Date: 05/19/2018 04:56 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 07/13/2018 02:21 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Hatch needed
Date: 09/10/2017 09:16 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Date: 12/31/2017 09:03 pm
  • Online today: 584
  • Guests: 364
  • Total: 364
quickie 8" pinion question
Started by dholvrsn, February 18, 2009, 12:11:24 PM
rkk
The yellow paint is there from when the rear was originally set up.  It marks the pattern on the teeth to make sure the pattern is in the middle of the teeth not at the rim of the teeth.  If this was apart and put back together you will have to reset the pattern.  Warning though to reset the gears is hard with out getting a whine out of the rearend because it has already woren a pattern in the teeth. You will need to set the backlash, endplay with a dial indicator(I think it is around .012) and pinion depth if this has been apart. Below is a link on 9" gear setup but the 8" is exactly the same.
http://www.ford-trucks.com/article/idx/0/065/article/Ford_9_Inch_RebuildGear_Setup.html
1976 TURBO PINTO
It's believed to be a genuine Ford 3.25 gear set. Right now the thing is assembled with the yellow painted pinion tooth between the two yellow painted ring gear teeth. When I cranked this all around, the grinder mark never landed between the two yellow ring teeth.
This one is a bit over my experience level. BUT I have in my possession a copy of the FoMoCo rear axle service guide. It has no mention of the yellow paint but states that the pinion tooth with the mark is in "time" when it is in mesh the two marked teeth on the ring gear. Are these gears a ford set or aftermarket? There's a bunch of measurements to be sure!
Is the tooth on the pinion with the notch ground into it supposed to be the same one with the yellow paint mark? I got hold of one where these are two different teeth. Thanks!
