1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
V8 rear end
Date: 04/12/2018 10:57 am
Date: 02/03/2018 11:28 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 07/17/2018 09:22 pm
Date: 02/14/2019 06:27 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
  • Online today: 1,292
  • Guests: 485
  • Total: 485
Starting to think V8 again
Started by Carolina Boy, March 29, 2009, 09:36:20 PM
happy birthday robert =) go get something nice for yourself.
 :devil: :devil: :drunk: :drunk: :lol:
She don't know me verwey well do she?? :devil:
By the way  :happy_bday: now go buy yourself something purty.   :fastcar:
Hey CB I dont think their is any way to get a rear sump to work. Im not sure, but thier was just enough room for the bell housing to slide down in their. I moved the rear of the front sump forward about 1 inch and welded it up, and after the motor went in i still had clearance on the oil pan to go back further but with out removing the heater box completly the motor could not go back any further. i did move the heater box back 1 inch or so over the trans tunnel. I am back as far as i can go with the headers that i have, and the heater box back as far as possible. But after i set it in i am very pleased with the clearances i have.
Hey Beegle55, I haven't received those pictures yet. If you have been too busy, I can understand. I am in no hurry.
I do have another question for yall. If I wanted to set the V8 back, could a rear sump pan be used? What about a dry sump setup, would it clear?
entropy
Quote from: dholvrsn on April 06, 2009, 06:25:00 PM
I was wondering about an aluminum Modular V8 swapped into a Pinto. I wonder how much one weighs versus the cast iron 2.3 or 2.8. Or if that OHC configuration makes it too bulky to easily fit under the hood.
Also, people here have talked about dropping a Zetec four popper into a Pinto. Has anybody done it?
Unfortunately, the 4.6 is actually wider than a Boss 429 which would make it....tricky...to install.  If you're going to do that much work, hey, why not just go for the Shotgun?
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
I went ahead and took that mans offer for his 5.0/T5 combo. I gave him $200 and a table saw. He didn't want my engine, lost interest in his project. I'm going over next Saturday with a buddy to pluck the drivetrain.
Forgot to memtion I will be fixing up the 2.3 to ride around and the V8 will be rebuilt and hopefully installed by spring of 2010.
turbo74pinto
i dont remember.  i would be curious too.  theres a guy on turbo ford that was doing one also in an svo.  when i checked a few days ago, it hadnt been updated for the past few months.  those motors could be had cheap and pull some decent ponys.  i think the ones out of the fusions are around 150 stock.  50 more than our 2.3s.
bob
So did they ever say how the Duratec swap came out?
turbo74pinto
i think someone was doing a 2.3 duratec swap.  im pretty sure those mod motors would be too wide, although ive never messured.
bob
Carolina Boy,
   I don't blame you for leaning towards a v8 install....there is nothing like the rumble of that v8 on startup. Although the turbo 2.3 is a valid...and functionally effitient...alternative. I documented my entire install right here on FordPinto about 5 years ago...find it in your projects...i still mean to have it compiled for quick referance but have yet to get scott the data...dig back...it is in a number of threads cause I did not know at the time about one contiuous thread...duhhh!
Anyway I used a 77 v6 pinto and found it easier cause it had the front suspention and rear 8 inch...i made my own oilpan and fabricated my own rigid engine and tranny mounts...it has proven to be a good recipe and has given me no problems in functionality.
I can't say for sure but I have read that if you move the left frame mount back 1" you can use stock 65 mustang 289 motor mounts.
I have rubber insulators under my "block plates", nice and smooth. I think smallfryfarm did his the same way. Plus it frees up lots of room for access to the starter.  :)
The Mustangll motor mounts (D72-6038-AA) are hard to find. Is there a substitute or a diagram to fabricate something. I'm not too fond of the block plates, to ridged.
Turbo Toy
Quote from: Pinturbo75 on April 02, 2009, 01:22:31 PM
i thought they did..............you cant go fast with 140 ci............ :showback:
That's right. If you want to go fast, you need a V8. :fastcar:
Beegle55, Slow down and take your time, please. Take care of your things first, I can wait.
Carolina Boy,
I told you that I would provide pictures and I will by the end of this evening. I'm working on wrapping up end of the week stuff and am filing claims to get my Pinto worked on but I will have some info for you by the end of today.  :)
Jim:
  What equipment do you have on/in your carbed setup? Could I bother you to send me a PM or email and describe what you have? I am wanting to do a normally aspirated buildup, I really am trying to avoid a full blown replacement of the motor with a turbo or V8. Thanks for anything you can share.
Something else to consider is that EFI is not the only way to go.  Mine is carbed and will have a blow through setup on it.  EFI right know for me is a lot of dollars compared to doing a blow through.
Just a thought.
Just found an old post by 78pinto dated Feb 18, 2005. Very well written and detailed about a V8 swap in his 78 Pinto. The title is "V8 conversion basics for '74 & up Pinto"
12 cylinder Pinto with four of them turbocharged?  :o
I have made my decision!!!
I will go one way or the other as soon as I make up my mind! :lol: :drunk:
What a great thread. I too am checking all the possibilities, and hearing people's experiences is priceless. I have considered doing the normally aspirated 2.3, and building it up nicely, but I just don't know. My biggest problem? I have never done anything like this before. Even when I did my frame-off on the '57 Chevy, I left the motor alone, as I was not looking for a killer street machine, just a beautiful accurate resto. The other point is, when you DON'T have the experience, you end up spending more $$ on someone ELSE'S experience. For me, body, paint, interior, detail - no problem, have done, will do. But motor work? Ack - that's where I have no experience (and wish I DID!!)
