Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 12/31/2017 11:14 pm
Date: 02/16/2019 10:46 am
Date: 07/17/2018 09:49 pm
Date: 04/12/2017 06:57 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 04/20/2017 10:10 am
Hatch needed
Date: 09/10/2017 09:16 pm
  • Online today: 178
  • Users: 1
  • Guests: 136
  • Total: 137
  • rob289c
JUST A THOUGHT?
Started by Twister_Reject, August 24, 2008, 11:47:25 AM
apintonut
the ranger is  shorter not the same as t/c
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Quote from: apintonut on August 24, 2008, 05:00:03 PM
what is the  hood clearance issues????
The 2.3 with EFI may have the T/B over the V/C. It takes modifing something somewhere to get the hood to shut (or just slam it a few times to make it a custom fit).
apintonut
Quote from: 77turbopinto on August 24, 2008, 04:54:41 PM
As talked about in the first post; 2.3.
Quote from: apintonut on August 24, 2008, 02:13:47 PM
2.3? or v8? bill
ranger 2.3 efi is different almost every year.  they also changed the 2.3 block in 77 or 78 they changed the block again in 93 that i know of there may have been a few other  block changes. i dont know but i do know the engine mounts and fuel  set up changes though the years
apintonut
Quote from: 77turbopinto on August 24, 2008, 12:13:05 PM
It will not "direct-bolt"; you will need to swap oil pans and deal with hood clearence.
2.3? or v8? bill
Twister_Reject
The oil pan I expect and the hood not that big of deal but other than that all I want is a solid foundation to start with.
Quote from: Twister_Reject on August 24, 2008, 11:47:25 AM
Now I just learned that any '74 through '88 Ford 2.3L will interchange. And that means say a 1987 Ford Ranger 2.3L will directly bolt into a '77 pinto. No need to worry about frame mount/motor mounts. Now if that is true why can't a guy use a v8 Ranger swap kit to put a v8 in his Pinto? Now I'm sure you probably are going to have some issues like oil pan clearance or something along those lines. But this could be a start to a solid conversion right? So now I'm really curious to hear from the first thousand  or so people that thought of this before I did of why it won't work, didn't work, and there solutions. ???
Twister_Reject
