Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 03/14/2020 01:52 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
SVO SWAP
Date: 03/15/2018 03:12 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 10/24/2018 07:35 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
72 pinto
Date: 06/23/2016 12:40 pm
Date: 07/30/2018 04:32 pm
  • Online today: 548
  • Guests: 430
  • Total: 430
1978 Pinto backfire problem
Started by 74WagonMeadowGreen, October 11, 2011, 11:15:48 AM
74WagonMeadowGreen
Thank you for the excellent suggestion. I did check the vacuum advance as well as timing and both seem to be working correctly. I have not been able to test the ignition module as we are now on an every-three-day 14" snowstorm routine... please, Lord, not another fall/winter like two years ago!!
Have you checked the vacuum advance on the distributor... ...Just a thought, my car is having some of the same issues and I when I went over the owners log book for the car it said it had a problem with the timing IE the vacuum would not advance the timing based on r.pm. changes...Of which leads me to believe that the vacuum advance has failed....
74WagonMeadowGreen
Brand new Anti-backfire valve, brand new vacuum temp control valve, brand new canister valve, brand new handful of other valves going to and from the distributor and vacuum lines. EGR cleaned and tested. It is flawless. Even with the air pump disconnected it stumbles and backfires miserably. Bear in mind the carb was carefully cleaned and overhauled, and all functionality restored. Some previous owner has definitely messed with the catalytic convertor, and as noisy as the exhaust sounds (with a correct, new factory-muffler) I am thinking the Catalytic convertor may be a shell, so to replace the needed back pressure and operational ability I will get a new, correct unit. As, in respect to emission garbage, one MUST either have ALL (working) or NONE... half-assed does NOT work... I am wondering, could the ignition box be going south to cause stumbling and backfires? I am running out of valid possibilities, and quite frustrated.
I have a 1976 Pinto if you need pictures of what the vacuum lines look like... Your carb may have more lines but the anti backfire system did not change.......
74WagonMeadowGreen
Again, thank you for the suggestions and insight. I finally managed to successfully accomplish a compression test... unsurprisingly, all cylinders have 130 lbs very evenly, and that with a questionable seal on the compression gauge, so I am not too concerned about any internal engine traumas. I will indeed check the various devices starting with disconnecting the divertor valve (a.k.a. dump valve, blow-off or bypass valve, anti-dieseling valve, etc) and see how it runs. I will consider doing a reseal on the valve guide seals before long, but really should drive the car a bit first, to help loosen any gumming up, as it suffers mostly from both sitting and aged seals/rubber parts. BTW- you are correct, there is no "deceleration valve" on my 78. There is a vacuum valve (as circled on the above diagram) on the intake manifold, but that is it besides a load of vacuum connections and devices all sprouting from the air cleaner.
On another note, did Ford use the same "faceplate" for their AM/8-track radio as for the standard AM radio?
Thanks to everybody once again! I will post when I track down the problem.
The anti back fire valve is what you should have....It's name should be clear...It stops the back firing.........You can find them on any Ford with a 2.3 except the Turbo Engines....They do not need one...
ToniJ1960
 Attached to the intake manifold. A hose connects it to the carb
But, "Use of the deceleration valve on the Pinto/Bobcat was discontinued after the 1977 model year"
ToniJ1960
 Thats the dump valve, at least that was the name they gave it when I had it `fixed`. Im not sure what the two vacuum hoses are for it, I guess one is a control signal from a switch in the air cleaner I cant remember anymore.
The other one you show looks like a ported vacuum switch that goes into that piece in the intake maifold. Im going to get my Chiltons out and look,but Im pretty sure the decel valve is mounted right at the carb. I might be wrong. Im not even sure they all had one mine doesnt. But like many other things it may have been removed over the years.
