  • Online today: 644
  • Guests: 475
  • Total: 475
73 Wagon Project - Brownie
Started by dave1987, December 10, 2009, 02:20:02 AM
Thanks Walter! I would love to come pick it up but I don't have a vehicle big enough to get it at the moment, kind of why I'm trying to get the wagon going! lol I might be able to put it in the trunk of my Saturn Ion, but can't do that until thursday if that works with you.
Day on Brownie cut short, had to take Tia to the hospital, she's been sick for a few days and hasn't seemed to be getting better. They think it's rotavirus. They said we're doing really well taking care of her but want to get a stool sample and run some tests. So they sent us home with some small bottles and tongue depressors to collect a sample and then drop off at the hospital for them.
Wife said I could go back to work on the car but I feel more like staying at home with the family right now and keeping and eye on Tia.
So, today I was able drain and drop the transmission. Took a total of two hours to drain the pan and torque converter and disconnect everything. The bell housing bolts are hard to get to, and getting to the torque converter drain plug and flywheel bolts is very difficult as the cross member is in the way, but I got it done!
I couldn't reach the fluid cooler lines with the transmission still in the car so I let it drop downwards a bit to reach the fittings. While removing one one of them the fitting broke, threaded part sheered right off the elbow with VERY LITTLE effort. So I left to pick up a replacement fitting at Andy's Supply downtown (they specialize in brass, steel and copper fittings/tubing and hoses). I had them make and re-form the return line for the transmission since the previous owner had repaired a crack in the line using a section of rubber hose and a hose clamp. While I was at Andy's supply, I stopped by Transtar next door, a local transmission parts supplier, and picked up the trust washer spacer/shim kit, just in case I need it to set the end play. On the way home I picked up the new modulator valve at O'Reillys.
Once I got home I pulled the transmission out to the end of the driveway and got the pressure washer out to clean it up a bit before disassembly. Not as perfectly clean as I wanted to get it, but it really seems like the metal is stained in some places. Some of the dirt on the bell refused to come off with just the water from the pressure washer alone and I had to hit it with some carb cleaner and then brake cleaner to soften it up some.
Only pictures I have of the project so far is the before and after of the transmission cleaning. Here ya go!
fast64ranchero
Dave, I have the stock C-4 out of my 71, 3K on rebuild, should be able to put it in and go, I think the price is right for you
(free) I also have a 72 parts car if you need anything off it, I also know where another 72-73 wagon is, it's in good shape
72 old V-8 parts Pinto
73 pinto, the nice one...
Yay!!!!! hope all goes well with the rebuild.....Larry :police:
Rebuild kit is in town at O'Reilly's! Has everything I'll need! Only a matter of time to rebuild it now! :D
I wish it were that simple! Lol
Once I get this new phone paid off I can get the rebiuld kit for the tranny and get her back on the road full time again.
thanks for the link SRT! I believe the kit I am planning to get for the transmission has a speedi sleeve in it, hopefully that will solve the problem.
http://www.skf.com/portal/skf_us/home/news?contentId=513135
Quote from: Yelby on June 24, 2010, 12:47:55 PM
Glad you got back to working on Brownie!
I wonder if the driveshaft yoke has a nick or groove in it that is allowing fluid to leak past the new seal?
How's your family doing?
Let us know when Brownie is road ready.
Well it won't be going anywhere now! I had to take the driver side brake line off the rear axle to put on the 78's new axle since the axle is from a 73. I put the one that WENT to the axle in the 78, in a box of parts in the back of my storage unit. For some reason, being as organized as I am, I didn't rubber band or zip tie it to the passenger side brake line like I normally would.
So, before the wagon can go ANYWHERE, I have to dig into storage and pull out that other brake line and bleed the rear brake system again! Good for the transmission! :P
Dave, Brownie looks really good. Make sure to get that tranny leak fixed asap, as I learned the hard way. It is much easier to replace the seal than it is to replace the tranny. That was not fun at all.
Thanks guys and gals, I appreciate your support! Family is doing alright, we're battling with the state to get some help with putting food on the table, paying off a settlement with an old loan on the 30th, no more worrying about going to court! :D
Tomorrow the work on Brownie is going to go on hold, the 78 is being troublesome. I need to adjust the clutch on it since I can hear the throwout bearing being tossed around a bit when engaging the clutch, and it's time for a tune up. Got new plugs today and may be swapping out the cap and rotor tomorrow if it's nasty (yay for lifetime warranties! :D)). I will also be purging the cooling system of air, again, and resetting timing and fuel/air mixture to get it running smooth again.
Dave I so admire your work on Brownie!  My fingers are still crossed that everything will work out right for you andyour family.
Yelby
Well yesterday I jacked up Brownie to take a look at the source of the leak. I found two places it's leaking from...
1) The output shaft seal where the drive shaft yoke slides into the tail shaft of the transmission. I replaced that seal with a new one and for some reason it has a pretty consistent drip. The seal has a one year warrenty so I'm going to take it out and exchange it at Autozone.
2) The intermediate servo cover. I tightened up the bolts and it seems to have stopped. For some odd reason the bolt on the top-rear of the cover was missing, like the previous owner attempted a fix but failed and forgot to put everything back on.  :surprised: I found a bolt that was nearly identical and tightened that up.
The intermediate servo cover seems to have stopped leaking, the output shaft seal drips just a bit, but it was still smoking a little bit.
I also replaced the two inch rubber line for the modulator valve which was so old it wasn't tight around the steel line or the valve nipple!
