1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 01/28/2021 03:49 pm
Date: 06/30/2018 09:48 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 04/27/2018 10:28 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
  • Online today: 548
  • Guests: 465
  • Total: 465
Old Faithful’s (late) 150k mile maintenance - valve seals 'n' more!
Started by 78txpony, May 04, 2010, 10:06:06 AM
Wow, great pictures guide on your tune up. I love reading stuff like this. Makes me want to get my hands dirty and get the wagon's valve train adjusted! :)
Keep up the good work!
78txpony
Day 7 – Valve guide seal replacement - the real fun begins!
It seems like every 15 years or so, the valve guide seals on the 2.3 need replacement... The engine starts burning more oil, most evident after sitting and after prolonged idling.  I usually let it go a few years after until the smoke clouds are visible behind me upon takeoff...  Right now oil consumption is a quart per 600 miles – pretty bad.  :nocool:
I did this operation back in 1991 (74k miles) and barely remember what I went through.  I thought the car would be gone by the time it needed to be done again – WRONG!  This time, with the advantages of digital cameras and documentation, I will be able to remember it longer.  Will I have to do it again??  We will see......
Last time I pulled the head, but this time I will do it with the head installed.  I know it can be done and it will help me save my back from wrestling a 75 pound block of iron off from the block... THAT part I do clearly remember!  :o
Chris (popbumper) stopped by to lend a hand and to also see this operation in person. He will need to do his seals if the original motor is to go back in!   ;)
Of course it is easier to do with the motor out of the car...
So here goes!
First, crank TDC was verified once more and the crank pulley was pulled. Timing belt idler was loosened, pulled back with a big screwdriver, retightened, and the timing belt was removed. The lobes had worn 0.06" – not too bad.  I bet it stretched a bit though.  Most of the nasty grime in the timing belt enclosure was scraped off.
The four big oil return holes in the head were plugged with non-shedding paper towels to prevent small parts from falling into them (which would create a VERY bad day...)  :reek:
Next the rocker arms removed one by one using the method I had tried above, making sure I knew each of their positions for reinstallation.  Some of them popped out, ending up under the car...  :rolleye:
Compressed air was directed around the spark plugs to remove any residual debris and then they were all loosened and # 1 was removed.  The air fitting was screwed into the #1 spark plug hole finger tight and was connected to the air compressor (set at 40PSI).  The air in the cylinder will hold the valves in place if all goes right...
Here comes the fun part!
I attempted to compress the valve spring with this improvised tool, just enough to get the keepers off.
Let me tell you this was the biggest failure done on this project!!  :mad:
Even with Chris helping me, the force required to compress the spring controllably was beyond one's imagination.  We wasted almost an hour fighting this and got only one keeper off.  My hands hurt badly and my thumb is still numb as of this writing.   :nocool:
We made a trip to Otterzone and found a screw-type overhead spring puller for 20 bucks. Yay!!  :amazed:
I was unaware to that type of compressor - I only knew about the C looking thing for doing it while the head was off.
We got it home and tried to get it in there, but the #%@&! cam was in the way!  >:(
It had to come out anyway to replace the seal, so cam pulley was removed. I found myself in a bind trying to get the two big screws in the back of the head loosened!  I needed a #3 phillips on a short ratchet attachment.  I tried a #2 offset screwdriver, but they were too tight and I felt it starting to damage the screw – I stopped.
Chris was kind enough to take me to Otterzone again and then to Lowes in the search of a tool – nothing - #@$%!!   :mad:  >:(
On the quest, I realized a #3 small bit in a ¼" box wrench would work.  We get back to my house empty handed and I searched for the above two tools I knew I had.  That too another half #@$%&! hour!   :hangover:
Finally find them and got the two screws out along with the retainer plate.
Gently ease the cam out and it will not pass the radiator top rail!  More #@^*&!!  :mad: :mad:  :nocool:
Put crank pulley back on, jack up engine under pulley, barely missing sway bar.  Removed two long motor mount bolts and jacked up engine about ¾ inch.
The bumpstick was now carefully extracted from the head, noting its original position.  It was set aside in the garage, away from floating contaminants.
I lowered engine enough to get the two bolts back in loosely.
NOW the springs started coming off the way they should with the compressor!   :hypno:
I started with #1 EX.  Compress spring...
Remove the two keepers with the magnetic pickup tool...
