Date: 02/21/2017 06:29 am
Date: 02/28/2024 02:07 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 01/28/2019 05:15 pm
Date: 02/05/2020 11:06 am
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 04/25/2017 12:17 pm
Date: 09/12/2018 12:33 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
  • Online today: 452
  • Guests: 348
  • Total: 348
1978 Pinto backfire problem
Started by 74WagonMeadowGreen, October 11, 2011, 11:15:48 AM
74WagonMeadowGreen
Once the valve was removed, it was easy to see if it was jammed open, which it was...no special testing required!
Out standing, now what is the testing process to find the TVS failure in the first place? Hook it up to a Mitty Vac ?
74WagonMeadowGreen
As of yesterday, the backfire problem is solved... exactly what we discovered... That TVS valve in the air filter housing WAS the cause, and except for needing a choke adjustment the car is running nicely when warmed up. Add to that, the heater bled itself! Once I left the valve open it purged the air block and works nicely. It still tends to stumble a bit when cold, but again, the choke is not in the correct position, so it improves enormously once warmed up. I am confident it should do OK passing emissions at this point, and as soon as both time and weather permit, I will head over to the testing station. Then I can finally get my plates and drive it!!
Thanks everybody for the help.
78txpony
As for your early question on valve guide seals, I have to replace mine every 12-15 years (avg 75k miles) when oil consumption is sky high.  They deteriorate, wear, and no longer seal.  Not sure if it is a design issue or i expect too much from them.
Did you notice how much total timing advance at idle you had when checking your timing?  Check it with the advance hose hooked up as well as removing it and plugging it.
I am leaning towards an ignition / cam timing issue here.
-Rob Young
1997 H-D Sportster
74WagonMeadowGreen
I did not, as time was of the essence, I simply planned to get back to it. I will check several things, including hose temp (when warmed up) as well as if the valve is working/conected, etc. Thanks!
RSM
You really shouldn't have to "bleed" the lines going to the heater core. Usually after a few minutes of running the core is full and the air gone.  There might be a possibility of a restriction in the core or in the lines. When the car was running before, did you feel the hoses to see if both were hot or at least one of them?
74WagonMeadowGreen
As soon as our 18 inches of snow clears, and temps rise above the single digits, I hope to verify the TVS (TVR??) valve, the little circular plastic job located in the air cleaner and connected directly to the air pump, amusingly shoved on several Ford products well into the 1990s, has been the culprit, as I was able to install the new one the night before the latest onslaught of snowstorms, and although covered, my poor car has to sit outside.
Has anybody encountered difficulty removing air from the heater lines when servicing the water pump? The previous owner did a lovely job replacing the water pump, until I drove the car in cold weather and discovered there was no heat!  Does anybody know any easy (outside of "bleeding, hence leaking fluid out to get rid of bubbles) method to remove air in the heater lines?
Happy holidays, and thanks for the input!
nothingtodo
if it  backfires on decel, check the vacuum line going to the air pump dump valve.
ToniJ1960
 That tvs valve is the one on the air cleaner cover isnt it? I think thats what was bad on mine and they cut a chunk out of the vacuum hose that goes from it to the diverter valve. Its was over 10 years ago, but thats all they did to `fix` it. I dont remember if I had a vacuum leak or what happened but its all been redone since then.
Keep us posted,it's all ways a good thing to know more about these cars.
74WagonMeadowGreen
Quote from: D.R.Ball on December 02, 2011, 01:13:47 PM
Have you checked the distributor spark delay valve ? It's a small plastic disc  black and white in color that has a vacuum line going from the carb to the distributor.If it's clogged or not connected in the right direction it could be the problem...It's marked on one side carb and one side dist.
I replaced it, but after getting the car on a lift and doing some tests, a friend and I discovered ., I WAS right, the catalytic convertor was a shell, totally empty, so we installed a new one. 2. The TVS valve, which controls air going from the pump into the exhaust was shot, so a new one is ordered. I am quite certain that will fix the problem.
74WagonMeadowGreen
I tend to think an exhaust leak or gutted Catalytic converter may be contributing to the problem. I plan to look into it as soon as time permits, thanks!
"The timing belt was replaced at a Ford dealer by the previous owner. I CHECKED carefully both ignition timing AND that the cam belt was properly installed. It is spot-on correct. Timing is precise and correct to spec."
