Date: 09/01/2017 07:52 am
Date: 02/28/2024 02:07 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 04/14/2023 06:15 am
Date: 03/06/2019 06:40 pm
Date: 04/15/2017 05:14 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 07/17/2019 05:23 pm
  • Online today: 586
  • Guests: 256
  • Total: 256
74 Squire Project! ( Bella )
Started by pintogirl, January 10, 2010, 09:55:24 PM
Quote from: blupinto on January 31, 2010, 10:17:34 PM
Sorry! I wanted to get everything in one pic! Because there are lines everywhere, just where do you want the camera to focus? I'm afraID IF i GET TOO CLOSE UP i'LL INADVERTENTLY CUT SOMETHING OUT. dRAT. i ACCIDENTALLY HIT THE 54353! CAPS LOCK BUTTON AGAIN!
Take 2 pics, one of front half close as you can to get hoses, and then take one of the back about the same distance as you did the first!! :D
Quote from: blupinto on January 31, 2010, 09:58:57 PM
Right side...
Actually a more close up and standing in center of the of fender would be great! I need to see where hoses are suppose to go! Although we are not going to worry about smog hoses. I just need to know what hoses are for making the motor work right!
Thanks Becky!!!
...and left side...if you're facing the front of the car. Hope this helps!
Right side...
Quote from: blupinto on January 31, 2010, 09:23:56 PM
The air cleaner's off already so if you want I can take a pic tonight. It's up to you.  ;D
No, wait till tomorrow. I would probably come out better in the day light!!!  ;D
We are done for the night anyway! Won't start back on it till hubby gets off work tomorrow!
Quote from: blupinto on January 31, 2010, 09:14:24 PM
Would it help if I took a picture of Wildfire's engine?
We'll, I'm not sure. I have a 77 motor in a 74 car! LOL I am kind of using the 77 CW as a template, but it has issues too! LOL It's hoses and wires have been hacked on before. It is still helping a bit!
If you want to take pics tomorrow that will be fine, just take the air cleaner off and take somewhat close ups of the both side!!! :D
Thanks!
Well, we didn't get to much done over the weekend. I was hoping for more, but really some of it wasn't hubby's fault! LOL
Hubby suprised me after going to breakfast. He took my to the tire shop and we got a quote on some white wall tires. Hubby said that would be ok although it is the most he has ever spent on tires in a long time!! LOL We payed 240 bucks installed and balanced. THey had to order them so we went home and pulled the wheels of the car and cleaned them and then painted them black. Once we got done with that we dropped them off at the shop. I called at about 3pm and they still weren't done. Then they finally called at 4.30 and said we could pick them up. Thing was, we were busy cleaning garage and they closed in an hour. We chose to leave them there till Monday!
Then today I pulled the drums off and we decided to get new shoes and wheel cylinders. I called 2 places and neither had all the parts in stock, would have to order them. So I now have to wait till Tuesday to finish that job. Now I will have wheels back on Monday but can't put them on till Tuesday! LOL
Than FINALLY, I started working on getting the motor all hooked up!!!!
Got to protect those fenders!!  ;D
The motor, fan, and radiator are all in and hooked up. Now it is down to just trying to figure out where some hoses and wires go!! Then finally the test of trying to start her. I'm hopeing that will be tomorrow, but it is hard to say! Hubby works at his own pace! LOL
Oh, and in the pic above, I have hoses going to places they don't go! LOL I was just hooking hoses anywhere! LOL We need to figure out what is smog related and plug that stuff off.  I'm going to go buy some plugs so things look neat!! I hate when you see hoses with screws screwed to them! LOL
Getting closer!!!!!  ;D
Hmmm... The engine is from a '77, a year Pintos had catalytic converters.  Radiator hoses are pretty straightforward, but the vacuum lines have always confounded me. Ask the experts! lol. If WF could be there, at least her engine compartment could be a guide. Well, Juju sent that it'll all work out... this weekend! lol.