Remove the compressed spring and retainer together...
I pried off the hardened old valve seal and checked for valve slop.  There is some visible slop but not too bad...
The seals were hardened but not too broken like they were the last time. Valve stems were coated with a layer of engine oil:
The new seals were installed as per their included instructions:
Install included plastic installation sleeve on valve, slather it and the new seal with oil, press seal over sleeve and tap it home with a socket and hammer.
Remove sleeve and save for next valve. Oil valve and seal last.
Compressed spring and retainer was reinstalled along with their keepers.  Spring was released carefully and valve was tapped with a brass hammer to make sure parts were seated.
Next I did #1 INT, which used a special blue seal with the same procedure.
Air hose was detached and fitting removed. A new gapped spark plug was installed loosely.
This process was repeated for the next 3 cylinders.
The cam seal was popped out of the front of the head with a big screwdriver and hammer.
A new cam seal was tapped in with a block of wood and a hammer and lightly greased inside.
The engine mount bolts were pulled and engine was jacked up ¾" until I could see all the cam bearings in a row:  :P
The cam bearings were lubed with 80-90 gear oil and cam was carefully installed.
Engine was lowered, mount bolts inserted and tightened to spec. Finally the back cam retainer and screws were installed.
In the process I dropped the little screwdriver bit, it BOUNCED OFF the oil drain plug I installed (phew!) and landed at the back of the transmission!   :hypno:  No cussing required this time, as I just grabbed the magnetic tool and snagged it.  8)
The pretty Esslinger adjustable bumpstick pulley was installed next.  ;D
Its bolt was coated with Permatex thread sealant, the cam held with a monkey wrench, and the center bolt torqued to spec.
I left off the old pulley backplate as instructed in its instructions.
I verified crank was still at TDC, cam was in right, with the front two lobes directly UP, and disty pointed to #1 wire.
The timing belt was installed and the idler released.  I turned the engine over a few times using the crank bolt to take up any slack, returned it to TDC, and tightened the idler to spec.
I cleaned the top of the head and removed the paper oil hole plugs.  The cam was drenched in clean 80-90 gear oil.
Degreeing the cam...
Here I followed PintoRacer's "Cam timing 101" article very carefully.  I will not get into detail, as he already did...
I verified the TDC position of the cam with the front two lobes directly UP and level.
With an aluminum plate on top, I measuring from each side of the plate to the left and right side of the head, making sure both distances are even.
I made a scribe mark for 0* on the pulley.  With the pulley's five adjustment bolts loose, I gently rotated the cam 3* advanced as shown on the cam pulley according to the pulley's instructions, and tightened the bolts securely in sequence.
Day 8 – Rest under the influence of prescription painkillers   :hangover:
I sure needed it – I was hurting everywhere!  ???  Finally around noon, still a little 'high' and still in a bathrobe, I prepped the thermostat housing.  I flattened the flange by bending gently with a vice and sanded it on a granite flat-block.  I washed and dried it and cleaned the flange with alcohol.
The thermostat went into the cleaned groove and the self-adhesive side of the gasket went on the housing to keep it all together for installation on the block.
Later on that day, after replacing a window motor in my Oldsmobile convertible, I finally got around to some Pinto work about 7pm.  I installed the thermostat and housing and gasket using some permatex sealer and tightened to spec.
I also rewrapped the engine wiring with non-stick black tape and installed protective wire loom.
Now late and starting to rain, I called it a day.   :sleep:
-Rob Young
1997 H-D Sportster
78txpony
Looking forward to the help, Chris - you will enjoy the insight of the inside of the 2.3!
Day 4 - Odd job day...
New small coolant hoses (all 5/8") were cut to length (3.5" and 2.5") and installed on the cleaned-up coolant pipes.
The aluminum air cleaner was quickly polished up.
The hood prop rod was repaired with the SSC parts and PCV valve, disty cap, and rotor were replaced.
The crank pulley was loosened by putting the car in 4th gear with the parking brake set.  This worked to my advantage since the car was parked on a slight incline and the weight was on the brakes already.  Turning the bolt CCW caused the car to want to reverse, so there was hardly any crank movement.  After a few good heaves on the ratchet, the bolt was free.  I thwacked the pulley with a small hammer gently on both sides to break any rust bonds.  Contrary to desires to pry or yank the pulley off, only very slight, gentle shakes made it come forward.  I pushed it back on for now and rotated the crank to TDC and verified with cam and by looking in spark plug hole.
