Date: 07/04/2017 03:26 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Parts Parts Parts
Date: 05/19/2018 04:56 pm
Date: 11/05/2020 06:32 pm
Date: 01/12/2019 10:19 am
Front sump oil pan
Date: 01/02/2017 06:54 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Online today: 854
  • Guests: 753
  • Total: 753
My first car is a 78 Pinto
Started by Clydesdale80, June 21, 2012, 07:02:47 PM
Clydesdale80
My car should be a little more rust proof now to stand up to Iowa winters and road salt.  I just finished coating the entire underside and wheel wells with Monstaliner bed liner.  It's a DIY truck bed liner that has been shown to be as good or better than professionally applied bed liners (depending mostly on prep work).  It has become popular in offroading communities to paint entire jeeps/trucks with it.  This stuff really is tough, I plan to coat the engine bay with it as well due to how easy it cleans.  I'll post pics when I can.
Bought a 1978 hatchback to be my first car.
78_starsky
looking good and it is coming along nicely !!
Clydesdale80
I got some time this weekend and was able to test fit the new rear end and get the spring perches from the pinto rear welded on to it.
It's a unnarrowed 8.8 from a ford explorer with 3.73 gears and limited slip.
using weights in the back of the car and a jack under the differential I checked for interference throughout the range of suspension travel.  It doesn't appear that the larger housing or the offset pinion will cause any clearance problems.  If anything I might move the parking brake cable mounts in the tunnel a little but I don't think I'll need to.
Quote from: Clydesdale80 on August 01, 2014, 10:36:40 PM
I'm considering painting the flat bottom half of the bumpers body color in order to simulate skinny bumpers.  What do you guys think?
I think that would be cool, it would be different that's for sure..
Clydesdale80
Quote from: Reeves1 on August 02, 2014, 05:26:07 AM
Looking good !
Now you need this: http://www.fordpinto.com/parts-resources-here-is-where-you-can-find-this-or-that/need-74-78-front-brakes/
;D
Those would be awesome but.... based on the price that they are listed for on wilwood, they are most likely outside the budget of a poor college student like myself  :(.  they are shiny though...
Clydesdale80
I spent this summer fixing up and smoothing out the rest of the body panels. After block sanding the shell I assembled it all to test fit and primed it all again.  I'm hoping that once more block sanding and repriming will smooth out the last of the imperfections. also added a torino gt scoop to the hood after deciding how to cut a hole and mount it.
I'm currently waiting for a driveshaft so I can test fit my drive train, T-5 and explorer 8.8 rear.  In the mean time, I took tonight to tuck my bumpers in and see how they fit.  I also changed out my headlight rings for the earlier style.  For a 78 I think it looks pretty good.
Clydesdale80
lol, I hadn't thought about it that way  :o
Heck, no chance of big leaves getting in there with that set up
Clydesdale80
I do ok at the welding but it looks the way it does because I was patient using the grinder followed by many thin layers of filler.  There is still smoothing that needs to be done that isn't apparent in the pictures.
To be completely honest I like the look. It looks like it was supposed to be that way.  Looks like you do good weld work.
Clydesdale80
thanks, that's ok about the cowl, now that it's all welded in I kind of like the little custom touch
Looks like the car is coming along really nicely! Wish I knew you were looking for a cowl. The one on my 77 has a couple small dents from where the hood flew up but other than that it's not too bad.
Clydesdale80
Clydesdale80
bingo! the previous owner cut out the cowl vents so they got replaced with louvers meant for a rat rod hood. it still needs a little more blending but I have the basic shape smoothed out.
dennisofaz
Hi Clydesdale80.
It it the custom louvered cowl?
Dennis
Clydesdale80
here are all the pics of the top side, i've been sanding most of it down to bare metal and dinging out the dents and glazing everything smooth.  there was some metal that was cut out by the previous owner and i had to replace with some non-factory sheetmetal.  I'll see if any of you can spot the slightly custom replacement metal  :-X
the floor patches blended in fairly well and you can see the main subframe connectors underneath where the front seats would be.
Let me know if anyone spots the custom bodywork and what you think of it.
