1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
windshield
Date: 04/14/2018 08:53 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Radiator
Date: 05/27/2018 06:07 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
front end parts
Date: 03/30/2018 12:48 pm
  • Online today: 1,137
  • Guests: 748
  • Total: 748
Pinto part interchange?
Started by Canaboost, February 10, 2012, 11:16:37 AM
Canaboost
What I am looking to create list of parts that can be used on the pintos that can be found on other cars at the junk yard or parts store?
Door Glass run channel from a 90 or older f150 250 350 works, the front doors are a inch short but if you find a crew cab the rear doors at the right length. New F150s to 96 or 250 350 to 98 may work but there is a flange you may have to trim, but it might be worth it for a 10 year newer rubber. Got mine for $5
Escort Electric Fan http://www.fordpinto.com/general-help/electric-fan/
Bronco II rear sway bar http://www.fordpinto.com/general-help/wagon-sway-bar/
8" ID http://www.fordpinto.com/pinto-faq/8-inch-rear-ends/?option=com_smf&Itemid=39
77 Camaro rear shocks for the wagon
http://www.fordpinto.com/parts-resources-here-is-where-you-can-find-this-or-that/pinto-wagon-rear-shocks-fyi/
Reading through the form I found out that you can use the ranger or older escort door gasket on the rear hatch of a wagon.
http://www.fordpinto.com/parts-resources-here-is-where-you-can-find-this-or-that/ford-pinto-wagon-rear-door-gasket/msg119367/#msg119367
I pulled one out of a extended cab with the extra doors today so it is extra long. $5 at pick n pull
Using GM door Pins http://www.fordpinto.com/pinto-faq/reolacing-the-door-hinge-pins/msg77679/#msg77679
GM 1 wire alternator http://www.fordpinto.com/general-help/alternator-upgrade/
some Pinto to Mustang parts interchangehttp://www.fordpinto.com/general-help/is-there-a-pinto-to-mustang-parts-cross-reference-list/
Hood Prop Rod convertion http://www.fordpinto.com/index.php/topic,7356.msg81232.html#msg81232
Grand Marquis seat belts http://www.fordpinto.com/your-project/later-model-seatbelt-swap/msg101531/#msg101531
Mustang Alternator http://www.fordpinto.com/general-help/alternator-wiring-help-please!!!!!/
but what else?
etc