Lastly I experimented with cam degreeing and planned my attack on the head disassembly.
I held diagonal cutters in the lash adjuster groove and used a wrench to pry up on the lifter against the diagonal cutters.  Worked great – popped right off.  I reinstalled it by sliding it in from the valve side and when it stopped, I gently tapped it in place with a small hammer.  Perfect!  Now how to compress those valve springs....
Day 5 - Odd job day #2...
After work, the radiator was taken to a local radiator shop for evaluation and repair.  Here is the slow weep area:
The guy there glanced at it and said it was beyond repair – wow – it does not look THAT bad!  :mad:  I was quoted $500+ for a new one or $400 to recore mine – screw them!   :showback:
I ordered a new one from Rockauto for 160 – either that one will work or the weepy one goes back in along with some stop-leak stuff.   :o
New spark plugs were gapped to specs and reboxed.
New EGR valve came in and low and behold – a genuine Ford part that almost looked NOS!  :hypno:  :hypno: It even had "made in USA" on the label under the Ford part number!    :amazed:
Of course, it did not fit without issues – note the hose nipple was on the opposite side...  :nocool:  I had to take the diaphragm off and turn it so the nipple is on the correct side.  Not too hard.  Afterwards it was installed with its included LEAD gasket. The cleaned out pipe to exhaust manifold was reconnected without issue.
Day 6 - Odd job day #3...
Oil fill cap gasket was cut from an orangey gasket material from the hardware store. Valve cover was hammered flat around the bolt holes using aluminum stock. Lastly I planned for tomorrow's "battle of the head"...   :read:
-Rob Young
1997 H-D Sportster
Rob - looking GREAT! Should be fun this weekend coming for a visit. I plan to have a full Saturday Pinto day, working on yours AND mine.
78txpony
Day 4 - more disassembly and cleaning!    :rolleye:
The EGR valve was in horrible shape and was spewing oily exhaust into the engine bay.  >:(
The passages and pipe were all clogged and were cleaned out.  A new EGR valve was bought on clearance from Rockauto and is en route.
The timing belt cover and valve cover were pulled and washed...
Here is the timing belt:
Here is the top end before scraping, the second time it has ever been exposed to sunlight:  :amazed:
Note the petrified gasket pieces laying about that were later removed by hand...  Yes, an oil change was due and will be done at the end of this procedure.  :look:
Here is cyl 2 & 1
And Cyl 4 & 3
The gasket was scraped from the cyl head and the dried cover was placed upon it again to keep it clean.
Now Sunday night – I call it quits.  :sleep:
-Rob Young
1997 H-D Sportster
78txpony
Day 3 - Power flush!  ::)
The next day I flushed the cooling system.
The old coolant hoses and radiator were removed.
Note the 1992 date and "made in USA" markings on these old hoses!  :surprised:
Using the garden hose, I forced water through the heater, radiator, intake and block in different combinations while blocking various ports.  Looked pretty clean for the most part.  I never really had any cooling issues, even with no shroud in 100+ degree TX summer traffic.
Inside the engine was pretty rust free, due to ALWAYS having a 50/50 mix of coolant. :amazed:
More cleaning - does it ever stop??  :mad:
Now that more parts were stripped off, round three of degreasing and cleaning took place, mainly around the bay itself.
While the Gulf of Mexico was being slicked over with crude oil sludge, I noticed I had done the same to my yard where the driveway drains into.  I now need to shovel away the black contaminated stuff and get rid of it...  :reek:
After my water-filled day, I blew away standing water from the engine with the leaf blower and called it quits.
Engine bay looks pretty good so far!  ;D
-Rob Young
1997 H-D Sportster
78txpony
Day 2 - Higher effort degreasing...
On the last day of April, while the engine was warm, I did round two of degreasing and cleaning of the engine, under the hood, and around the engine bay.   I used Gunk, diluted Tide, brushes, scrapers, and high pressure water. Extra gunk and water pressure was directed around the spark plugs to keep crap from falling in the cylinders when I pull the plugs later.
Here is after round 2:
Looks nice when wet!  :amazed:
Here's when dry...
I also cleaned under the hood...
