Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 02/28/2018 09:33 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Date: 12/31/2017 09:03 pm
Date: 08/08/2018 12:26 pm
Date: 05/21/2019 11:50 am
  • Online today: 3,091
  • Online ever: 3,214 (Yesterday at 10:48:59 AM)
  • Guests: 1572
  • Total: 1572
2L vs 2.3L. Which is more efficient...??? (Mileage AND power)
Started by Pale Roader, February 04, 2011, 03:47:14 AM
69GT
      The 2.8 is a great motor but like the 2.0 you'll have a hard time finding performance parts. I still say 2.3. You have all the modern transmissions and cams and heads to upgrade to. And we haven't even talked about turbos yet :). If you want horsepower the stock turbo 2.3 will hand a souped up 2.8 its butt in a horsepower contest. Think about this too: a modded N/A 2.8 will get way worse gas mileage. My friend had a beefed up 2.8 that got about 15 MPG. Now mind you it was in a Capri and it could (And did) take down an 80s IROC Camaro with a 305 in a strait up drag race :). My old SVO with a built 2.3 turbo got close to 30 MPG and could (And did) take down an LS1 Camaro. Good times...
pintomagic
Intersting topic ! All I have to say . What about the 2.8 ? I heard dual exhaust gets % 20 horse power . Don,t know much about mechanics.
76 2.8 was faster . than the other 2.8 s . I heard a 2.9 ranger engine could fit in as well .
pinto1979
I've had both and the 2.0 revved a bit freer, but I always had a soft spot for the 2.3 as I had a nicely tricked out one that made all kinds of power and had a better exhaust tone.
Pintos for World Domination!
69GT
     I'd go 2.3. You can get hydraulic roller cams that rev to 7000 RPM with the right springs. And they are better suited to high RPMs with their stronger internals and 4 instead of 3 cam towers. It's also pretty easy to change cams with the motor in because the cam comes out the front instead of the back.  Plus if you like solid cams you can put one in a 2.3. The aftermarket has headers and all the cams you will ever need. Oh, and blocks that can take 500 HP :) Spend money porting a later D port head and put big valves in it. Port a lower intake manifold from a F.I. 2.3 from the 80s and plug up the injector holes and buy a Racer Walsh 350-500 Holley 2BBL carb adapter kit. Throw in a full length header (Hard to find for 2.0) and enjoy the extra 18 cubic inches :)
The 2.0 had a slight advantage in stock form due to it being a little lighter and having a mild solid cam. It also had higher compression in 71.
That's just my opinion. Both are really fun motors. I had a 2.0 in my 72 and it was pretty quick.
Quote from: Pale Roader on February 05, 2011, 07:03:51 PM
Solid lift and 7K huh...??? Is that in stock form? the redline i mean.
It had a Holley 350 and a header, stock cam advanced 2* and I turned it 7K.
What did your 2L run without the juice...?? What was done to it?
Never ran the 1/4 without the juice but went from 10 flat to 9 flat in the 1/8th. All stock internals, Weiand intake, 390 Holley, Hooker header, Isky cam w/ adjustable pulley, small alum crank pulley,
I agree w/ Big Timmy, 2.3 turbo is the way to go. EFI so it runs good, good gas mileage, runs like stink even in stock form.
dave1957
my 74 has  a 2.0 and i like it better than my 79 2.3 n/a of course
1979 bobcat
1974 red stinkbug
Pale Roader
Quote from: Bigtimmay on February 05, 2011, 07:16:52 PM
Depends on if ya wanna stay N/A of go forced induction too and carb or FI.
Because my stock 2.3Turbo pulled close to 200hp and still got 25-28 mpg and this was in a car that weighs almost double what my bobcat weighs.
A 2.3T can be swapped in with the fuel injection and all. That's what I'm doing these Lil 2.3T will give a v8 a run for its money due to it weighs alot less and can produce close to the same HP.
I should have added that i'm only interested in N/A right now.
Pale Roader
Quote from: 71pintoracer on February 04, 2011, 09:33:04 PM
Stock vs. stock, the 2.0 will spank the 2.3 hands down. it has a solid lift cam and will happily rev to 7K rpm. The lifters in the 2.3 limit it to abouut 5k at best. Today, the down side is it is very hard to find any type of performance parts (new) for the 2.0, but there is a huge market for the 2.3. gas mileage wise they should be close, but you need to decide what is more important, power or gas mileage. The two don't really go together!  :P   For the record, my 2.0 ran a best of 13.47 in the 1/4 @ 105 MPH with a 50 shot of nitrous.  :evil:
Well... that was true 30 years ago, but today you CAN have both. Thats why i'm here, i'm just trying to figure out the best base to start with. The 2L sounds considerably better.
Funny you mention parts are hard to find for the 2L, around here thats all i seem to see parts for. Nothing for the 2.3, but lots ov 2L stuff. Maybe this'll all dry up if i trade my 2.3 for a 2L...
Pale Roader
A bit ov a loaded question, as (if i'm not mistaken) the extra weight ov the 2.3 would make for a heavier car, and that these HP levels even an extra 100lbs would make a dent in mileage. BUT...
Which is better? I'd always thought the 2.3 would be... Its more modern, still used up till 2001 in one version or another. But it really doesn't make much more power than the 2L (and certainly not more HP PER CID), which is smaller. Which got better mileage? Can we compare them? seeing as the 2.3 only came around in 74, when the cars were 400lbs heavier than in 71, when the 2L was around.
If we could put both in a 2000lb car it would seem the 2L would be faster, and get better mileage? Or were they pigs for some other reason? Wiki entry reads: the 2L, a German engine, was 'tuned for performance'. It was also just starting to see the smog stuff, whereas the 2.3 was born into it.
Incidentally, the mileage on my 76 'MPG' is supposedly around 23/34, and the way my own heap just kept on going and going and going i dont disbelieve it (even in its dilapidated shape, and god only knows the last time it was tuned...). Still cant find any actual figures on the 71-2 2L Pinto though...
