and you will be able to tell if the lower electrical or the mechano surrounding the tumbler is your woe. Take heart, even if you do have to drop the column, it's only 4 bolts and has enough give to drop a ways, and it's a small car, so it's a lightweight part...as far as that goes. I tried to get a bigger exploded view here, but that was as good as I could get. Hopefully you can zoom your browser in.
ToniJ1960
 Is that picture of the piece with teeth in it, pointed the right end towards the switch and left side towards the steering wheel? And the teeth ride on t he gear at the back of the tumbler? I saw a picure of the tumbler in an exploded view in a haynes manual for a fairmont Im sure some parts are different though.
And if you, or anyone, knows if one end of the rod or the other is easiest to remove (and get back on again ) to just check to see if the actual switch is bound up?
It looks like the rod is hooked upward at that end and you just lift it off said hook, been a while since I was under there. Also the rod is not a part of the potmetal lock mechanism behind the tumbler inside the column, the tapered end sticking out of that 'lock block' picture last night is the part I'm referring to here, behind that taper are teeth, and that piece slides up and down the column as you turn the key, and has a hole toward the dash side for the rod to hook into. The bolt slots in this pic are the bolts holding the column to the metal dash.
This is the other end, there's a gear that stands vertical with a slot for the tumbler that engages these teeth. I can't remember now how the bracket looked with the instrument cluster out, you may not be able to get to it that way after all (sorry) the Haynes manual says to disconnect the battery, undo the column to dash bolts and lower the column for access, and again, no mention of clip, just lift straight up off rod
I'm thinking a slide hammer could work, but it could break something. I got lucky one time and just twisted the chrome part of the switch with a good sized pair of channel locks, the tab on the column end of the tumbler just twisted right off, but another time I tried the same thing  ::) always losing my keys, and just the chrome part broke off, and I had to go junkyarding and get another column.
It could be, I was just getting ready to show you a couple of pics anyway. How are your keys, are they badly worn? You can try getting some graphite lube for locks and applying it to the key, not the switch, and inserting and removing it a few times then trying to turn it. If your keys are worn and it's keyed the same for both door and ignition, then you can take your door lock cylinder out and take it to a locksmith and for $15-20 they can make you a new one. Sometimes they get so worn that they don't depress the 'teeth' inside the lock anymore. As for using a remote starter switch, I would say no in this case because the switch is not in the on position, so hooking up the remote start would only crank it, and it wouldn't fire.
Fred suggested in that other link in my last post to remove the steering wheel and then removing that lock block, I'm thinking much more that your problem is the electrical portion, it's on the top of the steering column bracker, way easier to remove the instrument cluster to work on it, but beware and be gentle if you choose that route, the white plastic 'bucket' that holds the gauges is more often than not dry-rotted. I know it's late and you're probably not going to run out there now and mess with it, but I'm checking in a few times a day lately and hopefully another might have advice for you too.
ToniJ1960
 I read his post and I could probably figure out how to free the steering wheel Im sure. I dont know if I can get the car to run by starting it with a remote start switch or not though.
And if the cy;linder should be in the run position to get that pin in, theres a problem because one, it wont turn at all. And two, even when it did and I tried to replace the cylinder a couple years ago after someone tried to steal it, the pin wouldnt go in so I just left it the way it was.
Now I didnt think, if the switch itself might be jammed and keeping the cylinder from turning. Is that likely?
And yes I tried turning the steering wheel jiggling it jiggling the key the tow truck driver tried for a while and gave up too. I think I just need to get the cylinder out I dont care if its in pieces and the collar is  alreadsy broke off from the theft attempt a couple of years ago. So I can see inside the cylinder I might even be able to disect it. Or I guess drill out the pin? Break it out with a slide hammer? Thats how they changed the cylinder on my 74 wagon I had once.
Did you try rocking the steering wheel back and forth while you're turning the key? Sometimes mine would hang and it took an effort on the switch and the wheel at the same time. The electrical part of the switch is down under the dash with a rod leading up to the tumbler itself, on the top side of the column, the electrical part can be unbolted from the column, and the 'lock block' screw at the other end of the rod under the steering wheel is the screw directly to the left of the 'key in buzzer' switch, the white plastic with a single wire on the upper right. Haynes manual says 'run' position for removal, and  that it should be 'on' when inserting it and to turn it 'off' to release the pin after inserting it. I'd suggest lubricating freely inside the tumbler socket on the column while it's apart, I use spray lithium grease on stuff like that. One more thing, the socket for the wires to plug in on the electrical part is held to the housing that mounts to the column with 4 small metal tabs that are bent over, sometimes they come unbent and the two parts separate, there's a ball bearing in there, and if it's out of place, it'll jam up the works. I've put them back together before, but if the tabs become really weak then the fix only lasts a few weeks and a new electrical portion is in order. Hope it helps, and hope you get back on the road soon!
There was a suggestion from Fred Morgan in another thread for simply bypassing it and getting on your way, it was here:
http://www.fordpinto.com/general-help/help!!-21731/
ToniJ1960
 Well it started to go to the store but wouldnt come home. The ignition cylinder just wont turn. Its the first time in over 12 years my poor old car was on a tow truck.
  Its a 1978 Pinto wagon, I had it for nearly 27 years and right now I emphasize nearly lol.
My questions are
1. if it wont turn can it still be replaced easily? I forgot what position it has to be in for that pin to go in. I didnt change it before because that pin wouldnt  even go in when it did still work. Can it be drilled out? Or a slide hammer break the cylinder out like on a 74?
2. If I can get the steering wheel of and disable the wheel lock, will it run if I use a remote start switch to just be able to drive it somewhere to get it fixed? I dont know what all circuits are on the ignition switch if the car will run lights all work no lights what.
Anyone with some imput answers etc please help thank you Pinto People I always enjoy reading the Forum and try to [ut in 2 cents worth when I can. Hoping someone will ease my anxiety a little with this.
