Many Parts Listed Below
Date: 04/20/2018 11:15 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 06/05/2018 09:13 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 02/05/2017 09:45 am
Date: 07/30/2020 11:45 am
Date: 04/08/2018 05:47 pm
Date: 02/18/2017 04:47 pm
74 pinto
Date: 09/11/2016 06:32 pm
  • Online today: 529
  • Users: 1
  • Guests: 294
  • Total: 295
  • TommyT
2.0 timing belt tensioner
Started by 72Wagon, January 13, 2009, 07:22:45 PM
The tensioners can be made to be rebuildable, but it's not easy to do without access to a machine shop.  The "billet" aftermarket ones for 2.3s are simply stock brackets with a different wheel and axle that can be bolted together.
yhalkeeiron
Thank you I took it off it's actually my distributor is making the noise the timing belt tensioner is good but I'm going to order one anyways
Sent from my SPH-L710 using Tapatalk
yhalkeeiron
I can't find it on rockauto. autozone doesn't have it. BAT has it  but its $70 O'Riley might have it as a special order still trying to find. But was wondering if anybody modified the 2.3 belt tensioner to work?
lol your right I see that now. I had a whole list of parts saved from working on someone elses pinto a while back. let me see if i can find it on the list and see where we got the new one.
72Wagon
Quote from: 75bobcatv6 on January 14, 2009, 02:00:23 AM
Autozone.com Price 36.99 http://www.autozone.com/Ntt,Timing%20Tensioner/shopping/allResults.htm;jsessionid=40285C5E391B31FA9CA753E2BFDA8B08 hope this helps.
This comes up as drill bit and tap set ????? Don't know what it has to do with a tensioner. It is listed as a Comp Cam tensioner
1972 Wagon
Hey,
Another option, BAT Ltd. (British American Transfer) in Florida. The online catalog for S2000 road racing engines (Pinto SOHC) shows a tensioner for about $40. It'll last!
72Wagon
Thanks everybody, I drive by an Autozone on way to work, will stop in and see what kind of quality they are carrying. I turn this thing up past 7,000rpm at times and I don't need china shrapmetal flying around the engine compartment ;D
1972 Wagon
pintoches
i got mine from work.  (O'reillys)  let me know if you want me to get the part numbers
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
72Wagon
1972 Wagon
Bipper
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
72Wagon
 First I want to know if anyone has tried and had any luck replacing the bearing in the tensioner on a 2.0? Second are these still available and what might I expect to pay for the whole unit?
1972 Wagon
