Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 01/10/2022 03:41 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Parts Parts Parts
Date: 09/08/2018 03:13 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
  • Online today: 548
  • Guests: 502
  • Total: 502
Just SHOOT ME!! Starting another Pinto project, a '73 this time :)
Started by Pinto5.0, September 16, 2011, 05:14:31 PM
Finally go some assembly going. Put the vent back in along with a good wiper motor.
Also got the column support & automatic pedal installed. It's all shiny black POR & pretty.
The new master cylinder is in & hooked to the pedal. I need an adapter for the brake line but that's easy stuff.
The new rack is in & everything's painted.
Also got the front latch support bolted in. I'm ready for the sheetmetal & some primer but I think I'll get the engine gaskets done & drop it in first. It will be easier with no fenders in my way.
This is now a race to finish before the snow flies. God help me....
Finally got some serious progress. I blasted the underside of the cowl & POR'd it a few weeks ago.
I lined it up & got it tacked into place.
I hit the welds lightly with a disc sander to smooth them & then covered them with some seam sealer.
I also sealed around the patch where the battery tray was.
The next thing on the list is BlackCote on the fresh POR & the seam sealer. Once dry I can start assembly.
Quote from: Pinto5.0 on August 05, 2014, 04:29:13 PM
Here's a couple shots of how they fit.
They will work well !
I have to haul my car to pavement to drive it. Have about 6 miles of gravel I will not drive the car on.
Well.....if it ran I would have to !
Got the passenger side, crossmember & front of the tunnel all painted with 2 coats of POR. I have a few spots to seam seal tomorrow then I'll paint the top coat on & I can finally weld the cowl back on & start putting this car back together.
Junk yards use to be full of them on old car haulers. Every car spot had 4.
Quote from: Reeves1 on August 04, 2014, 10:57:46 AM
Like the first one...but doesn't ship to Canada.....
Just had a look under the back of my car. The original frame rails have been cut out for the tubs.
So I'd need two....providi ng the oval part is the right dimensions to fit.
I think those oval slots were an industry standard for the car carriers.
So I'd need two....providing the oval part is the right dimensions to fit.
Where would a fellow get them ?
Would only need 2, I think.
I'll look at the back of my car later.....
Quote from: Reeves1 on August 03, 2014, 01:55:46 AM
See the brake line bracket, where the flex hose attaches. Now confirmed for me the long ones are for drum brake front ends.
I think my 72 has long ones & it has discs but I'll have to look closer & make sure
Quote from: dick1172762 on August 03, 2014, 11:57:45 AM
ALL pintos have those oblong holes for tie down. There's two more in the rear by the front spring eye's.
Yeah, they were designed for these T-style hold downs.
See the brake line bracket, where the flex hose attaches. Now confirmed for me the long ones are for drum brake front ends. Like my blue parts car.
After I install the Wilwood kit on mine I will see if those longer brackets will work better for holding the flex hose off of the tie rod. Already took them off the blue car , blasted & painted.
Also see the oblong hole in front of that bracket ? Is/was that for some sort of transport tie down ? Ever see one that was made for that ?
Finally found time to blast the passenger side & tunnel. I would have POR'd it if the storm & floods had held off.
Work is gonna start picking up this month. Finishing this is gonna be a fight to the end.
to thin out the por15 did you add thinner or reducer to it??
Quote from: Reeves1 on July 30, 2014, 07:34:50 AM
POR 15 brush on or spray ?
If spray, learn any tricks to get it on nice ?
Type of sprayer ?
Air pressure ?
Don't know anything about spraying paint etc.....
I've been brushing it on. I bought the cheapest brushes I can find (3 for $1.00) & I use them once & throw them out. This stuff does not come out of anything once it starts to dry. It took nearly 2 weeks to wear off my hands & I started using disposable latex gloves. I refuse to spray it because I don't want to gum up my expensive guns.
Since this car isn't going to be a show car I have left my mistakes alone. It flows out as it cures & removes brush marks but on vertical surfaces it loves to run & sag & I have dozens of runs all over this car. I don't recommend applying it in the heat of the sun since it starts to cure & gets tacky REALLY quickly. I didn't have a choice but it's a bad idea & inside a garage in temps below 80 degrees would be ideal. Cover your floors with cardboard or plastic & apply it sparingly, thinner is better. I have easily wasted a pint or two due to rushing & less than ideal temps that made it cure too fast & too thick. This stuff is too expensive to waste but since this car will see road salt the excess isn't going to hurt anything.
