71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Wheel cap
Date: 04/25/2022 11:21 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 08/01/2023 06:53 pm
nos core support
Date: 01/03/2020 09:39 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 09/01/2017 07:52 am
Date: 07/30/2020 11:45 am
  • Online today: 577
  • Guests: 296
  • Total: 296
Old Topic -New solution? A Clutching Dilemma
Started by Pintosopher, November 16, 2009, 06:36:39 PM
Quote from: pintosopher on November 16, 2009, 08:40:47 PM
Thanks JT,
It confirms a Post by Cookieboy 2 yrs ago and Pintony said much the same thing about reusing the Adj nuts. I wonder if the Nuts are SAE or Metric? And are they available through hardware outlets.
Well, I thought this was easier fixed than going over the pond ;D
Kim ,Becky... There's your answer
I plan on saveing any I get in Pintos that I scrap. I also have a friend on the other side of the pond checking for us too! He will check tomorrow if he has time and get back to me! I'll let you all know what he finds!
Thanks JT,
72pair
Interesting find. I've been using the '74-up cable in my '72 for years. I just reused the original adjustment nuts and didn't worry about not having the fenderwell attachment bracket. Snagged plenty of gears with both 4 speed and T-5. Just thought I'd mention an alternative to original is already available. JT
Howdy all,
The question: Is the clutch cable for a English Ford Cortina with the 2.0L Pinto OHC motor the same as the one originally used in the 71-73 Pinto from Ford USA? Burton Power in the UK has a cable that looks like our USA cable for the 71-72 Pinto. It might be our solution to Import a few to help keep these people shifting good!
Pintosopher...
Never say unavailable, just go offshore
