v8 springs
Date: 05/07/2017 04:46 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 08/01/2018 01:17 pm
Date: 02/04/2018 08:26 am
72 Pinto
Date: 03/07/2019 12:07 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
  • Online today: 563
  • Guests: 372
  • Total: 372
73 Wagon Project - Brownie
Started by dave1987, December 10, 2009, 02:20:02 AM
Been refreshing the motor on Brownie with new piston rings, seals, and gaskets. I figured that while I have it all apart, I would clean as much as I could and repaint things. I know the oil pan color is originally black, but the blue is so much nicer. The block will be black, but I plan to leave the crank timing cover and the fuel pump cam cover their raw aluminum color. The intake will remain bare aluminum, as I prefer that over the black that was on it before.
Here are some pictures!
1) The oil pan before reshaping. It looked like someone parked the car on a boulder!
2) With a bit of dead blow hammer and a 1.5" wood dowel, I was able to shap the pan back to pretty much it's normal shape.
3) After getting the bad dents out, I decided to hit it with some fresh light ford blue engine paint, as well as the timing cover.
4) And painted the valve cover as well so it all matches. Still need to do the air cleaner though.
I like the points for originality but love the electronic for reliability. The swap may even give the car a little more umph.
Progress. It's name be Brownie lol. Nice to hear you're doing away with icky points.
Well, I ordered a new set of cast iron rings, pan gasket kit, front and rear main seal kits, as well as an auxiliary shaft seal for the motor. That coupled with the freshened replacement head, the motor should be nice and sealed up, with great compression again! Should the XR700 electronic ignition turn out to be usable, if not pertronix will be used, it should have some get up and go again!
I did about a year ago, haven't had the chance to any time recently though. Need to find time....
Man that sucks Dave,
Hope this solves the smoking problem. Did you do a compression test on the car? Didn't see that in previous posts.
Just finished putting the donor head back together for Brownie's 2.0. Sometime this spring it will be swapped onto the car and hopefully it takes care of the smoking issue under load, with fresh seals and head gasket.
Here's the head, cleaned up cam sprocket, and sorted bolts:
bbobcat75
that cargo cover is awsome, i never even thought about it, had a factory one on my 86 mustang and loved it.! now i wan to see what i can do for the wagon.
1975 mercury bobcat 2.8 auto
Thank you John! I hope you found something useful or intriguing from it. :)
johnbigman2011
Dave, just read your build forum from start to where you are now. Incredible build!
Ordered a head gasket set for Brownie today, should be in tomorrow morning. Hopefully it's just the valve stem seals leaking causing the smoking, that or the head gasket. If not, then she'll need a re-ring.
I have not yet painted the mounting eyelet tabs, but they will be painted with a rubber like paint in brown if I can find it, otherwise they will be painted with black undercoating paint.
For the hardware used to mount the cover to the mounting eyelet tabs, I used four "S" hooks that I found at walmart. They are actually "S" hooks for hanging flower pots, but they work great for this application! The larger end of the hook is connected to the cover's grommet and the smaller end of the hook connects to the mounting eyelet tab. Since the cover stretches a bit, it tensions itself and stays tight!
I am planning to add a 2" loop bungie cord to the grommets on one side of the cover witch will give me something to grasp and pull the cover/hook closer to the mounting tabs when hanging the cover. But that is something minor. The important part is that it's done!
Here's some pictures from the outside!
1) Passenger Side
2) Driver Side
3) Driver Side (lower)
4) Rear
Here is the cargo cover! :D
This is the brown one which actually kind of matches the interior. It is more like a thin rubber mat which is some what stretchy, but still ridged.
The black one was more of a mock up unit which is 100% functional. It is lighter, but also less durable since it is thinner, and it already has some minor damage (aka small tearing) from it being folded and unfolded. Small creases don't unfold very nicely on it. It's texture and thickness is actually nearly identical to the headliner material, minus the pattern.
Well, here are the pictures! :D
1) Cover from above
2) Cover from beneath
3) Back left corner's mounting eyelet (same as the back right)
4) Front right corner's mounting eyelet (same as front left)
Very cool! I look forward to seeing pictures and reading progress on your wagon! It sounds like you are off to a good start on fixing the electrical issues!
