Date: 05/28/2017 03:20 pm
Date: 03/29/2019 07:20 am
Date: 02/28/2018 09:33 am
free transmissions
Date: 11/28/2019 10:21 am
Date: 11/29/2018 10:26 am
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 07/17/2019 05:23 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
pro stock front end
Date: 06/28/2019 07:43 pm
  • Online today: 489
  • Guests: 387
  • Total: 387
Progress
Started by 71ss351, September 12, 2004, 01:00:17 AM
CHEAPRACER
71ss351
got me a set of weld 10 inch rims on the back know and bought me a set of uniroyal 275/60/15s for them, also decided to go ahead and use the swap headers, much easier to run exhaust, they sound a whole lot better too. ;D, I have also been losing oil from some where and found out it was coming from the back of the motor, as it turns out this motor has 2 rear main seals a 2 piece in the rear main cap, and one piece in the back of the motor, I just had the 2 piece in it and thats why it was leaking. I pulled it back out again and put a seal in it. I am going to hold off on putting it back in for know, b/c my buddy is giving me a set of 69 351 heads, which some one put a set of 2.00 1.60 valves in and double valve springs on them, I am going to get one of my buddies to shave them down .030" and my other buddy is going to port, polish them, and do a 3 angle valve job on them. not to bad huh?
71 Pinto
351 Interceptor w/ comp 274 cam
C-5 Transmission
7.5 rear end with 3.73 posi trac.
71ss351
sorry I have not updated in a while but every thing is moving very fast know, I bought me a rear end assembly with full posi trac and 3.73's for $125 from a buddy of mine and got the mustang rear end to go with it free, he also gave me a set of traction bars he had sitting at his house. I took my old rear end and the new one to out local welding shop (camden welders) and they are going to put the leaf spring perches on the new rear end on for me, and on top of that, they told me to bring the car down there and they would weld me up some mounts for the engine in the car and at the most was only going to cost me $50. other then that I bought me a set of weld draglites 15 X 10 for the rear.
71 Pinto
C-5 Transmission
71ss351
got everything set back up and got the valves adjusted, and know it sounds better then it did. ;D
71 Pinto
C-5 Transmission
CHEAPRACER
Quote from: 71ss351 on December 22, 2004, 10:40:36 PM
I saw that the pushrods where being eat up by the guide plates.
This will also happen if you instal aftermarket heads with guide plates on your late model 5.0 and use the stock pushrods.....................trust me, I know. :'(
At least its a top end job............. :)
71ss351
started the engine up 2 days ago, finally, and it sounds great ;D. I have been running it the past couple of days, untill last night when something bad happened. I hard a really loud knocking sound coming from the engine, I got close to it and it sounded like it was coming from the valve covers. I took them off and I saw that the pushrods where being eat up by the guide plates. It had scraped kind of a barrier on them that kept the pushrods from going beyound that point and thats what was making the knocking sound. The guy that I bought the motor from had the wrong pushrods. so know I have to go buy the right ones.
71 Pinto
C-5 Transmission
71ss351
one of my rims on the front is warped :'( so untill I can get it fixed I am going to have to put the the factory thirteens back on the front.
71 Pinto
C-5 Transmission
CHEAPRACER
Quote from: 71ss351 on November 30, 2004, 05:37:29 PM
mounted a tv under the dash,
PIMP THAT RIDE!!!!!!!!!!!!!
71ss351
sorry I have not posted in a while. I finally finished the motor and got the transmission rebuilt. I also installed a chrome three spoke steering wheel, pioneer cassat player with speakers, mounted a tv under the dash, and wired the fuel pump, fans, and coil to the switch plate. All that's left is to weld the motor and tranny in and a good paint job, which me and my dad are also going to do. I am going to get 3 inch pipe put on with glass packs for now and then 2 chambers later. And I decided to do the reverse shorty idea so I do not have to cut the fenderwells out.
71 Pinto
C-5 Transmission
71ss351
sorry it came out of my 86 mustang. Also have some really great news, a buddy of mine gave me a set of hooker super competition engine swap headers for my pinto ;D. he said he was cleaning out the atic of his friends old house and found them. He said he was going to throw them away but remembered I was looking for a set and said that I could come by and get them and I could have them. So I picked them up tonight. I also have the motor back together and ready to go in the car. I have an edelbrock torker II intake on the way that I won off of ebay also.