If you sandblast like I did & want a smooth finish I'd sand everything after blasting then POR it. Anything that will see sunlight needs a topcoat because POR15 isn't UV stable. I topped mine with POR BlackCote. It's not cheap but it's good stuff. Keep the lip of the paint cans free of product. Both of these will glue the lids down but POR15 is like crazy glue. If you use the POR cleaner/degreaser & metal prep like I did wear latex gloves, they're nasty stuff. Any residue left behind (lint, sand, dirt, etc.) will show through the POR like a zit. If you want a smooth finish you must clean it as well as you would to paint the car. The recommended 2 coats POR with a single topcoat is thick. Keep that in mind where clearances are tight.
I did a lot of halfassing on this car & it's gonna show if you look close but it's a 4 season driver so it only matters as a teachable  moment to me. I could have prepped better & taken more time to get it perfect & I will apply what I learned to my other cars.
Type of sprayer ?
Air pressure ?
Quote from: Reeves1 on July 26, 2014, 02:57:58 PM
Knew you would have your Ducks in a row !  ;D
Yeah I wanted to get this right the 1st time. Any mistakes I make here won't be repeated on my 71 or 72.
Quote from: bbobcat75 on July 26, 2014, 06:32:39 PM
thinking about using either the line x or lizard skin bed liner on  my street/strip car! the floor boards and under the car as under coating plus to try and keep the heat down while driving!   a thought for that car for ya!
I'll splurge on sound deadener in my cars since I'll load them up with audio & subs. This one will get a basic deck with provisions for an iPod & about 180 watts total. If Paul wants to earn some money to upgrade his audio I'll install it later but he just wants a car.
Quote from: Scott Hamilton on July 26, 2014, 06:41:05 PM
All I can say is WOW!!
:D
Yeah, this came a long way already. I'm just glad most of it was solid. I would have cut it up for parts & scrap if I discovered all this rust as I was building it to be a V8 car. Now that I have the mint 72 shell to V8 all those parts I had for this car can go on that one.
Scott Hamilton
Quote from: Reeves1 on July 26, 2014, 05:17:53 AM
Sand & paint any parts that will be exposed to sunlight.
Seems to me it says that in my instructions.
Yeah, I did 2 coats POR on the front clip then a coat of POR Blackcote for UV stability. Under the fenders I just did a single coat of POR15 because I planned to undercoat them heavily for rust & chip resistance. I'm going to Blackcote the underside of the hood over the single coat of POR. I let the POR flow into the drain holes at the front of the hood & along the edges & slowly turned it to get the stuff to coat all the inner areas that salt could potentially hit.
As long as he runs this car through a car wash with underbody spray about twice a month during the winter I think it will stay rust free indefinitely. The whole front clip is essentially dipped in this stuff & it's in every crack & crevice. I was thorough in my prep work & after blasting I used POR cleaner/degreaser then metal prep according to the instructions.
The only thing I would do different on my cars is to sand as much of  the freshly blasted areas as I could to give it a better appearance. POR over blasted steel has a rough appearance. I also have the occasional grain of sand under the paint because I rushed things a bit but this is not a show car. On this car it's merely being used as a preservative to keep the car from rotting away during winter use. This car isn't nice enough to restore for summer/show duty but it's not rusted junk that's expendable either. For a 17 year old it should make a perfect all season runner.
The rust in the cowl combined with the gutted interior, factory drum brakes, pinholes in the quarters & hacked up tail light panel where the Cougar lights were would have relegated this to being chopped up for parts. My stepson needing a car & my stockpile of less than mint parts actually saved this car from the scrapyard. I'll still have well over 2K in it when it's done but it will be a nice car for what's in it that won't need a wrench turned for several years at least.
I welded up the battery tray.
I also blasted the insides of the fenders & welded the emblem holes up.
I coated the undersides of the fenders & hood in POR15.
I also covered the undersides of the fenders with undercoating. I sure hope all this will save them from corrosion. If not I sure wasted a lot of time & money on nothing.
