Date: 01/19/2020 09:06 am
Date: 03/25/2019 09:02 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 08/26/2018 06:23 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 03/14/2020 01:52 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
  • Online today: 267
  • Guests: 337
  • Total: 337
93 mustang 2.3l swap in to a pinto problems
Started by flyboy1, March 08, 2010, 12:43:59 PM
Glitch666
The dizzys should swap all 2.3 dizzys are the same, I just put a duraspark dizzy in my 74 from a 79 bobcat. Careful Some times you have to tinker a while to get them to slide into place. Just make sure you timings set right and put the rotor on your number 1 twist the dizzy all the way forward with your roter at number one and slide in and rotate it towards the firewall and it should slide in pretty close to being on number one.
Also the only 2.3 that came with a points dizzy is the 74. They work great for triggering an msd box.
Here this thread has all the info youll need to get your dizzy to drop in right ;D.
http://www.fordpinto.com/index.php/topic,5147.msg31069.html#msg31069
flyboy1
i'm swapping a 93 mustang 2.3l in to my 1980 Pinto. i'm just swapping the intakes and getting rid of the efi...but the distributors will not swap out....is there any way to put a mechanical distributor into the 93...???? or is there a way to make the electrical distributor work with my Pinto???
