Date: 04/25/2017 12:17 pm
Date: 03/06/2017 01:24 am
Date: 09/20/2018 11:01 pm
78 windshield trim
Date: 02/01/2020 08:46 am
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 02/10/2017 09:30 am
  • Online today: 153
  • Guests: 131
  • Total: 131
The Baby (aka the copper queen)
Started by blupinto, November 28, 2008, 09:41:14 PM
Quote from: discolives78 on January 31, 2009, 03:37:04 PM
Hey Kim!
I'm getting ready to do my timing belt so I'll take plenty of pictures, I've done it before, It's not difficult, just time consuming. I'm pretty sure Pep Boys still carries the belt. Keep your chin up.
That would be Becky!!! LOL I'm sure she doesn't mind the name mix up though because we are Pinto buds!!!! LOL
Hey Kim!
Update:
    This morning my mechanic neighbor (a great guy, is Jerry!) took a look at the Bronze Metalist. He gauged the fuel pump pressure (average- 5 PSI) and was kind enough to do a compression check while he was at it. The readings averaged between 120 and 135. He looked at the spark plugs and judged them alright (no oil fouling, etc.) and checked the distributor and rotor. He does think the timing belt jumped or is otherwise off-kilter. He is also concerned about the knocking he hears in the engine. He says right now it's not driveable and the reason it's stalling on inclines is because the car doesn't have enough power to climb.  Now I'm looking at timing belt (probably be a good time to replace it), battery, spark plug wires to replace for now. The belt might be fine, but I do see tiny cracks on the edge of the belt. Waaaa! I'm grounded!!!
Dave my fuel pump is from a Yamaha seika. runs 5psi, and is set an an auxiliary switch. not hard to wire one in.
 ;D Thank you Dave. I'm lucky to have a Pep Boys, Car Quest, Autozone, and Kragen (owned by the same folks that own Schucks). I'll shop around. But first I'll have my mechanic neighbor do that pressure test to see if that's the issue.
Yeah. The only reason I haven't gone to another supplier is because my dad purchased a replacement pump for it back in 1987 from Schucks and got the lifetime warranty on it. I can still get my fuel pump replaced free of charge because of that, and I never had enough cash to pay for a different one.
And so I leave you with, beware of Schucks, Parts America or O-Reily's reman fuel pumps!
 :-\ Er... I know how to install a solenoid on a highway landscape sprinkler, and I know to shut off the electricity in my house if I need to replace a lamp or ceiling fan, but I'm not that knowledgeable on car electronics. After reading that thread about the electric fuel pump and relays and Hobbs switches I think I'l gonna stick to the mechanical one. I want to keep my girl as close to stock as possible. Sorry about the duds you had to replace last year.
I really couldn't tell you. My gut is saying to go electric, as it is less likely to go out on you since just about every replacement mechanical pump available is re manufactured and I had four of them go out on me last year.
I have everything on my car to do an electric pump conversion, all I need to do is hook up the hoses. The only reason I have not done so, is I like the originality of the mechanical pump, and I have not yet found an adjustable fuel pressure regulator which will let me go down to 3.5 PSI, and still have a return valve on it.
Converting to electric does require some electrical knowledge, as you have to wire up a relay and the safety switch to operate when the car is running, and not when the ignition is off.
Thank you both for the info. In your opinion, which is better or more beneficial- mechanical or electric (when all safety issues are met)? Come on Tax Refund!  ;D
They SHOULD be able too. Mine did great when climbing over the blue mountains during my trip to Spokane a couple weeks ago!
It sounds like the fuel pump is going out, to me. I would recommend checking how much pressure you are getting from the pump using a gauge. Mine delivers a healthy 7-8 PSI.
If you convert to an electric pump, be sure to read through the safety thread here, and don't use a pump any higher than 4PSI. The mechanical pump delivers fuel in "spurts", an electric pump would give a constant stream of fuel.
Since I'm quite the novice about the fuel system I'll go along with that, but most Pintos can climb a hill without incident (running Pintos that is!) right? These aren't mountain-goat grade hills.
Possible for the Fuel pump but its Mechanical so i dont know. as for the float issue i believe that it would do it no matter what if the float was messed up. Alternative is to add a small 6-8psi external pump to help boost volume to the mechanical pump.
Oh when will I learn...
          I got an itchin' to fool with the Baby again and got her running. She idled well for a few minutes so I was encouraged to take her for a spin around my neighborhood. So far so good... until I turn around to go home. My turning point was a couple streets below where I live. I'm noticing a pattern here. Going down on a decline the Baby's fine. On level ground she's fine. Going up on an incline she's not fine! >:(  Could this be a float issue or a fuel pump problem? I only bog down and stall on inclines we're ascending.
           On a happier note I did find another crimpy hose that connects the air filter to the blue cannister filter.
 >:(Did I mention I hate thieves? >:(
      I have yet another question: Does anyone have any advice for repairing interior stuff where the threads are simply brittle? I gently but firmly tried to pull the fabrics (the headliner and the top of the back seat) but they won't stretch and I'm afraid if I force the issue (pardon the pun) I will be very sorry. Apparently the pix I took are in a mystery file. I'll post them later. Thank you.
