2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 02/03/2018 11:28 am
Date: 09/01/2017 07:52 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
72 Pinto
Date: 03/07/2019 12:07 pm
  • Online today: 2,399
  • Guests: 1510
  • Total: 1510
simple fat bumper fix
Started by JoeBob, September 25, 2011, 11:56:41 PM
After about 4 years I thought why not bring this up to the front again.
I will be doing this on the 79. So I had to dig and find it to read up on it again.
Maybe if it is back up front it will help someone else out as well.
I think it looks great, that Plasti-Dip is cool stuff.
JoeBob
a view of the back
77 yellow Bobcat hatchback
Deuteronomy 7:9
JoeBob
I finished the bumper retraction a few years ago. I was still just a bit unhappy. My bumpers were badly scratched. I could not afford to have them refinished. I came up with this fix. I sprayed them with plasti-coat. It gives them a rubber look. So many cars now have black rubber bumpers that even though this was not an option in 1977 it looks right. The plasti-coat is easily removed with no left over mess. tell me what you think.
Deuteronomy 7:9
This was way easier to do on my 78 wagon. Drilled a hole in absorber pressed them in with a 50 ton press at work then just drilled a hole thru and nut and bolted it into place worked great plus was able to get as much in as needed.  Did it to the front and rear bumpers. Just my 2 cents!
Thanks.
I don't want to just push in the bumper bracket though. There is no way of knowing if it ends up in the right position or not. I want to make it totally adjustable so I can just easily move it in and out by hand until I have it just right and then drill it and bolt it. All the way in may not work. I just won't know until I can work with it.
Try setting the bumper bracket under the front crossmember of the car while it's jacked up & let the jack down slowly.
Personally I'd cut the piece that looks like an I beam down & weld it back together
Probably from age, time for a press too bad you're so far away..
yep, unfortunately it didn't help.
It is really tight. I don't know if it was supposed to be this way or if it is just old. I even tried burning the rubber out, but I don't think the propane torch gets hot enough. Although I did stink up the neighborhood pretty good.
Going to have to get them pressed out I guess.
Oh, for anyone reading this, don't try beating on the plate that bolts on to the reinforcement to knock it out. I tried that after hitting it on the other end for several minutes, all I did was bend the plate. It might be ok if you are trying to knock it in though.
Ahhh, a little incentive, LOL.. ;D ;D
That I have, just no way to really keep everything from flying when I hit it.
But my wife has me so p.o'ed right now I am going to go out and beat on it and see what happens.
Quote from: russosborne on August 25, 2014, 10:42:35 PM
I don't have any thing other than my two hands to hold, beat, drill, etc. I don't think I could do it with these. Not enough hands.
thanks,
Time to invest in a BFH.. ;D ;D ;D
Well, I can't seem to paste the image here, but I was reading my factory manual (thanks Art) and it seems that for the rear bumpers the difference I am seeing IS because mine is a wagon. The rear bumpers mount differently on a wagon vs a sedan/hatchback.
So as long as you don't have a wagon (74 for sure, I don't know about the others) you can do the rear bumper fix.
reason for editing: I am having a really bad day and nothing is going right.
the rate my week is going I would end up in the hospital somehow.
thanks,
Do you need a press can't you just beat them out?? then just slide it back..
If I had a press that would work. My thought is to have the inners pressed out so I can remove the rubber and then hopefully the inners will just slide in and out so I can get them positioned in the right spot.
My reason for posting the pictures in this thread is just to let those with a 74 know that Bill's mod won't work on their cars, unfortunately. It's a great mod for those cars that it will work on.
Put the front bumper shock in a press and make it shorter.
And here are pictures of the 74 front bumper shock. Apparently very different than the 75 and up.
Just for anyone with a 74, the rear bumper mounts are also different. I just took a look tonight. Sigh.
If I remember, I will try to get some better pictures of the rear setup on mine, but I will have to get it up in the air first. I was pretty much just pointing the camera at the area for these ones, but they should show enough of the difference.
JohnW
I think at some point I'm going to make new brackets for my '80 out of steel plate with angle iron where the bumper shock is. I tried to drill out the shocks but I couldn't get it to push in. I still want it to stick out around an inch or so from the body in case I get hit.
That will be the only way to do this on mine with the stock bumpers, unless I could fabricate something.
Just another thing to think about. It doesn't have to be done anytime soon.
It would probably be easier to just get a small bumper, but easier always equals $.
JoeBob
Could you drill new holes in the bracket or frame to allow you to bolt on anyway you see fit?
Deuteronomy 7:9
Quote from: joebob on September 25, 2011, 11:56:41 PM
For some reason the mounting frame for the radiator on passenger side was ¼ inch too far forward to allow the bracket to fit properly. A light tap with a sledge hammer moved it back into the correct position. See photo. red tape shows where I hit with the hammer. http://s1124.photobucket.com/albums/l568/bobjoebob/bumper%20fix/?action=view&current=radiatortap.jpg
Ok, I was re-looking at this, and just noticed a major difference between Bill's car and mine. The radiator support and forward part of the frame is completely different.  :(
Mine matches what the 74 manual shows(Vol. IV Body page 47-09-02), so there must have been changes over the years.  :-\
Compare my pictures below to his in the above link.  His support has a nice curve to it. Mine is very angular(?), anyway, totally different. So I guess there shouldn't be a surprise that the front bumper mod won't work on my car. I am wondering when Ford changed the support over to the nice one like Bill has? I like curves.  ;D
Bill, it just took getting bumped at the right time.  ;D
Dan, no, it is the actual bracket that won't clear. Might be able to grind it down some, I haven't looked that hard at it yet.  :-\ I decided to move to another area I have been working on for now until I can come back with a clear head.
JoeBob
It is so funny. My post went almost 3 years without anyone making a reply. I could not imagine that this was not interesting to someone. Now 40 replies in just a month, it is so strange. Thank you Clyde for posting photos.
Deuteronomy 7:9
Clydesdale80
Quote from: russosborne on August 11, 2014, 03:59:09 PM
Well, that was interesting.  ???
I just found out that this mod won't work at all on my car, at least not in the front.  :(
I took the mounts off the bumper so I could work with them, and found out that if I move them back one hole the front of them won't clear the frame. It's not by a lot, but enough. I'd have to measure it to see exactly, but I am thinking much less than one inch. The mounts seem to be totally uncompressed. Both sides are the same way. Everything fit nicely before I took the bumper off.  :-\ :o
I really don't know what is going on. I was thinking maybe it was a wagon thing, but my manual shows the same dimensions for the frame holes for both the sedan and the wagon. I wouldn't imagine that the newer years would be any different there.
Who needs a bumper anyway? ;D
is it the head of the bottom bumper bolt hitting the rad support?  that bolt has to be move as described in the original post.  otherwise I guess things changed somewhere between 74 and 78.
Wagons look good with a roll pan out back & no bumper to break it up.
I guess that's one way of looking at it!
That would probably be the best way. However my fabbing is limited to what I can do with a hand drill, a hacksaw and/or a grinder.  :-[
And possibly a BFH. ;D
I am thinking that if I remove the reinforcement piece from the bumper that should make the rest light enough so I can modify the mounts if I need to. I wouldn't want to do that with the full weight of the stock setup though. Although to maintain the correct spacing I am wondering if I will have to cut the reinforcement up and use like 4 inches (width) on each mount since fabbing a spacer for me isn't in the cards.
Just going to have to start playing with it I guess. I'm trying to get motivated to go out there right now, but it is a tad warm. ;D