I know this may be a LONG SHOT but it sounds like the timing belt may have been installed one tooth off. With the cam slightly off (cam degree), the exhaust valve may stay open too long causing raw fuel to pass through and going boom when it enters the hot exhaust manifold. Just a thought...
I know this is not a Pinto I am going to be writing about, but I thought I'd mention it anyway. I am haviing a problem with backfiring when decelerating on my bus. One of the guy's an the Samba said that it is possibly caused by an exhaust leak. He told me to check all my doughnuts and gaskets on my muffler.
Could this possibly be the same senario for a Pinto? Maybe the exhaust system has an air leak?
74WagonMeadowGreen
Quote from: sedandelivery on November 08, 2011, 04:16:12 PM
Is your EGR valve working properly?
EGR and passagewayis cleaned and tested, works perfectly.
74WagonMeadowGreen
Quote from: RSM on November 10, 2011, 05:46:00 PM
So this happens when you let off of the accelerator slowing down...correct?
When I step on the accelerator, the engine revs perfectly fine, and as it comes back down, it "backfires" in the exhaust, on deceleration. I have not had time to test it, but ever since I drove the car home,the exhaust has always seemed louder than it should, even with a correct muffler installed, so I still suspect the catalytic converter to be empty. I have a new one ready to install, as time permits.
74WagonMeadowGreen
Given our elevation, that may be a wise idea... yes, the timing is currently set precisely to the emission sticker settings... your suggestion is great, thank you, I will see what it does.
Where have you set the timing, as per the emissions sticker ? If so try to advance it a couple of degrees, like to 6 if its a 2 degrees because the original owner has had a similar problem and this helped fix it.On my car...
RSM
74WagonMeadowGreen
Quick clarification: EGR is cleaned and working perfectly. Compression test was indeed accomplished and it was even and good in all cylinders, but I cannot guarantee a perfect seal on the gauge, so will retest now I have a good gauge. The car seems to be backfiring in the exhaust, what some refer "more accurately" as "after fire". It does not backfire through the carb. It does not smoke or make mechanical noise in the motor, like a valve problem would. I am going to revisit the vacuum advance on the distributer despite all indications it is working correctly. It is possible the carb needs readjusting since rebuild, but still should not be a major cause. My friend has an analyzer and I will plug that in as opportunity permits. Right now, I am seriously looking at the catalytic converter... the more I read, the more it may be contributing to my problem...
RSM
I finally managed to successfully accomplish a compression test... unsurprisingly, all cylinders have 130 lbs very evenly, and that with a questionable seal on the compression gauge, so I am not too concerned about any internal engine traumas....he did a compression test and it looks good as far as that goes. Sticking valve is what I'm starting to think...or something along those lines. If it were a burnt valve the compression would be down on that cylinder.
ToniJ1960
 Think it could be a burned or sticking valve or weak valve spring? Doesnt say a compression test was done might be a good idea, like I said maybe start at the beginning.
RSM
Car ran OK, but no idle and backfiring on deceleration. (This is what he said in the first post) Even with the air pump disconnected it stumbles and backfires miserably. (This comment is made later)...Kinda confusing  as to when it really does backfire.
ToniJ1960
 I reread and reread but it doesnt really say anywhere,is it backfiring out of the exhaust or the carburetor. If youve done everything you said already it might be time to start back at the beginning.
RSM
Is the car still backfiring when you decelerate or has it changed? Seems like your saying it backfires all the time..maybe it's just how I'm reading it. Does the engine diesel sometimes when you shut it off?
74WagonMeadowGreen
I checked the vacuum advance while checking timing with a timing light... it seemed fairly obvious when disconnected. I routed the new wires and plugs carefully, so although I can never be entirely able to disqualify them, it seems unlikely. Thank you!
How did you test the vacuum advance, with a vacuum source like a mity-vac ? Or just disconnect it......Also I just got done changing the spark plugs and spark plug wires and can say it's a lot better, not perfect but a lot faster, more power etc......Have you checked the routing of the wires if it's not right it could cause some timing issues like a cross fire in the firing order....
sedandelivery
74WagonMeadowGreen
Quick update: the ignition module is perfect, no problems. I am running low on possibilities! Thanks to all for your suggestions!