Thank you. I know I am fortunate to live in such a moderate climate. You folks in the ice and snow zones should move out here!  ;)
      Good news: I found some goodies at the Oceanside and Santee swap meets that'll help me work on the Pinto I have and the Mustang II I'm hopefully getting. I found an extension piece and a working ratchet for spark plug removal and a Haines Mustang II repair book for a couple bucks. Now the bad news: At the Kobey's swap meet in San Diego I somehow lost my little purse that had all kinds of important stuff in it like my drivers license, a credit card, ATM card, cell phone, nail file, AAA card, etc. I hate thieves! I couldn't go to the junkyard today like I had planned. Cards are cancelled at least.
Looks like she is really coming along. Really nice work.. I am jeaulous of you being able to work on your car at the moment. It's just too cold & & snowy for me to work on mine.
LOL! Good one Kim!
        Dave, I am still on the lookout for door panels and other goodies folks here are looking for. I recommend these deluxe door panels for everyone! There's a similar door panel that doesn't reach back so far. I only have the decorative piece (I got this in the early '90s too).
Quote from: blupinto on January 16, 2009, 07:43:00 PM
Well, it's time for an update:
     I tried to pull a spark plug wire off a spark plug (yes I gripped close to the plug, as opposed to pulling on the upper part of the attachment or the wire itself and the metal contact stuck on the spark plug anyway!  >:( So it looks like I'll need new wires. I couldn't get the plug off because I need the right spinner. sigh.
         The armrest is inoperable. The only chance it'll have to live is Loctite super glue. Because I don't want to rebrake it I am saving it for showtime and in the meanwhile Baby's sportin' these red-hot mamas (see pix)
It's good to have friends in high places (how do they look Pintogirl? lol.)
Wow, those arm rest look awesome!! You sure are lucky to have an awesome friend like that!!! LOL  They actually don't look all that bad!!
Love the leapord print seat covers!!!!  ;D
Yep, sounds like a run to the parts store is in order. Maybe once you get new plugs and wires, your baby will run better??? Let's hope so!!!  ;D
The more I look at your door panels, the more I want a set of them in black. :(
Borg Warner Select Series of spark plug wires have treated me well. And with a 5 year warranty, the deal is even better. I got my set for $35 at Schucks (Parts America).
SEM makes a vinyl paint, which I have been using to change the color of my new center console from bright RED to BLACK. It has worked very well, surprisingly.
I have used SEM paints before on my current console to change from gray to black, but that was on plastic. The new console is solid vinyl, and I was worried about the durability of the paint. Using SEM's Vinyl Prep spray (which is like a cleaner. spray on and wipe off), it seems to be holding up VERY nicely, and I highly recommend SEM interior paints to anyone. My local auto paint supply store will color match any color you have and mix it for spray can use too. Check around with your local auto paint supply stores and see what they can do for you if you want to continue using those armrests.
After 60 days gas goes bad. mines been in there about 7 months.... i drive on a regular basis a 1997 Dodge caravan. Until i am done with the bobcat. and this Feb the van goes to its Home, and i get a 2001 Sable for a DD. So i would recommend that you use Stabil now before you have to drain the tank. its only 4-6$ for a thing of it. Best insurance you can get for your car. too bad i learned about it 3 months after i filled the car up. =/
 :hypno:She has a full tank of relatively fresh gas (1 month ago it was filled) and she'll be sitting for only that couple months. If it's still a good idea to get Sta-Bil I will. Thanks.
If you plan to leave her sit, without runnign her I would get a thing of Sta-Bil from autozone or another parts store to keep the gas good so you dont have to do what I have to do. and drain the tank out and clean it.
 ;DI came home from work today and found a '74 Pinto pamphlet waiting for me in the mailbox. Now I know a few things about my Baby: She is in what's called the Luxury Decor Group. She is Saddle Bronze Metallic (5T) with saddle interior (BZ) and optional flipper rear quarter windows. THis is information that's been driving me crazy not having.
        While I was sitting in the Baby watching a glorious sunset tonight I made a mental list of things I can do that don't require too much brain power! :lol: I'm going to see if :
surgery can be performed onm the armrests (skeletal transplants); ???
pull all the spark plugs and check them (shoulda done that already I know); :rolleye:
check distributor (ditto on the shoulda done); :rolleye: :rolleye:
study study study the carburetor and see if I adjusted the wrong screw (probably did). :read:
Question: It'll be sitting in the driveway for a couple months without running. Is this OK? A neighbor who seems to know cars suggested I not run her til the mechanic has looked at the engine ( there's a tapping noise). I'm all for not making any problems worse.
If you like it  keep it no one else will know..
The woodgrain one on my bobcat does not always  line up  so i have to take it off rotate it and put it on again. phil
Oh well...  :cheesy_p: Thank you guys...
Dwayne got it! Sorry. :(
Merry Christmas!
The handle part of the gas cap should be horizontal.  The cap in your photo is not correct.  Sorry.  Merry Christmas!
Merry Christmas to all, and to all a good night!
Well, the color is a tad off... the cap goes on and I'm able to tighten it, but what do you mean if it won't go on straight?
