Date: 01/23/2017 07:41 am
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 10/10/2019 10:02 pm
Date: 09/15/2019 08:30 pm
Date: 02/28/2018 09:18 am
Front grill for '72
Date: 03/02/2022 12:09 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Bumper Guards
Date: 03/28/2017 09:27 pm
  • Online today: 548
  • Users: 1
  • Guests: 469
  • Total: 470
  • rob289c
Old Faithful’s (late) 150k mile maintenance - valve seals 'n' more!
Started by 78txpony, May 04, 2010, 10:06:06 AM
78txpony
Quote from: Srt on May 19, 2010, 05:56:09 PM
i was under the impression that they all ran off 'ported' vacuum. (off the carb) and not manifold vacuum.
That is how I thought the factories did it, also.
Maybe the factory that did mine screwed it up!  The original hoses and routings are still in place.  Noone has ever messed with the hoses.
I made a vac diagram and will post it when i can redo it and make it readable enough...
-Rob Young
1997 H-D Sportster
THat's my guess. I'm going to try playing with mine on Friday, I'll let yall know what i find out.
if, when you run it off ported vacuum it runs bad, it may because you have all the carb adjustments and timing set for when it was connected to manifold vacuum.
78txpony
Well the factory hooked the disty to the front manifold vacuum fitting, along with some other vacuum circuits.
At idle, the disty hose has 15" and it increases with steady opening throttle.
The rear manifold port gave be 19".
However, 15" at the disty seems to be enough to give me full vacuum advance.
The disty is a 4 month old reman unit - unsure of its quality.
On the 5200 carb mixture screw, which way do you turn it for richer and which way for leaner??  I cannot remember if that is an air bleed or an actual fuel port...
Thanks!
-Rob Young
1997 H-D Sportster
I'm running my distributor off the main vacuum line. I can't figure out which port on the carb is for the distributor. I've tried one that I thought it was but didn't get much vacuum and the motor seemed to run worse. :(
78txpony
The disty hose is connected to wherever the factory decided...  :P
All the hoses and vac switches, etc, are original, so it is possible something is going on there that shouln't be.
I will connect the vac gauge to it and see what happens. I am thinking it was maxed out at idle.
On the way to work, the car DOES run better and stronger.
Upon takeoff, the clutch engagement is firm and the engine 'grabs' me.  I can easily idle in first and second without engine lugging.
This is much more welcomed than the mushy, juddery, engine-bogging starts that I was so used to.
Idle was crappy though - i will adjust that today and keep tuning it.
I wish I can loose that annoying clutch bearing squall!!  :mad:  The WD40 treatment did not help...
-Rob Young
1997 H-D Sportster
Quote from: 78txpony on May 16, 2010, 06:52:27 PM
I prolly read the marks wrong...  ::)   I had doubts when i wrote last time - I will check it tomorrow.
Now you are saying 36* tops at idle with vacuum hooked up, right? Ot at different RPMS, too...  ???
36* total with all the advance in, say at 3000 rpm. Been a long time since I had a car w/ vacuum advance but it seems like you are getting a lot of advance at idle. Are you sure your vac hose is hooked to the carb or are you getting full vacuum all the time? When you hook your vacuum gauge to the dist hose you should have low vacuum until you rev the engine. I run a Mallory Unilite and the base timing stays at 10* at idle and when I rev the engine the advance starts changing the timing as the revs go up.
Glad to help! :D
1100 is a bit high, I can't stand it on my 78's 2.3. Adds a constant low tone hum in the car while sitting inside and it drives me nuts! Mine fluctuates a bit between 17 and 20 when down to 750 rpm at idle, but I like to run mine around 800 - 825. No hum, still have power at take off, and it runs great overall!
78txpony
Quote from: dave1987 on May 17, 2010, 08:22:08 PM
Have you connected a vacuum gauge to the motor/intake yet? What's it read at idle?
A vacuum gauge can tell you a lot about a motor's condition.
A vacuum gauge?????  What a marvelous idea!!  I forgot I even had one of those things!   :hypno:
Okay, I hooked it up to a capped port in the back intake.
During its lumpy 750rpm idle, it rapidly fluctuates (vibrates) between 16-20.