71 Pinto
C-5 Transmission
73pinto
Darn, if it was a 4wd c5 i would've traded you straight-up for a c4 out of a 73 302 maverick.  Need somethin to replace the a4ld in my 90 Bronco II.
-Harry
Stock 73 2.0/4spd 3:40 maximum slip, cd player, pop-out quarter glass.  Soon to be slight performance 2.0/5spd and much more...
71ss351
I finally paid the motor off today and brought it home  ;D. I found out that it has a really nice size cam in it so I may leave it in. bad thing is that the pistons are dish  :'(. so not sure what the compression is.
71 Pinto
C-5 Transmission
71ss351
added some more pictures to the website and a couple of other things.
71 Pinto
C-5 Transmission
71ss351
they were already installed in the car when I bought it. They are made by sunpro. This was the first set I have ever saw like that, not sure they still make them but you can probably check out their website. when you first switch the car on they all light up then sequence down to zero ,except the battery gauge which sequences down to  between 12 and 13 volts. cool huh?
71 Pinto
C-5 Transmission
Hey 71ss351 where'd youi get that triple gauge cluster?? I LOVE the digital gauges
71ss351
got my website up and it has pictures of the interceptor check it out
www.geocities.com/ss351pinto/index.html
71 Pinto
C-5 Transmission
71ss351
mounted a neon aqua light under the dash and have it set up where it comes on with the headlights, I think it makes the inside of the car stand out a little. also forget to mention earlier, I put my rims on. dont know what kind they are, but I had them on my mustang. I also found my digital camera so I will be adding some pictures tomorrow. It does not take very good pictures b/c it is one of those wal-mart cheap miny cams.
71 Pinto
C-5 Transmission
Use what you want, we are just trying to give you good information......... ;D
71ss351
I cut the radiator support out today to make room for my three row, still needs a little clearancing but it looks good. I also checked with a couple mechanics arround here and the told me that the c5 is a good transmission and that the only difference is the clutches the valve bodies are just about the same because my uncle had a c5 and he put a c4 valve body in his and he did not have to modify anything, one of the mechanics told me that the c5 is a little bit better then the c4.
71 Pinto
C-5 Transmission
71ss351
Got my electric fan put in and also hooked up my switch plate with push button ignition, and it looks and works great. Hope to have pictures very soon.
71 Pinto
C-5 Transmission
71ss351
I am not planning on racing it untill next year because Thats when I am going to redue the whole drive train. I am just getting it ready for a car show we are having at autozone on holloween. next summer I am going to put my 8 inch rear in, change the trans, and put some good heads on it. I just needed a 2500 stall for my cam, because the stock one idled the car at about 1100 in park then 600 in gear, when I started my 302 up with this cam and stock converter it sounded like I was at the track ready to go. dont want that with the 351. ::)
71 Pinto
C-5 Transmission
They are awefull without a performance rebuild (mushbox) A local Drag race trans builder did it for me, it required machining to get the extra clutch plates in but i'm not sure what he did inside. It shifts hard and fast, on the 1-2 shift it will break loose and head for the wall at the track and thats with my M/T ET streets! If you can get one, get a C4 as they ARE better and the shiftkits are readily available. Just my 2 cents
71ss351
hey 78pinto did you get some kind of special kit with the 7 extra discs? also does it shift harder and quicker?
71 Pinto
C-5 Transmission
Jeff,Im glad you took the time and did your trans correctly. My fear with this set up was that with a high torque V8 he would shred that C5 to bits.Not a good thing to happen while out on the road or track.
71ss351
P.A.W. sells a universal pan that fits both a c4 and a c5 I might try that with the c4 valvebody
71 Pinto
C-5 Transmission
my car has a C5, it is built and has 7 extra clutch disks. They are basically the same as a C4 but they are a weaker tranny from the factory, i used a C4 convertor and a C4 bellhousing (C4 bell is shorter than the C5) If you really want to get tricky, put a C4 valve body in it but you'll need to modify the tranny filter and pickup to work in the C5 pan.
BTW, I did not answer  your question about the converter. So, the C5 torque converter is a centerifugal controlled lock up converter which is no longer available. The replacement is called a TT converter ( non lock up). A C4 converter will work as long as the spline count and shaft diameter are the same. I also Neglected to ask if you were going to go through the C5 and modify it. If so, you can make the C5 about as strong as the C4, however in its stock state I still would not use it.
 I still would not use it. Just my 2c worth.
71ss351
mine came out of an 86 mustang with a 3.8 v6 than I went to 5.0 with it
71 Pinto
C-5 Transmission