It's just the stock fan, but yah we will make sure it isn't to close! Yah, the engine is all bolted in and the drivetrain is all hooked up. Just a matter of hooking all the life lines up! Hoses, vacuum lines, and little stuff like that. It's not just a simple plug and play though. We took a 74 motor out and put in a 77 so some things don't exactly match up, as far as I know. I havn't got into it that much yet. Working the crazy hours I work durring the week, I don't spend much time out in the garage. It may be easier then I am portraying??
I am hoping I can talk hubby into working on it tomorrow, that way I can help and hubby's friend won't be here!
I'll let you know how it goes tomorrow night! LOL
Kimmy, does she have a flex fan or her normal fan? If it's a flex one be careful when you install the radiator hose (top). Last year I bought brand-new hoses for Wildfire and two days after installation the hose got a leak. On inspection it showed that the hose was close enough to the fan blades to eat a hole in the hose. That was almost $20 out the window. Is the ebgine bolted in and attached to the drivetrain? Again, too bad I don't live nearby.  :D C'mon Hubby! Help the wife out!!! lol.
Quote from: blupinto on January 29, 2010, 10:31:37 PM
Well!? Did she fire up? Inquiring minds want to know! lol.
They didn't work on  her tonight!  >:(  She still needs hoses and stuff hooked up. I'm hoping hubby will work on her over the weekend!
Well, not much to report, but I figured I would report it anyway! LOL
The motor is in and on it's way to being all hooked up!
I'm hoping we will have it ready to fire up tonight!!! Then we need to check brakes and all! Also I am going to call around for some whitewall tires!!!  ;D
Will update when we get more done!!
I know how you feel Kim.  My mom bought my 67 Mustang coupe new in Oregon.  We moved from Oregon to Idaho in 1975ish.  For the first couple years my mom kept the Oregon plates and just updated them when we would visit my Grandparents.  Around the third year she broke down and got the Idaho plates and tucked the original Oregon plates away.  We moved the car back to Oregon in 82.  Mom gave me the car in 85 for my 14th birthday.  I started to fix it up then.  It was road worthy in 87 so out came the original Oregon plates and we went to the DMV.  Aparently in Oregon, once the car moves out of state, they wipe the record from the computer.  Eventhough nobody else had that plate number, the DMV would not let me register the car with the original plates.  I could not even register it as an antique because it was not officially 20 years old then.  I had to wait till the end of the calander year for it to be 20 years old in the mind of the DMV and that was not going to happen.  After being shot down at two different DMV offices, I decided to see if I could get personalized plates for the car with my old number.  Instead of getting the plates, I would use my original ones?  I went to a small office and lucked out.  The lady I got knew what I wanted to do and made it work in the system.  I had to pay for personalized plates initially but when I renew the tags, I pay for the standard plate fee instead of the personalized fee.  I was so happy.
Good luck to you......
Today we tried to get the Squire registered back into CA. Fred had a title only done in AZ. I am trying to keep the blue and yellow original CA plates on it.
I had it verified with the plates on the car so at least that will hopefully help. I was a complete idiot and forgot the verification form at home!! UGGGHHH. So that set me back!
I also found out that I will need to make photo copys of the license plate and add that paper to all the paperwork I have. I'm also going to make a photo copy of the last registration showing the plates were registered to the car back in 98. (all though they have that info LOL) I figure any and all stuff I can send will help!
Anyway, so now I have to wait till next Wed. (that is the appt. time for the tow yard, no long lines that way lol) and take the AZ pink with info on the back, copy of license plate, copy of old reg, and verification form all back to DMV. Then they will have to send all that paperwork into DMV Headquarters. Headquarters then has to decide if they will allow me to keep the blue plates! I have no idea how long that process takes, but DMV lady told me to wait till next Wed. to get moving permit sticker. It will be good for 3 months. If I got it today, it would only be good for the rest of this month I guess! Didn't quite get that, but I figured I would wait. Pinto isn't drivable right now anyway! LOL Hopefully it will be by next week! I had planned on it all ready being ready, but a bad flex plate has held me back!
So everyone send good ju ju for having DMV approve my blue plates!!!! I would much rather keep them then have to go to the white plates!
