1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
78 hatchback
Date: 03/12/2023 06:50 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 03/25/2019 09:02 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 04/14/2023 06:15 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 07/30/2018 04:32 pm
  • Online today: 484
  • Guests: 498
  • Total: 498
73 Wagon Project - Brownie
Started by dave1987, December 10, 2009, 02:20:02 AM
Since I have the dash apart, I've pulled out the dash wiring harness and will be putting the one from the spare 73 dash I bought with Mr. Tadakichi's axle. All the wiring seems good, hopefully it will help to sort out some issues!
Dome light not working now, argh, electical is such a pain! :(
Was going to buff the paint today but it started to rain, got the top of the passenger side fender done, wow a lot work work it is!
I moved to the inside of the car when it started to rain and decided to clean up the dash a bit with a tad of polishing compound and it came out great! :D
Since i was in there and it was still raining, I decided to pull out the A/C ducting, radio, dash cluster, glove box and climate controls and replace the wiper linkage, as well as repair the climate control switch. Working on the linkage at the moment.
Phil, I'm wondering if it really could be the bulb sockets, but EVERY OTHER light works EXCEPT for the turn signals on the cluster!
I found the hazard light flasher, got a new problem now.....
I put the new flasher in and pulled the switch to activate them and it STILL does nothing! :( Fuse is good to! -.-
Dave, you probably already know this, but the turn signal and emergency flashers are behind the dashboard to the right of the dash emblem accessed through the glove box. ;D
how clean er the contacts for the bulbs? it took me several tyrs to get all of mine clean enough to work. an the hibeem indicator still dont  but i can live with that.
Nope, bulbs are good. I even swapped the rear of the cluster out for the one in my spare 73 dash and it acts the same.
are the bulbs in the cluster blown?
Been driving Brownie around for a few days now. Getting some nice comments and thumbs up from other drivers! :D
Question:
The cluster turn signal indicators don't seem to work, nor do the hazard emergency lights. I cannot find a fuse blown for those lights, and I cannot locate the hazard flasher unit. All the exterior lights work just fine, just no indicators on the dash. Any ideas?
Dave:   Great!!!!!!! look forward to it.  Larry :police:
I'm going to try and run down to my storage tomorrow and pick up the fragments of the old grill and replace the broken fin on the grill you sent me, Larry. I used some JB Weld to fix the grill where it cracked along the bottom. Once the broken fin is replaced, I will paint it up and get that part finished.
Wednesday I'm going out to Caldwell to get a windshield out of a 78, if it isn't the glue in type, and a few other things for both Pintos.
I'll keep ya'll updated!
Dave:  I'm just excited on how great the wagon looks in your profile pix.  Keep up the good work, I'm sure once you get the grill finished, it will look great.   I'm glad you saved this great piece of Ford history.
Larry :police:
Thanks Larry! Your grill is the next thing up! :D
Need to wash it down real good, remove the turn signal lenses, JB Weld the cracked spots and then Primer Paint and Clear Coat it back to silver. :)
WOW!!!! That's all I can say.   The glass looks incredible.  Thanks for sharing the procedure with us, it's a great tip!!!!  Keep up the good work, it's nice to know another Pinto is loved....
Larry :police:
Dave,
It's looking better and better all the time!  I can't wait to see how the paint polishes out!  Keep up the good work!
While I was out working on polishing stuff, I figured I would try the Turtle Wax Chrome Polish on the front bumper in some badly oxidized spots. It really does make a huge difference. Hard to capture on camera, but here's a spot I did to see how well it would come out.
The Last two photos show one of my most favorite things about the Pinto Wagons. The way light, objects and landscaping reflect off all of that glass is just beautiful, isn't it? :)
In some of the first photos I posted of the car, you can see how bad the windows were. Even after wiping them down twice with glass cleaner and a microfiber towel, they were still cloudy and oxidized. So I used some Turtle Wax Rubbing Compound on all the windows, and WOW what a difference! Brownie has better glass than my 78 Sedan does!
1) Rear side window (passenger) cloudy before cleaning.
2) Rear side window (driver) clear after cleaning.
3) Driver's window clean and clear!
4) Driver's side windows all clean and reflective again!
Here are some shots of the headliner in the car. It isn't perfect, but neither is the headliner. It will be replaced with a NEW one eventually, for now this is better than the brown one that hung down on my head an obstructed my rear view mirror.
First two photos are off the headliner from the front to the back.
Third photo is the front area of the headliner.
Quote from: dave1987 on April 19, 2010, 01:52:39 PM
It is true, the headliner would normally be tucked under the top windshield gasket and around the pinchweld. However the way I cut the headliner out of the car at the junk yard, it will glue up just barely under the windshield gasket and still look great! :)
Works for me! ;D
Quote from: blupinto on April 19, 2010, 12:06:26 AM
Dave, the black on ginger actually looks good! I like!  ;D
Me too!  It's a much more appealing color combination than you might think!  It has been my understand however, that in order to install a headliner, the windshield must be removed.  Is this not true of the wagons?
Tomorrow I hope to clean up Larry's grill and get it painted, as well as buff the glass on the car and make it easier to see through! lol
I might be able to clean up the inside some to, we'll see.
Here's a couple pictures of the headliner. I stored it in a tube so it wouldn't get damaged, along with the bows that came off the bobcat wagon.
It was very easy to remove the old headliner and install the new one. I just need to glue it down along the windshield gasket and it will be in all tight!
It got dark before I could take any pictures of the headliner installed, but I will tomorrow.
Before finishing up for the night, I fixed the retractors on the front seat belts and they now work great!
Here's a shot of the car at night at Albertsons as well. I was returning a redbox movie and she looked really nice in the parking lot by itself with a lot light gleaming down on her! :)
Got the chance to do some work on Brownie today! :D
Replaced the old door panels that were falling apart with some black ones I had around as spares for my 78. They actually don't look to bad!
Also removed the old headliner that was falling apart at every seem, and tearing left and right. I installed the black headliner I pulled from the 77 bobcat wagon I parted out last year. It's in great shape for a used headliner, it's in one piece and very solid!
The new headliner and the door panels look great in the car, and actually make the car feel much more home like! :)
rctinker
1977 Crusin Wagon when I was 16
Yay!!!!!  It sounds like things are falling into place on your wagon.  I cannot wait to see the pictures.......  Good luck!!!  Have a great weekend.....Larry
Plan for Monday:
Investigate wiper problem.
Fix passenger side seat belt retractor
Install spare (black) headliner
Buff glass
Maybe in a few weeks I can get some sealant to replace the side window gaskets with the good ones I pulled from a wagon last year. We shall see. If all goes well, Friday I can start buffing the paint!
Thanks for posting for me becky! Glad you got my message and I didn't call the wrong number. lol
Drove her around all day, the 78 might be getting jealous! lol
Monday it is supposed to get up to the high 70's, I'll see about polishing the glass on her then. Maybe I can fix the windshield wipers to...
Need to find some way to temporarily keep the headliner up since it obstructs the rear view...
