Date: 02/14/2019 06:27 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 10/11/2019 11:13 am
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 03/23/2018 09:23 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
  • Online today: 2,535
  • Guests: 2364
  • Total: 2364
Compression?!
Started by delizious, January 24, 2010, 08:22:40 PM
 Delizious,
  You have tight valves, recheck your timing belt marks alignment, and then reset the valves on the compression stroke at TDC.
50K miles and 80lbs is way too low..
delizious
Actually my pinto has 50,000 miles on it
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
Delizious, as far as I know her engine is all original- no rebuilding, new valves, etc.  She has lots and lots of miles on her and the odometer turned over a long time ago I'm sure. She has no performance parts on her. I had thought 120 was low. In any cae, good luck with yours. They might try your patience but they're worth it! ;D
Delizious,
Your Comp Number is too Low. Recheck the valve adjusment after verifying that each cylinder was at TDC "On the compression stroke". If all is correct, The rule of thumb is that the lowest comp # should be within 10% of the highest comp #.
This could mean bigger problems if all is correctly set and aligned.
delizious
Ok, but did you ever have new rings put in and what not? And how many miles do you have on it?
The lowest on my '74 2.3 last year was 120 and the highest 135.
80 sounds low to me. I have 120 on my 74. Its a 2.3 but it should still have about the same compression.
delizious
Just set my valves and did a compression check on the number one and im getting a reading of 60 and I think im supposed to be getting a reading of 80
I dont know what the others read because my battery went dead before i could check
I have a 1973 ford pinto wagon 4 in line 2.0
thanks ;D