According to its FM  :read:, this means valve guides are worn.  Yes, I noticed a little slop when I had the seals off.  I saw the oil around them move as I shook each valve.   :nocool:  I have to live with this for a while - no high dollar head rebuilds for now.  It will need to get worse for that to happen.
If I get the idle to 1100 and above, the engine runs smooth and I get a pretty steady 18 on the gauge.
It drops to 5 when i bump the throttle open like it should and it bounces back to 22, then back to 18.
So for now I raised the idle speed to 1100 and opened the mixture half a turn.  Seems to idle well and the gauge is somewhat stable at 18.  I'll see how it does on the way to work tomorrow.
Thanks for stirring my mind Dave - I forgot what tools I have here...  :rolleye:
If anyone else has any comments, please add!
-Rob Young
1997 H-D Sportster
lencost
I too am enjoying this post a lot! I recently changed the vale guide seals on my V6.
1975 Wagon 8" C4 2.8 V6
78txpony
Okay, here the deal...  Normal idle speed is set to 750RPM.  Any lower and it runs too rough.
With disty hose pulled and plugged, I am set for 10*BTDC.   Engine runs rough (expected).
When I connect the disty hose, engine runs smoother and timing goes to 28*BTDC.
When I rev the engine past 2000 towards 3000, centrifugal advance takes it off the scale, maybe to 36-38* I estimate.  The disty is a reman unit installed a few months ago.
Another weird thing - my carb mixture screw is only turned open about 1/3 of a turnCCW.  Engine runs okay even with it all the way in (CW).  This is also how it was adjusted before I did all this work.
Back in 1990 when i did this type job, I was able to unscrew the mixture about one whole turn.  Whats up with that???
Also, engine runs a little smoother with disty vacuum hose is off and unplugged.  Plugging it makes it run a tad worse.  Is almost seems like its running rich...  ???
Any ideas??
-Rob Young
1997 H-D Sportster
78txpony
-Rob Young
1997 H-D Sportster
40-ish is to much timing. 36* total is all you should run, didn't think there was 30* advance available!!  :amazed:
78txpony
71PR - I really appreciate all the advice so far!  :smile:
After setting to 10*, I checked it with the vac advance connected and I was getting about 30-something* at idle.  When I revved it a little, centrifugal advance took it to 40ish or more (estimating).  That sounds about right...
I will bump the cam another 2* later and see what happens.  Yes, some tinkering around will be needed to find the right combination.
If I hammer out the semi-clogged ceramic honeycomb in the cat, I should get some better flow.  WOuld this require a carb rejet, since the engine was designed with this known restriction?  ???   I thought a more free flow would require richer jets...   Do correct me if i am wrong.
Thanks again!!
-Rob Young
1997 H-D Sportster
If you don't need the cat for smog certification, ditch it. Those old cats were very very restrictive and yea, after 30 years..... :P
If you have to run a cat, look into an aftermarket low restriction.
Kinda strange that bumping up the ign timing caused you to loose power. Might want to check your total advance to make sure the vac advance is working properly. 34-36* total is ideal.
As stated before, all cams (unless it is a custom grind) are designed to be run at 0. Advancing or retarding just changes the power band. With it advanced, the intake valve opens sooner, but the exhaust closes sooner as well. After a certain amount you are working against yourself, so to speak. In their cam info section, RW ans Esslinger say 6* should be the max either way. However, ign timing and cam timing are things that you can play with. You can "feel" the difference. (as you already noticed) So go ahead and play with them, you won't hurt the engine by going 6* with the cam or even more, it is a non-interference engine. But only do one at a time, (don't change ign timing and cam timing at the same time, work with one or the other) that way you know what made the change in the way the engine runs.  :)
78txpony
Okay, I set ign timing to 10* - no knocks or pings at all during a 6 mile drive.
The initial hesitation was improved but now i seemed to have lost that extra oomph I thought I had...  ???  MAybe now i just have some filler power...  ;D
I would not think the timing change would do that...
I once thought that the most spark retard without ping was ideal...
I did set my cam to 0* - (mine was originally off a couple degrees I think) then made the mark on the cam pulley.  I then set 3* advance.
I think I will add 2 more and see what it does.   What happens if I go over 6*?? I am so curious...  :P
The car starts so much easier when cold and the choke pulls off fast - I have never experienced that with this car it seems!!