Ok, now, I have to do a little rant.  Why in the world is it so hard to assign plates that are already made, and in one's possession, back onto a car?? ?? I mean if we have plates and they are both in good condition, what is the big deal? I would think it would save money and resources for making a new plate. I mean, wouldn't that fall under "recycling"  ?
Ok, rant over!
Stay tuned....!!!
Ok, so I am bored and I thought what better thing to do then to update my thread! LOL Although not much of an update! Again, just bored! LOL
Today I attempted to get the last screw out of the roof rack, and failed again! LOL
I also waxed the hood and bumper areas. Then our friend that owns a Radiator shop came over and I gave him 2 radiators. He asked if I wanted them both fixed, I said if they were worth fixing. He said it was free, might as well!! LOL So I said sure fix them both!! LOL
So tomorrow I should have the flex plate, I hope, and then by mid week I should have the radiators back. Wed. is also the day we go and register the car(s). So I am hoping to take Bella out for a test drive by Friday!!!!
Ok, done with the bored update!! LOL
Quote from: pintosopher on January 17, 2010, 01:16:32 PM
Kim ,
Would that be like a Rolling cage around the whole car or a "rotisserie" that bolt up in place of the Bumpers?  Rotisseries are less complex and use less space. Besides you can "roast " other food items at a BBQ  :lol:
Pintosopher....
LOL, actually yes, that is what he was going to make for the Minor! It was going to bolt the hubs of the wheels though! Then it would have gone all the way around the car so we could roll it over and fix the floors from the bottom!! LOL
Quote from: pintogirl on January 17, 2010, 12:45:08 PM
I thought of that, but the roof rack already has a dent in it and I didn't want to make it worse! LOL That and hubby was planning on doing that with the Morris Minor about 10 years ago! I'm still waiting for him to build the "roll" cage for it. Don't want to wait 10 years or more for him to build one for the Pinto!!! LOL
Kim ,
Pintosopher....
Quote from: smallfryefarm on January 17, 2010, 08:05:47 AM
I only got the back half of the patch sewed in tonight! I will finish it tomorrow! Last time I did a headliner like this all in one night, my wrists hurt for a week! LOL It's hard to sew upside down! LOL
Kim why didnt you just turn the car over?  ::)
Kim why didn't you just turn the car over? Cause she did`nt have the key she was using a sewing needle...... :hypno:
[/quote]
Quote from: dga57 on January 16, 2010, 12:23:34 AM
It's hard to do most thing upside down!!! :lol:
Unless you're a bat! lol Or a sloth!  :lol:
Not much to update tonight!
  Tranny guy had to order a flex plate and it won't be here till Monday! So the engine and tranny get to sit out a few more days!
I did take out the old stereo and put in one of my old cassette decks!  ;D I wouldn't have done it if the old one would have worked ok, but the volume was staticky when trying to adjust it! It was an old Clarion though and I thought it was pretty neat. Oh well!
Here's the deck I put in!
Hubby bought it for me about 10 years ago! I love purple and had to have this deck. I had it on my Buick for a while, but pulled it out when I sold it and it has been sitting on the shelf since!
Then I had to drag out the sewing machine!
Made me a patch!
Yah, that is bath water! LOL Although I have been waxing her and she is coming out very nicely! I need to put some more umph into it, but I think she will be nice and shiney in the end!!! She is going to be a real nice driver.
The other engine was fried! The PO drove it home with no water in the radiator and it just got to hot. It still turned over, but had no compression or had compression leaks, can't remember what hubby called it! LOL
We are currently trying to find a flex/flux (?) plate. The one that was originally on the tranny had bolt holes that were not quite round anymore! LOL
Will update when something else happens! LOL
Kimmy, she really is a beauty. I still wish she were mine...
    What was wrong with the old engine? I see there's no kicking filly in the door inner panels. Is she really that shiny or is that the bath water? I'm a little (okay ALOT!)  jealous! lol.
Did I email you that woodgrain info from the Hemmings Getting Started magazine insert?
Today I managed to pressure wash the motor and the engine bay! Then I was able to paint the motor. It has been drying for the last hour or so, so I am hoping we can start putting things back on it tonight!!