The Pinto >begs< to look stock, but fly when required. I have not made a decision either way as well, but I appreciate you guys sharing your experiences.
I knew I could count on you guys and get some honest opinions and answers. Yall have gave me a lot of ideas to work with.  8)It is up to me now to take this info, research, and decifer it and make a choice :read:. THANKS to all. :drunk:
Hmmm..... wonder why the girls didn't chime in?  :devil:
Well you know what they say opinions are like but holes everybody's got one. Really you cant go wrong either way they both will be a sweet ride. Personally its a feel thing, its like a my Harley Davidson. I put a set of 107 ci jugs 10.5 pistons and a nice cam. When your riding it you can feel the pistons slapping you in the rear, gets the testosterone goin, with my pinto i want to feel the v8 with 10.5 comp. and a nice thumpin cam. I want to coast into a drive in thumpin thumpin. and when i want to go fast i can, but i am gettin old so its more about the thumpin, just my opinion, you make it what you want it to be then you'll love it.  8)
uncleamin
I'm by know means an expert on the subject but I have to agree with steve on this one. You can spend a lot of $ very easy on a turbo project...or you can be patient and wait for the deals. If you just keep your eyes open they will come. I spent a lot more than I needed to my first time around b/c I was in such a hurry to get it on the road. I am now working on my second one and have almost everything that I'm going to need for the swap at a fraction of the price.
As for the decision between V8 or turbo, I strongly encourage you to take a trip down to Greenwood SC and get a ride in Curtis's(Turbo Toy) pinto. I did, and I couln't stop smiling for weeks! Of course that was back when he had the small turbo and about 240 hp. I think now he's somewhere in the neighborhood of 450 now.  :hypno:  Plus it's so much fun killing expensive V8 guys egos with a 4 banger!!!!!!!!
turbo74pinto
i agree with pinturbo75.  they are easier to find than you think.  i payed 400 for my 88 turbo coupe doner with 110k on it.  i personally dont see a point to get an engine and just drop it in.  rings, bearings, crank grind (if needed) and gaskets are like 300-350.  thats some good sound insurance for me.  id do the same for a v8 too.  anyhow, all i needed out of the turbo coupe was the motor, tranny, harness and eec.  by the time i parted and scrapped the car, i got paid $200 for the drive line and got a pair of power buckets for our 34 dodge!
the turbo parts also arent hard to find.  the only thing that could be a pain to get is another turbo head that isnt cracked.  but even those are readily available.  keep in mind that the rods in my turbo motor are stamped "D4" so they are the same rods that have been used in 2.3s since 1974.
i also felt that the turbo swap was easier than the v8.  with my swap, i had everything out of a mustang ii and i still had to cut the firewall for clearance for the upper bell bolts. most people cut the radiator support and move the radiator forward.  you can also move the engine back and cut more of the firewall.  i think that involves modifying the oil pan for rack clearance.  no cast manifolds work other than the mustang ii that i know of.  the hooker headers i had were not cheap at 350 or 375 at the time.  my motor mounts had to be moved and modified.  but i started with a v6 car, it may be different with a 4 banger.  also at the time, only one side motor mount was available aftermarket. although that may have changed by now.
with the turbo, there were no underhood mods that i did.  even with a 3.5 inch exhaust. if you want your factory heater, youd have to move the turbo forward, i think.  you can build your own header for that or buy one...although not much cheaper than the hooker v8s. im not for sure since i took my heater out so it wasnt an issue. but if you have the skill to do either swap, you should be able to fab up a header.  ive got 45-50 into mine.  i think ive also read that the factory turbo location would need a notch in the right front inner fender, above the control arm. although i didnt do it yet and i havent had any trouble or wearing issues, a "u" or "v" notch for the clutch cable isnt a bad idea unless you have a "d9" (i think thats the right stamping) straight pull bell.  the tranny crossmember needs the notches for the mounting studs elongated to the rear about half an inch or so.  i think thats the same with the v8 swap if i remember correct.  and for the t5, the floor has to be cut about 2 inches forward to fit the shifter.  as far as the wiring, its not as hard as it seems.  although it can be intimidating.  the biggest problem that i found was findint where to route the wires as clean as possible.  i just ran mine behind the firewall than out through the factory harness right under the speedo cable.  keep in mind, the plugs only connect with one sensor.  well, other than the fans.
both set ups need different yokes unless the c3 is the same as the c4/t5.  but i dont think it is.  im sure the 4 speed "fog" units were different.  i also shortened my driveshaft a little for my set up.  with my v8, i had a mustang ii driveshaft but i dont remember if it fit right.
in the long run, both swaps arent too hard.  as long as you have patience and some skill, you can do either.  its a mater of what you want.  build something youll enjoy.  waiting for the right thing pays off.
just my 2 pennies
bob
actually i did better than that. i bought 2 pintos (both sedans, a 73 and 75) for 95 bucks. paid 200 for a 85.5 tbird turbo that ran. no title on the bird so it was a parts car. used the engine rearend, and tranny for my pinto, the wiring harness and ecu went on my dads pinto. sold the rest of the bird and got half my money back. sold the 73 pinto and got all my money back from that plus a few bucks for tracking down the title for it. every thing else i go junkyarding and do the ebay deal to finance my car fund or use the barter system.  got my megasquirt for a used 780 holley and 50 bucks. im a cheap bastard but i need to be when it comes to toys.