Before:  :rolleye:
After:  :surprised:
The majority of the grunge stemmed from the constantly leaking valve cover gasket.  However the leaks were never bad enough for it to drip all over the driveway.  After the 10lbs or soof oily grunge was gone, I drained the cleaner and water from the cooling system.
Drain and flush, round two...
I was shocked to see that the stuff was BLACK!   :nocool:
I refilled it, ran it, burped it, drained it about 5 times until the water came out nice and clear.   :smile:
Here is the sequence of coolant drains from left to right – Straight coolant, flush 1, flush 2, straight cleaner results, cleaner rinse 1.
I only bottled the first rinse, as the cleaner is not really even that harmful.  Active ingredient is sodium citrate, which is actually a food additive!   :hypno:
The system was filled with tap water, ran until hot and left overnight to soak.
Next, the I pulled the air cleaner and covered the carb throat with a special can I save, just for this purpose, and plugged the open vacuum lines.  The air cleaner itself was degreased afterwards and hung to dry.
Time to call it the day...  :sleep:
-Rob Young
1997 H-D Sportster
78txpony
As many of you know, my old '78 has been in our family since new and has been kept up pretty well.
However, it has been a bit neglected over the past 10 years or so, despite its use as a seasonal daily driver.
My mission is to thoroughly clean and flush the cooling system, fix some pinholes in the radiator, replace all the coolant hoses (less the impossible heater hoses  :nocool:), t-stat, leaky valve guide seals (must be gone every 12 years I guess  :rolleye:), valve cover gasket, other minor gaskets, leaky EGR valve, spark plugs, wires, disty cap & rotor, PCV valve, & timing belt.
Most of the spare parts were obtained from Rockauto.  All parts were of the best available brands – no skimping there.  Total from there was about 200 bucks.   I learned not to use cheap timing belts when one failed on me on 2-29-2000.  It stretched, jumped a tooth and the engine died on the spot – first time in its life that it had left me stranded.
Since this car is a surviving daily driver with significant collision damage, I am keeping it bone stock, with the exception of the adjustable cam pulley to bring the power band into the lower RPMs.  :amazed:
I put this operation off last year, but recently the car has ran worse and worse, up to the point I felt challenged when racing a school bus off the line...   :rolleye:
So this year, it is happening, so let's git 'er done!
Day 1 - Low effort degreasing...
A week before the anticipated teardown date, I decided to start cleaning my nasty engine...
Engine temp gauge still said 140* a few hours after I came home from work, so it was a perfect temp for cleaning.
Here is BEFORE:
I bought two cans of Gunk for this project.
Before gunking, I hosed down the cement under the car and kept it wet with water throughout the process to prevent stains.
I started at the left rear of the engine / tranny and circled around to the right rear, spraying Gunk only, in a stream to help blast away the oily grime.
I used a toothbrush only on the valve cover and one thick area right at the thermostat housing. Did not even get my hand dirty...
I let it soak a few minutes, then repeated the same application from LR to RR.
I repeated soak and spray again steps again until the first can was empty.
I got out the water hose and used the jet stream position on the nozzle to wash the crap off. I kept spraying under the car also to wash the nasty stuff away. (Ironically, I did this on "Earth Day"...  )   ::)
Even though the "environmental friendly" degreasers will work, nothing seems to beat Gunk. I always believe that when cleaning something off, it is best to dissolve it with it's base ingredient. In this case, it is petroleum! Applying to a warm (not hot) engine really helps, too!
Below the AFTER pics of round one.
Coolant drain and flush – let the games begin!   :amazed:
I drained the coolant and saved it for recycling.  It has been in the car for nine years – oh how time flies!  Several years ago I did add a bottle of corrosion inhibitor to it as I knew this big job was coming...
Draining is easy on this car.  I did pull the heater hose at the water pump to allow air in for easier draining.
Old stuff did not look too bad.  Yellowish green, no big rust issue thank goodness. I refilled with water, ran it & drained it a couple times to remove as much coolant as possible, as the block drain plug was hard to get to and I knew this engine was not too nasty inside. When all was clear, I put 2 bottles of Prestone super flush in the radiator and filled it with water.
I used a screwdriver lodged in the heater hose connection to 'burp' the air out as it ran.
I drove the car about 25 miles over the next week for a good cleaning.     :fastcar:
-Rob Young
1997 H-D Sportster