I pulled the cat converter and found it to be getting a little restricted..  And good cleaner for that, aside from a san-angelo bar or crowbar??  I am surprised that it was not full of oil!
-Rob Young
1997 H-D Sportster
The cam timing and ign timing have nothing to do with one another. As far as cam timing, the cam is designed to be run "straight up" or at 0 degrees to the crank. The problem is that the factory sets them "close enough" and every engine is set the same. Might be dead on, might not. Then if the head has ever been shaved, that retards the cam even more. Did you need the 3* to get your cam straight up? Or did you go an additional 3*? I would say you don't want to go more than 6* total above straight up. I ran my 2.0 at 2* but it had an aftermarket cam. All you are really doing is changing the powerband of the engine. Advancing the cam gives more bottom end which the 2.3 desperatly needs.
Play with it and see what feels best, you should be able to tell a difference at different settings, 2* at a time. Remember, if you needed the 3* to get to zero, start adding from that point. I think I read that you marked the pulley at 0 and then advanced it to 3*.
One more point, and I know this gets to dragging on and on, but with the engine out of the car you use a degree wheel and find absolute TDC. We are hoping that the factory mark is the same, but it could be off a degree or two, which in turn would throw your cam off. Most of the engines I have checked have been dead on.
So once you get the engine running good, you can play with your new toy and change the cam and see how it affects the way it runs.  :fastcar:
78txpony
Quote from: 71pintoracer on May 14, 2010, 09:01:30 PM
GREAT JOB and a very good post!! ;D The engine looks brand new! :amazed: Try setting your base timing at 10* (you are setting it with the vacuum hose disconnected and plugged, right? Just checking! ;D) If it doesn't ping you're good. Might help with the hesitation. Once again, great job!!  :)
Many thanks...
Dude - you beat me to the next question!   :P
I was gonna ask if i should set ignition timing to stock 6* or bump it up.  I will try 10 and move back if needed.  Yep, disty hose was pulled n plugged...  ;)
NEXT question - how do you arrive at best cam timing number?  I am using 3* now.  Keep advancing until it pings (like ign.?)  The more you advance the more the power band moves down??  :o
Should ignition or cam be timed first?  Or does it matter?  :-\
Hopefully I can get it running better.
Thanks for the help!   :)
-Rob Young
1997 H-D Sportster
78txpony
Test run!!    :surprised:
Before filling the cooling system, I wanted to see if the car would even start and run.
I plugged the open vacuum lines, gave a shot of carb cleaner into the carb, closed the choke and gave a short burst on the key...
KA-VAROOM!!!!!!!!!!!!!   :hypno: :hypno:
I hit the pedal and the idle speed dropped.  It ran a tad rough with a little valve noise, but it idled okay.  I ran it about a minute and shut it down since there was no alternator or coolant yet.    It was warm, but not hot.
My neighbor brought over a beer and gave me a "good job!" toast!  :drunk:
The accessory belt was installed, as well as the hard heater lines, securing them with their little clips to the valve cover.
I decided to bypass the heater core, as I no longer trust the 32 year old hoses.  I cannot replace them without pulling the heater box, so that work will be done in the fall when I work on the interior some.
I did secure the old hoses and plugged them well to keep bugs out.   :P
Day 11 -  New radiator arrives!!
So what is a $160 last-one-in-stock radiator made of??     ???
Well, on the good side, it turned out to be brass and copper.   ;D
On the ugly side, it is the same exact make and model of the piece of junk I had in there now – a ready-rad.   :nocool:
The last one was put in around 2001 and started leaking 2 years after.  I'll just have to see how this one does I guess...   :mad:
I installed a heater bypass hose, as I do not trust the heater hoses and do not need a heater for a while anyway. Note the two fail-safe brass "blowout preventers"  :lol:  I added to the heater line......  :rolleye:
These will make switching back to a heater less messy and easier to switch back to bypass mode on the side of the road should an old hose burst in heater configuration.  I got the valves from Lowes – ball valves with ¾" hose connections.
Although the radiator was new, I flushed it with water in both directions to remove any possible contaminants.
It was installed without too much difficulty – drop it in and put in 4 bolts. Glad I kept the spring nuts from the old rad. Overflow tube was installed and secured with black tie-wraps. The big radiator hoses needed no trimming to fit and I installed them with new clamps where needed. The fan guard plate went on last.
