Date: 08/08/2018 12:26 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 02/08/2018 02:26 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 09/05/2018 06:30 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 10/28/2018 08:45 am
Date: 08/26/2018 06:23 pm
  • Online today: 445
  • Guests: 145
  • Total: 145
Progress
Started by 71ss351, September 12, 2004, 01:00:17 AM
A C5 is well know as being made of Cheese and foil. If you put any torque behind a C5 it WILL brake. If you take a look at any given auto trans site you will never see a C5 on the list of things they sell. It's becouse of the Cheese/foil factor. Heck, I dont even know of One car running a C5 in it other than maby a stock 1985 mustang with a 2.3 engine in it.However, I would recommend that you email one of the better known Trans shops and ask them what they think. This will get you In the comfort zone im sure.
71ss351
71 Pinto
351 Interceptor w/ comp 274 cam
C-5 Transmission
7.5 rear end with 3.73 posi trac.
71ss351
By the way my pinto will know be known as "THE INTERCEPTOR" 8)
71 Pinto
C-5 Transmission
 I wouldnt use a C5 for anything.........  :'(
71ss351
pulled the numbers from my trans. today, turns out it is a C5 not a C4. Anybody know where to find a stall for it ??? ?
71 Pinto
C-5 Transmission
PintoBro
Quote from: 71ss351 on September 18, 2004, 07:33:58 PM
I went to napa today to get a price on some battery cables, and they wanted $160 for 6 ga. Then I decided to go to autozone where I work and price some jumper cables, they had a set of 4 ga. 20ft. long cables for 29.99, so I boought them along with some ends and with my discount it was only $25. I went home, cut the clamps off, put my ends on and ran them through the car. When I hooked them up, every thing worked just like it was under the hood. Not bad, moved the battery to the trunk for $25 ;D.
How did you fasten the battery down? If you take it to the track, and if it's a hatchback, you will need to put the battery in a sealed box (must be approved by NHRA), and vented to the outside of the car, and a battery shut off switch. When I did mine, I used welding cable, and I moved the starter selenoid to the inside of the firewall, where the heater used to be. This made a convienant place to grab power for any electrical componet.
Pintobro
71 Pinto 306 10.0:1 351w heads
Comp Cams: .554/.558 lift .294/.306 duration
Torquer II Intake - Holley 750 HP
Sepanek's Racing Transmissions C4 (Full Manual)
8" rear (4.62 spooled)
pimpin_pinto
jeez, this car sounds crazy, your making progress fast.  so stop, you're making everyone else look bad.  haha, sounds awesome though.
71ss351
71 Pinto
C-5 Transmission
71ss351
I also took my valve covers and oil pan to my other buddys shop to have them cleaned. I have the 70's style with POWER BY FORD printed on them.
71 Pinto
C-5 Transmission
71ss351
Got my headers back from the muffler shop, now they are ready to be rebent.
71 Pinto
C-5 Transmission
71ss351
I am getting a great deal. A buddy of mine was building a 351 interceptor for some kid at his shop, and the kid changed his mind about the car and left the motor with my buddy. The kid had bought brand new stuff for it, including forged pistons  ;). Now here is the deal, my buddy had $400 invested in getting the motor finished, and thats all he wants for it  ;D. Now I will have a Pinto Interceptor  8).
71 Pinto
C-5 Transmission
71ss351
I used it for the trunk floor. My dad had some sheet metal for home a/c system, the kind they use for the big pipes, laying out in the barn and I got a piece and measured the trunk then drew the form out on the metal and cut it with a cut off wheel. The reason I used this metal is because it has a kind of rib design on it. Great idea huh? 8)
71 Pinto
C-5 Transmission
What did you use the "plate" for?  The hatch or the trunk floor? What did you use for material?  Thanks, Tricky Dick.
71ss351
Took my headers to the muffler shop today to have them cut. I will pick them up friday and then bend them to fit my pinto.
71 Pinto
C-5 Transmission
71ss351
I have finally started working on my projecet. I have made me a plate for the trunk out of sheet metal, and It looks great. I moved the battery to the trunk and now I need lots of cable. I also put my hurst ratchet shifter it. I want to start on the engine friday. I found a rebuild kit through Power House for $230 that comes with every thing but the crank,cam & lifters, and rods. great deal. I will keep you posted
71 Pinto
C-5 Transmission