My alternator is in front of the air cleaner because the car came with factory A/C. I Don't use it, but I have yet to find the brackets to put the alternator on the passenger side. It was a challenge to find replacement lower driver side brackets for it! lol
dieseldave4443
WOW!  I think we're kindred pinto wagon spirits!  I have a 73 brown wagon too-all dusty accessorized with several hornets nest, missing grill and spider webs.  I have the 2.0 and noticed your alternator is in front of the air cleaner-mine is not?????  I too am having electrical issues.  I have a fresh battery with no power to anything?  I'm going to replace the starter solenoid which is 20 bucks and found a new ignition switch on amazon yesterday for 15 bucks including shipping.  I'll be following your thread for progress and try to post some pics of mine as well.  Good luck to your venture and maybe we can learn from each others experiences.
Well, I put the tabs in that will stretch the cover over the cargo area, but two holes were required to be drilled in the side metal at the back or the tabs would flex when the cover is on. They don't look bad either, but minor drilling is required.
For the front tabs, I didn't use the rear of the seat since it wouldn't cover the cargo area properly, but behind the plastic panels on each side, I bolted the tabs between the panel and the metal. The plastic panel goes over it and all you see is a 1/2" sized tab centered with the rear most center window pillar. I plan to paint these with undercoating "paint" so it's a rubber type coating.
I will post pictures of all of this once I figure out the good way to connect the cover grommets to the mounting tabs. I did a test hang with some twist ties (that come with yard trash bags) and it stretches and covers very nicely!
Just need to see if I can find some 1" bungie cords, or make something myself with some small hooks on each end. I just needs enough to reach the 1-2" distance between the cover and the sides of the cargo area.
I would take a red one for my wagon  ;D
id put em up for like 50 lol. atleast then you have some margin for profit to help you on other "pinto related" projects
Dave,
That is some really fantastic work!  I'm impressed.  If I had a wagon, I would want one!  You probably SHOULD offer them for sale but don't cut yourself short on the labor.  They are definitely worth more than the amount you mentioned.  Look at it this way... you're offering a product no one else has!  Keep up the good work!
Dwayne :)
oldford66
 Thanks for documenting this! I love these threads. Very inspiring.
If you think this looks nice, just wait until I get the brown one done! It closely matches the factory seats!
If it comes out nice when it's installed I was thinking $20.00 or $25.00 shipped. The vinyl is about $5 for a slightly oversized sheet, and $7 for a pack of 10 grommets. Thread and needles are cheap (about $5 for both).
I'm working on finding a way to keep the "stock" appearance for mounting it. The three grommet end will be along the back seat, while the end with the two grommets will go along the tailgate.
More updates to come!
dave let me know how much you would charge to make those lol. id love to get one. that looks GREAT.
4) Corner grommet (bottom side)
5) Corner grommet (top side)
6) Stitches for edges (two rows of zigzag stitches)
After much practice and getting my "new" sewing machine to zigzag stitch again, I finished making one of the cargo covers last night using the thinner black vinyl. I think it came out pretty good! Here are some pictures:
1) The Bernina 830 Record Electronic sewing machine I use
2) Cargo cover finished (top side)
3) Cargo cover finished (bottom side)
Looks like next spring/summer I will be refreshing the motor. Piston rings, oil pump rebuild kit, and a new pan seal. I may put off rebuilding the head until then too. Need to get an engine stand and rent a hoist....
Installed the blower yesterday before the date with the wife, and it didn't even come on! :(
Got back in today and found a blown fuse from when the old motor seized up. Problem fixed! Blows good air flow again!
Now who wants to make a bet on how long this one will last? lol
Well I found myself a nice Bernina sewing machine at the thrift store for $97.34! It is a 1971-1982 model of the Record Electronic 830. After some practice runs I will be doing the hem work myself for the cargo cover.
The blower motor seized up on me this week, so I went to car quest today and they now have one coming in from IL for $60 w/freight. Hopefully this will be the last blower motor I have to install on it for awhile. I just need SOME way of defogging the windshield this winter!
Going to take the vinyl to my parents and see if my mom can run in through the sewing machine to hem the sides in an inch for me. Bought her some heavy duty needles and heavy duty nylon upholstery thread. Hopefully it works, otherwise I'll be paying the upholstery shop to do it, which I would hate to do. :(
Stopped by the fabric store today and bought some black and brown vinyl to make a cargo cover with. Will be hemming in the sides 1" and adding a metal zinc plated ring in each corner and one at the front center of the cover. Then it's just a matter of figuring out how to mount stretch hooks to the inside without drilling or modifying any of the interior panels or sheet metal.
Will post pictures later this week. It should be interesting, but it will cover up my valuables and the speakers when I do the stereo swap later this year, keeping the appearance pretty stock looking.
thats a really sweet lookin wagon........