I filled the system with a 50/50 mix of coolant and distilled water, a little of each at a time.  I left the radiator cap off and added as needed.
It cranked up easily again, very little diminishing valve chatter that went away in a minute. Choke pulled off after 3 minutes or so.
Once it was hot and on slow idle, I set the speed to about 700RPM and tweaked the mixture to get a somewhat smooth idle.
The timing belt cover had to be installed to time it and luckily it went on easily.   I got out the timing light and set the  ignition timing since it was last set with a stretched timing belt. Spec is 6*BTDC, it was at about 4.  I had to tweak the carb mixture and idle speed afterwards. I suspect worn throttle shafts and carb bushings are the causes for roughness.
Once the coolant was topped off, the genuine Motorcraft radiator cap was installed.
The polished-up air cleaner was installed last – not too bad-looking now!   :hypno:
Remember, nothing was restored or painted.  Only parts that were broke or bad were replaced.   :)
Test drive!  :fastcar:
Well, there are some good, bad, and ugly here.
--The good is that the car runs.   :P  After some tweaks, it seemed a little more responsive with 3* cam advance.  8)  Spinning the tires around corners can be done easier, for sure...   :amazed:
--The bad is that there is a bog on initial takeoff, when before it was not too bad.   ???  At about 1600RPM, the power started kicking in.  I am still questioning the throttle shafts.  Also, the idle will be okay when shut off, and very rough after a restart a few minutes later.  :mad:  Lastly the PCV valve is very loud & buzzy!  :nocool:  If I pull it out and plug the bottom the noise stops – wow??
--The ugly is that during the engine washings, big cracks in the clutch lever boot allowed the bellhousing to fill partially with water.  :reek:  This caused lots of rust on the tranny shaft and throwout bearing.  Needless to say, a loud hollow shrill sound occurs when the clutch pedal is depressed any amount.  >:(   It happens when the bearing spins on the tranny shaft.  Also, the clutch slipped some during the first couple miles.   :nocool:
Finally, the clutch disc was sticking to the shaft splines, causing me to miss shifts.   :mad:
When I got back home, I got the car on ramps and pulled the decrepit boot.  Water drained out  :o and I tried to carefully shoot a stream of WD40 at the bearing.  It seemed to help only a smidgen and I gave up for the day. I left the boot off so hopefully it can dry out in there.  It is full of oil, too – it captured the oil from the constant valve cover leak!!   I do not feel like changing the original clutch yet!!!   :rolleye:
-Rob Young
1997 H-D Sportster
The block is machined cold & the clearances are tightest then. Things expand & move around when warmed up. Are you using the same compression tester? If you are curious just re-check it warm again.
78txpony
Thanks guys - the replies do help me keep my sanity through all this!   :laugh:
Day 10 – Almost there!
I decided it would be silly to start this engine with such nasty, dirty oil in it, so I did an oil and filter change.  I only drained out 3 quarts anyway – it barely showed on the dippy stick...  :rolleye:
I used Motorcraft 15-40 diesel oil since it has higher levels of ZDDP, and I also used the Motorcraft filter that wally world always sells at a decent price.    :amazed:
Afterwards, I disconnected the coil and did a compression test with the engine cold, throttle at idle position.
Cylinder 1 -  130 PSI
Cylinder 2 -  143 PSI
Cylinder 3 -  155 PSI
Cylinder 4 -  150 PSI
--How do these look??   ???
My close neighbor next door came over wondering why I could not get it going, and I happily told him I was just doing compression checks.   :cheesy_p:  He said if it ran first try, he would make a toast with me!   :lol:
Now the above results are interesting...  :read:
Back in 1995 with 95K miles, and with the same tester, I measured the following with the engine warm to the touch:
Cylinder 1 -  127 PSI
Cylinder 2 -  133 PSI
Cylinder 3 -  143 PSI
Cylinder 4 -  140 PSI
Does it measure better when cold?? ???
Certainly it is not "healing" and getting better... :P
Anyway, it looks like this engine will not be getting torn down in the near future!
The spark plugs were torqued down and connected using new Motorcraft wires and separators.
Getting them nice and neat was a little challenging.   :nocool:
Test run!!
I plugged the open vacuum lines, gave a shot of carb cleaner into the carb, closed the choke and gave a short twist on the key...