I took the pressure washer out (with the car still on jack stands) and blasted everything I could off the bottom of the car and in the wheel wells. You wouldn't believe how much crud came off the car! Big ole' stones of tar and sand packed together coming out of the wheel wells, a flow of black dirt out of all the trim, it was nasty! You can definitely tell the car is cleaner now!
The transmission grabs first gear a little quicker now, not GREAT, but it IS better. I think tomorrow I might drop the trans and see about cleaning everything up and do a full fluid change again. Maybe do a band adjustment to be sure everything is snug.
I think what's burning off the car now is just the residue on the pipe and surrounding surfaces, I'm keeping my fingers crossed though!
Once the tranny is done I need to swap out the windshield for the good one I have in storage and get an electric buffer to clean up the paint. After that it's ready for the same treatment my 78 has been getting. Little things here and there to make it just right! :)
Yelby
Hey Dave,
Maybe the metal lines leading from the transmission to the bottom of the radiator have rusted through or the fittings are loose where they screw into the tranny.
Let us know what the the source of the leak was.
Really enjoying reading about your rebuild.  Would like to purchase the car and continue the restoration after you get the tranny fixed.  I'd fly out and would drive the car home, thus the car needs to be road worthy!
Brownie's transmission is spraying fluid out the side somewhere, and all over the exhaust pipe. Today it was so bad the car was smoking down the road!
I'm taking it back to my parents tonight to park it back on the side of the house until I can get the trans rebuild kit and fix everything once and for all!
Checked Brownie's transmission fluid a couple days ago, was really low. I did see some trans fluid on the undercarriage of the car before when I rigged the exhaust pipe to stay in place before I drove it to the muffler shop.
Today I added two quarts of fluid and it's at a good level again. It took drive quicker than it has been lately and it took it for a spin around the block, ran great. Tomorrow we will see how well it takes drive when I leave for work. Hopefully that's all it was.
I need to get it over to my parents to drop the transmission and rebuild it with a kit and trace down where the fluid is coming from! Odd thing is, there is no fluid puddling or dripping on the ground under the car, it must be spraying while driving.
Dave:  The repair on the grille looks amazing.  I'm glad you and Brownie are happy.  Keep up the good work, the car is looking amazing.  Larry :police:
Very nice repair, Dave.  My Lincoln Mark VIII has a broken grille and although I plan to replace it, I think I'm going to see whether I can make a reasonable repair on this one so I'll have a spare on hand.  You just never know!
And two shots of the grill showing how well the repaired slat blends in with the rest of the grill.
First picture is one more of the repaired section from the back.
The other three are of the repaired gap in the "frame" of the grill.
Thanks Dwayne. It's slow progress and little things at a time, but any progress is still progress!
Here are some shots of the repaired slat in the grill. It was a triangle notch near the center of a slat close to the center of the grill. I used epoxy to glue in the repair section and JB weld to glue the "frame" of the grill back together where it separated and left a gap. The JB Weld holds up well to the "stretching" of the grill frame when it is installed, and the epoxy should be more than strong enough to hold the repair in place.
I left some excess around the repair of the slat on the sides to ensure the piece doesn't fall off by just a bump of the grill when I wash it.
From a distance it's very hard to tell it's even been repaired! Then again, how many people stare at the grill of your car up close and personally? :P :)
Larry, the grill came out great! BROWNIE AND ME THANK YOU SO MUCH! :D :D
First four pictures show the repaired slat/tooth of the grill.
Dave,
Brownie looks better and better every time you post pictures!  Keep up the good work!
Worked on repairing the grill some more tonight.
A small crack on the bottom of the passenger side was repaired tonight using JB Weld, should hold up well, will see about it tomorrow night.
The broken fin was "reproduced" using some of the remains from the original grill. A wedge was cut out and then epoxied into place. I will be leaving excess epoxy around the repair to ensure it stays in place. It won't be perfect but it will look a ton better in the end! I will repaint and clear the repaired sections in the next couple of days and post photos.
Thanks Becky, I'll look further into it!
Took a few pictures of Brownie today! First two are of the grill so Larry can see how well Brownie sports it! :) Just need to fix the one broken/chipped slat and it'll look great!
The last photo is of the new plates and the Ford Pinto frame I have on it. I now have a great use for the old frame, and it tells the truth this time! :D
I think, but I'm not positive, that it monitors both. I know Meanie's light was on when I took possession of her last April... luckily I was only driving in little spurts because I was learning to drive a stick-shift. The eejit who traded her to me for my Rickenbacker 330 ran the wee beast dry of oil!  Ruby's engine light would be on every time I started her for the first couple weeks I had her this April- that was a mystery. It doesn't come on butfor a second now when the ignition is on. Ruby may have set too long, so her oil pump or something might have been slow to function. GAWD I LOVE THIS CAR!!!
Oops! Sorry Dave. I got carried away there... ;D
Got the weld done this morning, nice and quiet again, for the most part. There's a slight leak at the manifold where the pipe joins but that's an easy fix! :)
What exactly does the engine light monitor, the temperature or oil pressure, or both? I had it come on and off a few times during a short trip to the gas station a few minutes ago.
Quote from: dave1987 on May 26, 2010, 01:02:04 AM
Got an appointment with the muffler shop tomorrow morning at 11 AM to get the exhaust pipe welded together where the down pipe and muffler pipe connect. $10.00 and they'll call it good! I'll let ya'll know!
If it does the trick, you certainly can't beat the price!
