Date: 08/26/2018 06:35 pm
parting out 1975 & 80 pintos
Date: 10/31/2018 12:00 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 01/30/2017 01:48 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 06/24/2020 06:12 am
Date: 11/23/2017 05:44 pm
  • Online today: 178
  • Users: 1
  • Guests: 102
  • Total: 103
  • rob289c
JUST A THOUGHT?
Started by Twister_Reject, August 24, 2008, 11:47:25 AM
apintonut
the ranger is  shorter not the same as t/c
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Quote from: apintonut on August 24, 2008, 05:00:03 PM
what is the  hood clearance issues????
The 2.3 with EFI may have the T/B over the V/C. It takes modifing something somewhere to get the hood to shut (or just slam it a few times to make it a custom fit).
apintonut
Quote from: 77turbopinto on August 24, 2008, 04:54:41 PM
As talked about in the first post; 2.3.
Quote from: apintonut on August 24, 2008, 02:13:47 PM
2.3? or v8? bill
ranger 2.3 efi is different almost every year.  they also changed the 2.3 block in 77 or 78 they changed the block again in 93 that i know of there may have been a few other  block changes. i dont know but i do know the engine mounts and fuel  set up changes though the years
apintonut
Quote from: 77turbopinto on August 24, 2008, 12:13:05 PM
It will not "direct-bolt"; you will need to swap oil pans and deal with hood clearence.
2.3? or v8? bill
Twister_Reject
The oil pan I expect and the hood not that big of deal but other than that all I want is a solid foundation to start with.
Quote from: Twister_Reject on August 24, 2008, 11:47:25 AM
Now I just learned that any '74 through '88 Ford 2.3L will interchange. And that means say a 1987 Ford Ranger 2.3L will directly bolt into a '77 pinto. No need to worry about frame mount/motor mounts. Now if that is true why can't a guy use a v8 Ranger swap kit to put a v8 in his Pinto? Now I'm sure you probably are going to have some issues like oil pan clearance or something along those lines. But this could be a start to a solid conversion right? So now I'm really curious to hear from the first thousand  or so people that thought of this before I did of why it won't work, didn't work, and there solutions. ???
Twister_Reject