:lost:
-Rob Young
1997 H-D Sportster
I can't help but to feel so happy you are still determined with this car. I have a thing for the 78 sedans/hatchbacks and love to see them in original shape and well maintained. Keep it up!
just because i do not respond  does not meen i do not enjoy reanding and making mental note  in case i ever cross this  path on my own. it is very hepfull  yhanks and keep up the good advice/ work.
78txpony
Quote from: popbumper on May 12, 2010, 12:59:42 PM
  On the driving arouund stuff, no biggie, the crackers were GREAT  :lol:
We all know the best snacks come from auto parts stores...   :rolleye:
Hopefully my radiator will be here tomorrow.  It shows to weigh 15.5 lbs on the fedex tracker and my old one weighs 13, so I am HOPING the one I get is not plastic!  <fingers crossed>
I noticed Rockauto has the rads again but for 212 - whats up with that??
-Rob Young
1997 H-D Sportster
Rob:
  You really have an eye for detail and of course you know I am a NUT when it comes to that - great work. I have a big pile of engine accessories that I will be happy to drop off for you..... :P.
78txpony
Day 9 - Some assembly required...
Today the rocker arms were installed.  DA'ed me left them outside in the tray the night before and we got a surprise rain that night.  :nocool:
We got a quarter inch, cause that was how much was in the &#@$%! tray...   :mad: :mad:
I dried them off,  buffed off any rust spots, and reoiled them. The cam, valve stems and the adjusters were smeared with 80-90 gear oil.
Whack-a-rocker!!  ;D
I slid the rockers in from the spring side, held them at the adjuster side, and whacked them firmly onto the adjusters on the spring side with a deadblow hammer.
The ones that I could not get a hammer to were levered on with a small crowbar and a block of wood.
The key to making this work is for the cam lobe to be straight up – not 'kinda straight'...  :o
Lastly I drenched the cam and all the parts with clean engine oil.
Time for the valve cover to go back on!  :amazed:
I ordered the Felpro "Permadry plus" silicon rubber gasket this time which ~should~ help seal it better.  No sealant is needed – just install with care.  It is twice the price of cork, but should be much more durable, longer lasting, and more leak-proof – well worth it if those claims are true!
I tightened bolts slightly and in sequence, a little more each go-around. I used a big nut driver so I would not overtighten.  However, there are brass spacers in the gasket to prevent over-tightening and damaging the gasket.
The timing belt cover was left off for now so I can tune the cam as needed.
A REAL choke cleaning!!
Forget the choke cleaning spray – this is different...
I removed the entire automatic choke assembly to clean it up, as the choke and fast idle mechanisms were very sticky and unpredictable.
It was pretty straightforward, just remove the screws, don't drop anything, unclip the choke rod and the throttle link, and unhook the wire and vac hose.
It was so nasty I could see why it was sticking.  :reek: This linkage should not be lubed, as lube dries up, hardens, and attracts dirt.  The green cam is very lightweight and is supposed to drop by gravity.
Also, note the fast idle cam stud pulled out and caused the fast idle arm to hang up often.   :nocool:
I took it inside to disassemble and degrease it in the sink with citrus degreaser...  :o  The clean parts were fast-dried in the toaster oven for a few minutes on low.  :o :o
Here are the clean pieces!  :hypno:
After reassembly, it looked like a new choke again!  :surprised:
It was then reinstalled and the gas pedal lubed inside and the clip outside as well.
Good progress for a weekday!!  ;D
-Rob Young
1997 H-D Sportster
78txpony
Thanks Dave!  Despite the few responses to this thread, i hope it will help others do these operations a bit more smoothly than I encountered.  If you lived closer, i would let you finish up my car - that would get those hands dirty!  :evil:
Chris, thanks for helping out and driving me all around town looking for tools we couldn't find.  What a waste of time that was, but not all was lost - I got some ideas that let us get that blasted bumpstick out...  :nocool:
BTW, this ain't over for you YET - there is a test at the end.   :P
You will most likely have to do all this to your motor before reinstallation.  I will watch you and grade ya!   :lol:
-Rob Young
1997 H-D Sportster
It was a blast being part of the effort, even with the difficulties we encountered. I learned a LOT in the process, and it was good comraderie. Thanks Rob for letting me be part of it. And yes, you'll get the bodywork lesson - soon  ;D.