Clydesdale80
i agree about the welding the galvanized, i used a grinder to remove the coating on the edges i was welding but still did most the welding outside. I will post the rest of the pics on this thread next time i get some time.
thanks for the compliments on frame connectors, it was a slow progress as i was hesitant to just start cutting and found myself second guessing every idea i had but i think it turned out well, there was also a significant amount of cleaning up ugly edges and welds after those pics were taken. the bottom of the car looks much more natural now and the added rails don't stand out like they do in that picture. thanks again guys, i'm glad the consensus isn't that i ruined my car  :o lol
Srt, click on the photos above and it takes you to Clydesdale80's photobucket.  Photos of the top side in primer are at the front.
Clydesdale80, Thanks for the idea and research into adding rocker panel stiffing tubes during the frame connector installation.  I am sure you are aware, but in case somebody else is trying to weld galvanized steel, it puts off a bad gas so use extra ventilation if you have to weld it.  Looking forward to future progress during your next school break.
I "like"!
It looks like you're going in the right direction.  Any vehicle can be improved by a stiffer body structure.  Every part of the driving experience will be iimproved by what you have done.
How about some photos of the top side of the shell?
Clydesdale80
I also did some body work and primed it before coming back to school, i'll post more pics later.
Clydesdale80
wow, its been awhile since i've updated my project thread. The work is going alot slower than i was hoping but there is definitely progress. It's hard to find time to work on my car when i'm going to college over 2 hours away. Anyways, this is what i accomplished this last summer. when i left off last winter i was working on the floor and subframe connectors.
the floor pans are made of galvanized steel that is a little thicker than the original floor.  The subframe connector design was created and stress tested on a 3d modeling and simulation program and compared to several other designs. this structure tested to be the strongest of my designs while staying under 40 pounds of extra steel. the steel tubes are welded into the floor for the entire length of the connectors to help evenly distribute stress. there is also smaller tube welded along the rocker panels. the simulations i ran showed that by forming a box with the rocker panels and the main subframe connector rails, it greatly increased the structures ability to resist twisting.
the rear if the main subframe rails T into 3x1 inch tubing placed where the supports for the rear seats used to be. there tubes are notched and welded into the from leaf spring mount and the rear subframe. the other end of the tube is welded to a reinforced arch in the trans. tunnel. this completley "boxes in" the center portion of the car that previously lacked a frame.
Clydesdale80
while I'm welding a new floor in, what do you guys recommend as far as moving the seats back a little?  I'm only 6'2'' but it's mostly legs so getting between the seat and the steering wheel is a bit awkward.
Clydesdale80
I forgot to mention this earlier in my thread but thanks to 79Prostreet I now have an actual gas tank so I can stop using the one gallon go-kart tank.
Clydesdale80
I didn't get near as far as I had planned over break but I definitely made some progress.  I picked up an old gravity box that was falling apart in a friend's barnyard.  I took it completely apart and I'm gonna use the steel to make my new floor.
My dad also helped me make a cradle or "tip-over jig" to make my floor work a little easier.
sorry about the lighting
I think I have a plan for the subframe connectors, I actually found some channel to use.  I should be all ready to go when i get home next. Only 3 weeks until christmas break and then I'm home for a month.
Clydesdale80
thanks guys, I'll look at it more tomorrow but I'm thinking I might use some angle iron to connect the leaf spring mounts to the front frame.  About 50% of the floor is rusted through so I'm planning on cutting most of the floor out and just making entirely new floor pans out of the sheet steel that I have.  This should make it fairly easy to work in any extra framework that I decide to do.  One of my dad's friends said I should tub it while I have it this far apart but I'm not going to since I would prefer to be able to use the interior panels and the biggest tires I can see putting on it would be 205/60r13(biggest that will fit on my mags)  Anything else that you guys would recommend doing at this point?
i realize my 2.3 isnt mild but i do have frame connectors and it does make a difference in the way the car handles....
johnbigman2011
If you ever plan on going with big HP go for it while you have it tore down. There is a good right up on how to install them on here. Look in the search section.
Clydesdale80
I'm getting ready to do quite a bit of welding and patching the floor of my car and I'm wondering if there is anything else I should be doing while I have the welder out.  Is there any reinforcing or anything else that would be beneficial? I know that they add sub-frame connectors in V8 conversions, would there be any benefit from doing this to a car with a mildly modified n/a 2.3? what do you guys think?
P.S. the car is torn down to the bare body and will eventually be repainted so this is a great time to do any beneficial modifications.
