Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 06/28/2019 09:14 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 02/14/2019 06:27 pm
Date: 08/03/2017 07:40 pm
Date: 02/10/2017 09:30 am
Date: 09/15/2019 12:38 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
  • Online today: 600
  • Guests: 438
  • Total: 438
Is it wise to re-use 2.3L followers on a different cam?
Started by Pinto5.0, July 16, 2012, 05:21:55 PM
My instinct was to install new ones anyhow. I'm glad I asked just to be sure.
Quote from: Bigtimmay on July 17, 2012, 10:51:16 AM
Only ones I know of that can be reused are the roller followers. But they can only be used on roller cams.
WRONG!!!! 2.3L Roller rockers will work all day long on 2.3L and on 2.0L (if you have 2.0 roller rocker arms). Had both for years on the street and track. Been there/done that.
racer99
The rule is never reuse or swap followers when changing cams. The followers have already established a wear pattern unique to the previous cam. If the pads on the followers is worn even slightly off plane the New cam will suffer right away. Why waste a new cam?, get new followers and eliminate the risk..
Everything I've ever been taught says you cant re-use lifters on a different cam but does that rule apply to followers? I see used ones selling on Ebay for good prices by themselves all the time.
The ones on my '79 2.3 are OEM Ford with 20K miles on them & I'm swapping in an Esslinger .495/265 high vacuum hydraulic cam that has 6 races on it.
New ones are only 90 bucks at Summit but if I don't need new ones I'll save the money to spend elsewhere. What's the rule with followers?