74WagonMeadowGreen
Thank you all for your help! For the sake of clarity, please see the attached diagram, and my questions are-- Is the "dump valve" identified as number 9B289 (circled in the illustration), and is the "deceleration valve" identified as number 9D473 (also circled in the illustration)?? I have not had time to do the compression test yet, that is next. I did managed to remove, test and clean the EGR valve. The diaphragm works perfectly, but the gasket had dissolved and vanished, not that it mattered, as the manifold chamber was blocked 100 percent by carbon buildup. I carefully decarbonized it and have a new gasket to install. It is now cleaned thoroughly and ready to reinstall. I doubt it will help running very much but it cannot hurt! With 52,000 original miles it is difficult for me to imagine the motor requires substantial work done to it. Please let me know about the valves. Thank you!
Don
RSM
 Usually when valve stem seals go bad the oil goes past the guides and into the combustion chamber where the oil is mixed with the fuel and it gets burned...hence blue smoke but that will show up as carbon on the plug. With enough oil being burned the plug may foul and since the oil isn't being burned it settles on the plug and shows oily. An oily plug may also indicate that the rings are the issue. When oil comes past the rings it's not mixed with the fuel as much as coming past a guide. The oil still settles on the plug and can foul it or lessen its ability to properly burn the fuel/air mixture. A compression test will tell you a lot.
74WagonMeadowGreen
Thank you very much for your input... I am still attempting to identify each little valve and sensor (it surprises me just how much more emission garbage appeared between my '74 Pinto wagon and the '78). I will verify that particular valve and remove it, once I am certain which it is. I will also verify the dump valve, and look into it. One more question... has there been a consistent problem with the Ford valve guide seals on this motor? I have read a lot of folks commenting the need to replace them as well as how-tos... I am afraid it might be my oily plugs problem, but I have to fit an adapter to use a compression gauge thanks to the 7-mile-deep and narrow plug placement!
I will keep you posted as to what I discover... what I do not like is what is causing the backfire, even if the decel valve may be blown regardless...
ToniJ1960
 Mine did that years ago,I took it to be checked and they said it was the dump valve, that goes to the air pump and the exhaust manifold. They cut a hole in the vacuum hose to it and it quit, I just took it out and blocked off that vacuum port.
It backfired at every stop sign on my way home from work until I had it checked.
Might you have a deceleration valve? It is mounted on the base of the intake manifold and sticks out towards the firewall. One single backfire will burn the valve diaphragm making it completely useless and causing a vacuum leak.
I don't know of anyone who reproduces them though. I would think you might be able to take it off and plug it, the cap off the vacuum line.
Back when I had to get my 78 tested, I had it passing WITHOUT the EGR valve or plumbing, and even with the catalytic converter hollowed out. It was rebuilt shortly before, but still...
74WagonMeadowGreen
I recently bought a 1978 Pinto 2.3L with 4-speed, no air, bare bones but not Pony. 52,00 ORIG. miles... absolutely stunning condition. Car ran OK, but no idle and backfiring on deceleration. I got home OK, and proceeded to check/replace certain things. It now has a new air pump (old one was very noisy), rebuilt carb, cleaned distributor, new wires, plugs, PCV, all vacuum hoses carefully, one-by-one replaced, fuel filter, etc. The timing belt was replaced at a Ford dealer by the previous owner. I CHECKED carefully both ignition timing AND that the cam belt was properly installed. It is spot-on correct. Timing is precise and correct to spec. When overhauling the carb I discovered the pin holding the choke linkage had come loose screwing up choke operation. I repaired it and all works perfectly. The only thing altered from original is the drop-down solenoid (anti-dieseling) was removed. When I fired it up it ran exactly as badly, unable to idle and backfiring on decel. Living in Colorado I MUST pass emissions so all that equipment needs to work. Can anybody suggest what next to check (there are a load of sensors yet to check) that might cause this condition? I did discover cylinders 2 and 3 are oily (on plugs). Possibly stuck rings or valve guide seals? Please help! Thanks,
Don
