Intake manifolds
Date: 03/06/2021 03:04 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 06/07/2021 08:14 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 09/19/2019 04:43 pm
Date: 07/08/2022 11:51 pm
  • Online today: 600
  • Guests: 440
  • Total: 440
Engine ID
Started by Bigfoot79, July 07, 2012, 11:12:05 PM
Bigfoot79
Thanks for the quick replies. Using your tips it is a 2.3, oil fill is in the back and the distributor is about five inches. Is there a way now to break down the casting code to confirm a year and model that it originally came out of?  Thanks again
Unless you have a need to open the cam cover, the Distributor location and Oil filter location tells you what you need to know. There are subtle differences in the shape of the cam cover and the timing belt cover too. If you open the cam cover it's easy, 2.0L have 3 cam bearing towers, 2.3l have 4
Another way to tell th difference of the 2.0 & 2.3 is the location of the oil filler cap, and how to remove the cam. the 2.0 has the oil cap in the front, 2.3 in the rear. Also at the back of the 2.0 head there will be a camshaft retaining plate. The cam is removed from the rear of the head on the 2.0. The 2.3 has the retaining plate at the front behind the cam gear.
johnbigman2011
Bigfoot... the way that I tell them apart is buy the distributor placement. 2.0's are really close to the timing belt and the 2.3 are roughly 5 to 6 inches away from it. Hope that helps without getting into all the numbers. I'm new to these motors as well.
I own two 2.3 and four 2.0's
Bigfoot79
Hey guys, I was hoping for some help ID'ing my engine. It's in a sand rail I just bought. I was told it was a 2.3 but that was all the info the seller had. I've checked the fomoco site and must be to ignorant to figure out the casting on the side of the block because im no closer to an answer. Hopefully one of you can help out. The casting under the exhaust is 08EL 6015-BA.  That casting is near the front of the block, closer to the middle of the block there is also 7GO8 cast in it. Thanks in advance for the help
