Date: 09/10/2018 10:41 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 01/28/2017 12:30 pm
Date: 12/30/2022 01:30 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 02/11/2020 12:09 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 01/19/2020 09:06 am
  • Online today: 125
  • Guests: 116
  • Total: 116
water comming out of the bell housing area
Started by sward, March 22, 2009, 11:53:28 AM
sward
1980 Hatch
My duck is Mighty
Good to hear you got it fixed! One less thing to worry about now! Don't it feel good? :D
sward
I GOT it replaced, there is a frost plug on the back side of the block,  I lifted the car and took the tranny out, and replaced it that way,  If I had to do it again.... Id pull the motor.
1980 Hatch
My duck is Mighty
sward
thank you you made my night with that answer!!!!
1980 Hatch
My duck is Mighty
Branden,
It appears that all of the ford 4 cylinder Pinto engines DO have a freeze plug in the back side of the block. It looks like that means you get to Pull the trans and Flywheel (manual) or Flexplate (auto) . You'll need new crank bolts for the flexplate/ flywheel and It's a great time to look for a leaking rear crank seal and fix it if necessary.
Otherwise, pull the motor and do it all on a engine stand, and save your back and knuckles.
sward
does anyone know if there is a frost plug on the back side of the block?
1980 Hatch
My duck is Mighty
sward
thats what I dont want it to be, But I cant figure out why it started leaking only after I replaced the other frost plugs i would of thought that that leak was lower then the frost plugs, esp if it is a crack in the block. and why its the same flow if its running or not.
1980 Hatch
My duck is Mighty
I am only guessing, but if the freeze plug is OK, you could have a cracked block(God forbid). You may have to take the trans out to get a good look at the back of the block. Before you do that check all your hoses, head gasket and such. Pressurize your cooling system and check for leaks. Good luck and I hope you find something simple to fix.
sward
Hello again,
quick question, where possibly would my leak be if I  have water comming out of where the motor and the tranny meet up? i seen it dripping down there and thought my rear frost plug was bad, but its not the head and plug are all try, once i got under the car all i could see is the water dripping out of where the motor and tranny meet? any ideas?
Thanks
branden
1980 Hatch
My duck is Mighty
